ESP32_How to read I2C or SPI with precise time Interval
Hi Forum,
Just wondering if anyone could suggest a proper way to read the I2C / SPI in precision interval with ESP32?
Currently, I'm trying to build a gimble with DC motor(w/encoder). I use a LS7366R (external encoder counter with SPI) to count AB encoder and MPU6050 IMU to get the angle. Since I need to calculate the speed of the motor and do PID calculations, I need precise 20ms time interval. So my plan is put PID code and I2C / SPI reading in timer interrupt.
I used to put I2C / SPI read in a timer interrupt with Arduino Nano with Interrupt(); & noInterrupt(), and it works fine. However, when I start use ESP32, this code doesn't work as it does in Arduino. The ESP32 only runs main loop with taking care of interrupt. So is it possible to turn on the interrupt...when it is already in an interrupt?
I did A LOT search about this topic and the most common suggestion is set a flag in interrupt, and do the I2C and SPI read in main loop. However, based on my knowledge, (please correct me if I got anything wrong) by doing this, I would lose the time stamp so the interval between each reading is different, which causes unstable speed calculation and jump of Kd tern.
So is there any suggestion about how to read I2C/SPI in the timer interrupt? or how should I develop my algorithm?
Any help is appreciated!! Thanks a lot,
Bests
G
Set up a freeRTOS, the ESP32's built in OS, task, to run a thread using either a hardware timer or the sorta equal to millis() or use a hardware timer to trigger the task.
Here is a task that uses the equal of millis to run in its own thread:
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 1000 * 15; //delay for mS
  for (;;)
    log_i( "tick");
    if ( WiFi.status() == WL_CONNECTED )
      camera_fb_t * fb = NULL; // pointer
      fb = esp_camera_fb_get();
      if (!fb)
        log_i( "Camera capture failed" );
        ftp.OpenConnection(); // try open FTP
        if ( ftp.isConnected() )
          //try send file ftp to RPi
          ftp.ChangeWorkDir( ftp_path );
          // Delete existing file, create the new file, and send the image to the file
          ftp.DeleteFile( ftp_file_name );
          ftp.InitFile( ftp_file_type );
          ftp.NewFile( ftp_file_name );
          ftp.WriteData( (unsigned char *)fb->buf, fb->len );
          ftp.CloseFile();
          ftp.CloseConnection();
        esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
      log_i( "In capturePhoto_sendFTP found WiFi not connected ");
      connectToWiFi();
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
On the other had using a hardware timer will give a precise event trigger of 20ms.
If you want I can show how to set up a hardware timer to trigger events.
I had a look into the LS7366R datasheet. You can program the INDEX pin to trigger a store of the counter (CNTR) value to the OTR register. If you can create a signal from the ESP32 to regularly store the counter e.g. using a timer/PWM, you have the entire interval to read the value from the LS7366R. You can use a software flag from the timer interrupt service routine to tell the main loop that a new value has been stored. You have ~19ms to read the value.
https://lsicsi.com/datasheets/LS7366R.pdf
In the LS7366R datasheet look at:
  • page 2 INDEX (pin10) description
  • page 3 OTR description
  • page 4 MDR0 B5 B4 = 11
Hi Klaus,
Ohhh, I see what you mean. Never thought of using the chip it self to store the value!! it is really a brand new way for me to use this chip.
So if I understand the operation correctly: program the chips for OTR -> create a 20ms pulse by timer interrupt and let it go through Index pin -> LS7366R will store current value to OTR -> Check the timer interrupt flag -> if yes, read the OTR value and clear the register by SPI in the main loop.
Thanks a lot for this inspiration.
Bests,
G
Hi Idahowalker,
Thanks a lot for the solution. Yah I saw a lot of comments to say use the RTOS with ESP32 for multitasking when I did the search. Since I'm not familiar with the RTOS, I decided not to use this method. Right now, seems like it cannot be bypassed. I 'll do more research on the RTOS.
So could you give me some suggestions about how to apply the RTOS in my application? Sorry for this silly question but right now I have no idea about how RTOS work, just want to get some basic idea about it.
Thanks a lot, I'm very appreciated.
G
Like a state machine of doing small chunk of a processes or task then switch to another task to make it look like multiple things are going on at the same time. Also, their is room or a place for that task that happens on an ad hoc basis.
Here is a link to the documentation, freeRTOS.
