ESP32 HSPI and VSPI Conflict
Good Morning,
I am new to ESP32S3 I am currently trying to get my board which has an integrated LCD to use both HSPI and VSPI.
The issue I am having is that when I am using one or the other I am able to get no issues. But when I try to use both HSPI and VSPI simultaneously I am having issues with the LCD display (The display shows up with static...).
My question is what could be causing this issue?
The code is as follows
#include "Display_ST7789.h"
#include "LVGL_Driver.h"
//#include "RGB_lamp.h"
#include "ui.h"
#include <SPI.h>
// Hardware Configuration
#define ADF_SCLK   14  // HSPI SCK (MUST be 14)
#define ADF_MOSI   13  // HSPI MOSI (MUST be 13)
#define ADF_MISO   12  // HSPI MISO (optional)
#define ADF_CS     15  // HSPI CS (recommended)
#define ADF_LE     3   // Latch Enable
#define ADF_CE     1   // Chip Enable
#define ADF_LD     5   // Lock Detect
SPIClass adf_spi(HSPI);  // Dedicated HSPI instance
// ADF4351 Register Values
const uint32_t ADF4351_Registers[6] = {
  0x00400000,  // Register 0
  0x8008011,   // Register 1
  0x004E42,    // Register 2
  0x0004B3,    // Register 3
  0x0DC80FC,   // Register 4
  0x0580005    // Register 5
  while (!Serial);
  // Initialize LCD (uses VSPI)
  LCD_Init();
  delay(100);
  Set_Backlight(90);
  // PROPER ADF4351 INITIALIZATION
  Serial.println("Initializing ADF4351 HSPI");
  // Initialize control pins
  pinMode(ADF_LE, OUTPUT);
  pinMode(ADF_CE, OUTPUT);
  digitalWrite(ADF_LE, HIGH);
  digitalWrite(ADF_CE, LOW);  // Enable chip
  // Initialize HSPI with CORRECT pins
  Serial.println("HSPI Pins:");
  Serial.printf("SCK: %d, MOSI: %d, CS: %d\n", ADF_SCLK, ADF_MOSI, ADF_CS);
  adf_spi.begin(ADF_SCLK, ADF_MISO, ADF_MOSI, ADF_CS);
  pinMode(ADF_CS, OUTPUT);
  digitalWrite(ADF_CS, HIGH);  // Start with CS high
  // Test SPI communication
  Serial.println("Testing SPI...");
  uint8_t test_byte = 0;
  adf_spi.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
  digitalWrite(ADF_CS, LOW);
  test_byte = adf_spi.transfer(0x55);  // Test pattern
  adf_spi.endTransaction();
  Serial.printf("SPI test returned: 0x%02X\n", test_byte);
  writeAllRegisters(); // Program ADF4351
  Serial.println("System Initialized");
//  Register Writing Functions
void writeRegister(uint32_t value) {
  Serial.printf("Writing: 0x%08X\n", value);
  uint8_t bytes[4] = {
    (uint8_t)(value >> 24),
    (uint8_t)(value >> 16),
    (uint8_t)(value >> 8),
    (uint8_t)(value & 0xFF)
  // Use adf_spi instance (not global SPI)
  for (int i = 0; i < 4; i++) {
    adf_spi.transfer(bytes[i]);
    Serial.printf("  Byte %d: 0x%02X\n", i, bytes[i]);
    delayMicroseconds(5);  // Small delay between bytes
  // Latch data
  digitalWrite(ADF_LE, LOW);
  delayMicroseconds(1);
  Serial.println("  Latched");
void writeAllRegisters() {
  Serial.println("\nProgramming ADF4351:");
  for (int i = 5; i >= 0; i--) {
    writeRegister(ADF4351_Registers[i]);
    delay(10);
  Serial.println("Programming Complete");
Display_ST7789.cpp
SPIClass LCDspi(FSPI);
#define SPI_WRITE(_dat)         LCDspi.transfer(_dat)
#define SPI_WRITE_Word(_dat)    LCDspi.transfer16(_dat)
void SPI_Init()
  LCDspi.begin(EXAMPLE_PIN_NUM_SCLK,EXAMPLE_PIN_NUM_MISO,EXAMPLE_PIN_NUM_MOSI);
void LCD_WriteCommand(uint8_t Cmd)
  LCDspi.beginTransaction(SPISettings(SPIFreq, MSBFIRST, SPI_MODE0));
  digitalWrite(EXAMPLE_PIN_NUM_LCD_CS, LOW);
  digitalWrite(EXAMPLE_PIN_NUM_LCD_DC, LOW);
  SPI_WRITE(Cmd);
  digitalWrite(EXAMPLE_PIN_NUM_LCD_CS, HIGH);
  LCDspi.endTransaction();
void LCD_WriteData(uint8_t Data)
  digitalWrite(EXAMPLE_PIN_NUM_LCD_DC, HIGH);
  SPI_WRITE(Data);
void LCD_WriteData_Word(uint16_t Data)
  SPI_WRITE_Word(Data);
void LCD_WriteData_nbyte(uint8_t* SetData,uint8_t* ReadData,uint32_t Size)
  LCDspi.transferBytes(SetData, ReadData, Size);
void LCD_Reset(void)
  delay(50);
  digitalWrite(EXAMPLE_PIN_NUM_LCD_RST, LOW);
  delay(50);
  digitalWrite(EXAMPLE_PIN_NUM_LCD_RST, HIGH);
  delay(50);
void LCD_Init(void)
  pinMode(EXAMPLE_PIN_NUM_LCD_CS, OUTPUT);
