esp32 how can I get result digital wind speed sensor
how can I get wind speed from digital wind speed sensor
I try a lot of code but it doesn't work
example
float  windspeed;
volatile unsigned long start, duration;
  pinMode(27,INPUT);
  pinMode(5,OUTPUT);
  attachInterrupt( 0, wspeed,  RISING );
  start=millis();
void wspeed()
  duration = millis() - start;
  start    = millis();
digitalWrite(5,digitalRead(27));
Serial.print ("windspeed : ");
  windspeed = ( 312.5/ (float) duration ); // .3125 mph per hz
  if (duration > 1000)
    windspeed =0;
Serial.print (windspeed);
Serial.println (" MPH");
peak_wichu:
What does it do?
A common approach is to use interrupts as you did, but just increment a count. Periodically, calculate windspeed and zero out the count again.
No need to zero out the count, just remember the last value you read.
Also you may need a critical section to read the count if its an 8-bit microcontroller and
more than 8 bits of counter...
wildbill:
What does it do?
I don't know how to pause loop for counting interrupt. Please show me how. Thank you