Because the ESP32 has 2 cores 2 things at the same time is possible, when not using WiFi. If using WiFi, Wifi runs on core0 and programs will run on Core1.
Another piece of documentation that is very very useful when using the ESP32 is the ESP32 API.
Here is an illustration of running 2 things at the same time with an ESP32:
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"#include <driver/adc.h>
const int evtTakeA_Reading =  ( 1 << 10 ); // 10 event handle
EventGroupHandle_t eg; // create event group
QueueHandle_t xQ_Display;
int dispValueCellCount = 128;
  pinMode( 2, OUTPUT );
  xQ_Display = xQueueCreate( dispValueCellCount, sizeof(int) ); // sends a queue copy
  // set up A:D channels
  adc1_config_width(ADC_WIDTH_12Bit); // set 12 bit
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11); // use 3.3V as reference
  eg = xEventGroupCreate(); // assign event groups a handle
  // create a task, assign task a function name, a name, some stack space, no parameters, priority of 3, do not return a task handle, assign to core 0
  xTaskCreatePinnedToCore( fBlinkBuiltIn, "fBlinkBuiltIn", 5000, NULL, 3, NULL, 0 );
  xTaskCreatePinnedToCore( TaskAnalogRead_MyoWare, "TaskAnalogRead_MyoWare", 10, NULL, 3, NULL, 1 ); // assigned to core 1
void fBlinkBuiltIn( void* pvParameters )
  // toggle built in LED off/on
  for (;;)
    vTaskDelay( 10 ); //delay for 10 mS
    xEventGroupSetBits( eg, evtTakeA_Reading ); // trigger task event
    REG_WRITE( GPIO_OUT_W1TC_REG, BIT2 ); // set GPIO2 LOW (clear)
    vTaskDelay( 1000 ); //delay for 1000mS.
    REG_WRITE( GPIO_OUT_W1TS_REG, BIT2 ); //set GPIO2 HIGH (set)
  vTaskDelete( NULL ); // incase task jumpe loop destroy task
void TaskAnalogRead_MyoWare( void *pvParameters )
  float vMyoWare0 = 0.0f;
  int temp;
  float ADscale = 3.3f / 4096;
  // https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  int j = 0;
  for (;;)
    xEventGroupWaitBits (eg, evtTakeA_Reading, pdTRUE, pdTRUE, portMAX_DELAY) ; // wait till task is triggered by an event
    if ( j <= dispValueCellCount )
      for ( j = 1; j <= dispValueCellCount; j++)
        vMyoWare0 = ( adc1_get_raw(ADC1_CHANNEL_0) * ADscale ); // read AD
        vMyoWare0 *= 10.0f;
        temp = (int)vMyoWare0;
        //xQueueSendToBack( xQ_Display, &temp, 0 );
        vTaskDelay(1);
      j++;
      log_i( "j number is %d", j );
      vTaskDelay( 1 );
      vMyoWare0 *= 10.0f;
      xQueueSendToBack( xQ_Display, &temp, 1 );
    //xEventGroupSetBits( eg, evtUPDATE_DISPLAY ); << not used in this exercise
} //void TaskAnalogVoltRead_MyoWare( void *pvParameters )
void loop() {}
Right off the bat, notice loop() is empty. Under freeRTOS loop(), for proper operation, needs to remain empty.
look the code over, notice how each task is loaded into a separate core? You'll have to do some research.
The next program uses WiFi, so its coded to use a single core:
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
WiFiClient   wifiClient; // do the WiFi instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  configInitCamera();
  xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 20000, NULL, 3, NULL, 1 );
} // void setup()
  for (;;)
    log_i( "tick");
      if (!fb)
          ftp.ChangeWorkDir( ftp_path ); //need to check to see if this works, tested change to pi and change to ftp.
          //log_i( "length %d", fb->len );
          //void WriteData (unsigned char * data, int dataLength); //Convert image to unsigned character data format for sending FTP
          ftp.CloseFile();
      connectToWiFi();
void configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // Select lower framesize if the camera doesn't support PSRAM
//  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10; //0-63 lower number means higher quality
    config.fb_count = 2;
//  } else {
//    config.frame_size = FRAMESIZE_SVGA;
//    config.jpeg_quality = 12;
//    config.fb_count = 1;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error 0x%x", err);
    return;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void loop() {}
The task takes a picture, every 15 seconds, and FTP's the image to a web site for display.
And keep on asking questions.