  pinMode(EXAMPLE_PIN_NUM_LCD_DC, OUTPUT);
  pinMode(EXAMPLE_PIN_NUM_LCD_RST, OUTPUT);
  Backlight_Init();
  SPI_Init();
  LCD_Reset();
  //************* Start Initial Sequence **********//
  LCD_WriteCommand(0x11);
  delay(120);
  LCD_WriteCommand(0x36);
  if (HORIZONTAL)
      LCD_WriteData(0x00);
      LCD_WriteData(0x70);
  LCD_WriteCommand(0x3A);
  LCD_WriteData(0x05);
  LCD_WriteCommand(0xB0);
  LCD_WriteData(0xE8);
  LCD_WriteCommand(0xB2);
  LCD_WriteData(0x0C);
  LCD_WriteData(0x33);
  LCD_WriteCommand(0xB7);
  LCD_WriteData(0x35);
  LCD_WriteCommand(0xBB);
  LCD_WriteCommand(0xC0);
  LCD_WriteData(0x2C);
  LCD_WriteCommand(0xC2);
  LCD_WriteData(0x01);
  LCD_WriteCommand(0xC3);
  LCD_WriteData(0x13);
  LCD_WriteCommand(0xC4);
  LCD_WriteData(0x20);
  LCD_WriteCommand(0xC6);
  LCD_WriteData(0x0F);
  LCD_WriteCommand(0xD0);
  LCD_WriteData(0xA4);
  LCD_WriteData(0xA1);
  LCD_WriteCommand(0xD6);
  LCD_WriteCommand(0xE0);
  LCD_WriteData(0xF0);
  LCD_WriteData(0x04);
  LCD_WriteData(0x29);
  LCD_WriteData(0x3E);
  LCD_WriteData(0x38);
  LCD_WriteData(0x12);
  LCD_WriteData(0x28);
  LCD_WriteData(0x30);
  LCD_WriteCommand(0xE1);
  LCD_WriteData(0x07);
  LCD_WriteData(0x0A);
  LCD_WriteData(0x0D);
  LCD_WriteData(0x0B);
  LCD_WriteData(0x36);
  LCD_WriteData(0x14);
  LCD_WriteData(0x32);
  LCD_WriteCommand(0x21);
  delay(120);
  LCD_WriteCommand(0x29);
function: Set the cursor position
parameter :
    Xstart:   Start uint16_t x coordinate
    Ystart:   Start uint16_t y coordinate
    Xend  :   End uint16_t coordinates
    Yend  :   End uint16_t coordinatesen
void LCD_SetCursor(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t  Yend)
  if (HORIZONTAL) {
    // set the X coordinates
    LCD_WriteCommand(0x2A);
    LCD_WriteData(Xstart >> 8);
    LCD_WriteData(Xstart + Offset_X);
    LCD_WriteData(Xend >> 8);
    LCD_WriteData(Xend + Offset_X);
    // set the Y coordinates
    LCD_WriteCommand(0x2B);
    LCD_WriteData(Ystart >> 8);
    LCD_WriteData(Ystart + Offset_Y);
    LCD_WriteData(Yend >> 8);
    LCD_WriteData(Yend + Offset_Y);
  else {
  LCD_WriteCommand(0x2C);
function: Refresh the image in an area
parameter :
    color :   Set the color
void LCD_addWindow(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend,uint16_t* color)
  uint16_t Show_Width = Xend - Xstart + 1;
  uint16_t Show_Height = Yend - Ystart + 1;
  uint32_t numBytes = Show_Width * Show_Height * sizeof(uint16_t);
  uint8_t Read_D[numBytes];
  LCD_SetCursor(Xstart, Ystart, Xend, Yend);
  LCD_WriteData_nbyte((uint8_t*)color, Read_D, numBytes);
// backlight
void Backlight_Init(void)
  ledcAttach(EXAMPLE_PIN_NUM_BK_LIGHT, Frequency, Resolution);
  ledcWrite(EXAMPLE_PIN_NUM_BK_LIGHT, 100);
void Set_Backlight(uint8_t Light)                        //
  if(Light > 100 || Light < 0)
    printf("Set Backlight parameters in the range of 0 to 100 \r\n");
  else{
    uint32_t Backlight = Light*10;
    ledcWrite(EXAMPLE_PIN_NUM_BK_LIGHT, Backlight);
Display_ST7789.h
#pragma once
#include <Arduino.h>
#include <SPI.h>
#define LCD_WIDTH   172 //LCD width
#define LCD_HEIGHT  320 //LCD height
#define SPIFreq                        10000000
#define EXAMPLE_PIN_NUM_MISO           -1
#define EXAMPLE_PIN_NUM_MOSI           45
#define EXAMPLE_PIN_NUM_SCLK           40
#define EXAMPLE_PIN_NUM_LCD_CS         42
#define EXAMPLE_PIN_NUM_LCD_DC         41
#define EXAMPLE_PIN_NUM_LCD_RST        39
#define EXAMPLE_PIN_NUM_BK_LIGHT       48
#define Frequency       1000                    // PWM frequencyconst
#define Resolution      10
#define VERTICAL   0
#define HORIZONTAL 1
#define Offset_X 34
#define Offset_Y 0
void LCD_SetCursor(uint16_t x1, uint16_t y1, uint16_t x2,uint16_t y2);
void LCD_Init(void);
void LCD_SetCursor(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t  Yend);
void LCD_addWindow(uint16_t Xstart, uint16_t Ystart, uint16_t Xend, uint16_t Yend,uint16_t* color);
void Backlight_Init(void);
void Set_Backlight(uint8_t Light);
Any help regarding this would be greatly appreciated
