Hello, I am using an esp32 as a webserver. I have stored the html code in a string in main.cpp and that has worked but now i want to store the html code in a separate file and store in the spiffs file system.
I created a directory called "data" and stored my index.html file there. In my main.cpp file i create the spiffs file system and also have a partition in flash called "spiffs" I am not having any luck getting this to work.
The error I am getting is: "src/main.cpp: In lambda function:
src/main.cpp:66:41: error: request for member 'html' in 'index', which is of non-class type 'char*(const char*, int)'
server.send(200, "text/html", index.html);
Looking at the server.send function prototypes they all seem to be looking for a string type or char pointer and not a file so i don't know if I can even do this.
Here is the code
#include <Arduino.h>
#include <WiFi.h>
#include <WebServer.h>
#include <FS.h>
#include <SPIFFS.h>
// SSID and password of Wifi connection:
const char *ssid = "SSID";
const char *password = "PASSWORD";
// String webpage = "<!DOCTYPE html>..." html stored in String
// Initialization of webserver and websocket
WebServer server(80); // the server uses port 80 (standard port for websites
Serial.begin(115200); // init serial port for debugging
WiFi.begin("SSID", "PASSWORD"); // start WiFi interface
while (WiFi.status() != WL_CONNECTED)
{ // wait until WiFi is connected
Serial.print(".");
Serial.print("Connected to network with IP address: ");
Serial.println(WiFi.localIP()); // show IP address that the ESP32 has received from router
if (!SPIFFS.begin(true))
Serial.println("An Error has occurred while mounting SPIFFS");
return;
void send(int code, const char* content_type = NULL, const String& content = String(""));
void send(int code, char* content_type, const String& content);
void send(int code, const String& content_type, const String& content);
void send(int code, const char* content_type, const char* content);
server.on("/", []() { // define here wat the webserver needs to do
server.send(200, "text/html", index.html); // -> it needs to send out the HTML string "webpage" to the client, // server.send(200, "text/html", webpage); // -> this works
server.begin(); // start server
server.handleClient(); // Needed for the webserver to handle all clients