Oh here is a multi-tasked program:
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include <SimpleKalmanFilter.h>
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time       rtc;
#define evtDoParticleRead  ( 1 << 0 ) // declare an event
#define evtADCreading      ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
struct stu_message
  char payload [150] = {'\0'};
  String topic;
} x_message;
int    mqttOK = 0;
bool   TimeSet = false;
bool   manualPumpOn = false;
// interrupt service routine for WiFi events put into IRAM
  switch (event) {
    default: break;
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', 150 );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  x_message.topic.reserve(150);
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
  xQ_RM = xQueueCreate( 1, sizeof(float) );
  eg = xEventGroupCreate(); // get an event group handle
  sema_mqttOK =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  io_cfg = {}; //set configuration structure back to default values
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_4 | (1ULL << GPIO_NUM_5) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
  gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
  // set up A:D channels  https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
void fReadAD( void * parameter )
  float    ADbits = 4096.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //plant in yellow pot
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  float    WetValue = 1.07f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f;
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    xEventGroupWaitBits (eg, evtADCreading, pdTRUE, pdTRUE, portMAX_DELAY ); //
    adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
    adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
    //log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
void fPublish( void * parameter )
  for (;;)
    if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
  } // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
  gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
void WaterPump0_on()
  gpio_set_level( GPIO_NUM_5, HIGH); //energize/open valve
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 12;
  const TickType_t xFrequency = 5000; //delay for mS
  for (;;)
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  const TickType_t xFrequency = 10; //delay for 10mS
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  bool     pumpOn = false;
  uint64_t PumpOnTime = esp_timer_get_time();
  int      PumpRunTime = 11000000;
  uint64_t PumpOffWait = esp_timer_get_time();
  uint64_t PumpOffWaitFor = 60000000; //one minute
  float    lowMoisture = 23.0f;
  float    highMoisture = 40.0f;
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      xEventGroupSetBits( eg, evtADCreading );
    xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( RemainingMoisture >= highMoisture )
      WaterPump0_off();
    if ( !pumpOn )
      log_i( "not pump on ");
      if ( gpio_get_level( GPIO_NUM_0 ) )
        if ( RemainingMoisture <= lowMoisture )
          //has one minute passed since last pump energize, if so then allow motor to run
          if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
            WaterPump0_on();
            log_i( "pump on " );
            pumpOn = !pumpOn;
        //xSemaphoreGive( sema_RemainingMoisture );
        log_i( "water level bad " );
        WaterPump0_off();
         pump goes on runs for 5 seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
      if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
        log_i( "pump off " );
        WaterPump0_off(); // after 5 seconds turn pump off
        pumpOn = !pumpOn;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
      TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; // 250mS
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  int count = 0;
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]);
  log_i( "connect to mqtt as client %s", clientID );
    MQTTclient.disconnect();
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
    count++;
    if ( count == 5 )
      ESP.restart();
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
  int TryCount = 0;
    TryCount++;
    WiFi.disconnect();
    vTaskDelay( 4000 );
      ESP.restart();
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      if ( px_message.topic == topicOK )
        mqttOK = 0; // clear mqtt ok count
      if ( !TimeSet )
        String temp = "";
        temp = px_message.payload[0];
        temp += px_message.payload[1];
        temp += px_message.payload[2];
        temp += px_message.payload[3];
        int year =  temp.toInt();
        temp = "";
        temp = px_message.payload[5];
        temp += px_message.payload[6];
        int month =  temp.toInt();
        temp = "";
        temp = px_message.payload[8];
        temp += px_message.payload[9];
        int day =  temp.toInt();
        temp = "";
        temp = px_message.payload[11];
        temp += px_message.payload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = px_message.payload[14];
        temp += px_message.payload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s  ", rtc.getTime() );
        TimeSet = true;
      //manual pump control
      //    if ( str_eTopic == topicPumpState )
      //      if ( String(strPayload) == "off" )
      //        WaterPump0_off();
      //        manualPumpOn = false;
      //      if ( String(strPayload) == "on" )
      //        WaterPump0_on();
      //        manualPumpOn = true;
      //xSemaphoreGive( sema_MQTT_Parser );
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
Wow, that's amazing! Thanks so much for the information. I defiantly will check the information you passed to me and also the freeRTOS. I'll update the project to you guys with RTOS, but I doubt it will take few days or weeks to get there from LED blink Lol...
Thanks so much for the help, very appreciated !!!
Bests,
G
