ESP32 HTTP status code 404 for some reason
Hi there, I'm having a project that can send data from ESP32 to google sheets but I have an issue right here that is the HTTP status code is 404 and I don't know why that happened.
Here's a picture of the error on the Serial Monitor:
and here's the code:
#include <WiFi.h>
#include <HTTPClient.h>
const char * ssid = "Wifi name";
const char * password = "Wifi pass";
String GOOGLE_SCRIPT_ID = "AKfycbw4rA_eBkHPMkgRX4mLH2lscyZLGDVA21HpFngqFEc";
unsigned long Time;
String param = "";
#define RXD2 16
#define TXD2 17
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  Time = millis();
  WiFi.mode(WIFI_STA);
  Serial.print("Connecting to WiFi");
  WiFi.begin(ssid, password);
  Serial.println(ssid);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("CONNECTED !!!");
  if ((unsigned long)millis() - Time > 1000)
    print_speed();
    Time = millis();
void print_speed()
  if (Serial2.available())
    param  = "forceData=" + Serial2.readString() ;
    Serial.println(param);
    write_to_google_sheet(param);
    Serial.println("No data !!!");
void write_to_google_sheet(String params)
  HTTPClient http;
  String url = "https://script.google.com/macros/s/" + GOOGLE_SCRIPT_ID + "/exec?" + params;
  //Serial.print(url);
  Serial.println("Data sent to Google Sheets");
  //starts posting data to google sheet
  http.begin(url.c_str());
  http.setFollowRedirects(HTTPC_STRICT_FOLLOW_REDIRECTS);
  int httpCode = http.GET();
  Serial.print("HTTP Status Code: ");
  Serial.println(httpCode);
  //getting response from google sheet
  String payload;
  if (httpCode > 0) {
    payload = http.getString();
    Serial.println("Payload: " + payload);
  http.end();
Could it be that you are not connected to your WiFi when you try to send the data?
well the connection was completely normal
i tested everything but still, it still has the 404 code
but one thing is that I use arduino UART to send data from the arduino to the esp32 and then the esp32 sends that data to the google sheet. The funny thing is that when I disconnect the arduino, the esp32 can send something to the google sheet, and the HTTP status code is 200
Is your program that you posted running on the ESP32?
yes it is
and here's the code of the Arduino, it sends the MPU6050 values to the ESP32, then the ESP32 sends this data to the google sheet
#include <MPU6050.h>
MPU6050 mpu;
#define EXPIRED                    true
#define stillTIMING                false
#define LEDon                      HIGH
#define LEDoff                     LOW
#define PUSHED                     HIGH
#define RELEASED                   LOW
#define CLOSED                     LOW
#define OPEN                       HIGH
#define ENABLED                    true
#define DISABLED                   false
#define YES                        true
#define NO                         false
const float thresholdForce = 5.0;
const unsigned long resetInterval = 500;
static float peakForce = 0, lastPeakForce = 0;
static unsigned long lastPeakMs = 0;
//const int arraySize = 200; //array size
//float dataArray[arraySize]; // array for storing values
//byte currentIndex = 0; // current index of the array
struct makeTIMER
  unsigned long Time;           //when the TIMER started
  unsigned long Interval;       //delay time in ms which we are looking for
  bool          timerFlag;      //is the TIMER enabled ? ENABLED/DISABLED
  bool          Restart;        //restart this TIMER ? YES/NO
  //fuction to check if the TIMER is enabled and check if the TIMER has expired
  bool checkTIMER()
    //is this TIMER enabled and has this TIMER expired ?
    if (timerFlag == ENABLED && millis() - Time >= Interval)
      //should this TIMER restart again?
      if (Restart == YES)
        Time = millis();
      //this TIMER is enabled and has expired
      return EXPIRED;
    //this TIMER is disabled and/or has not expired
    return stillTIMING;
  } //END of   checkTime()
}; //END of   struct makeTIMER
makeTIMER forceChecker =
  0, 500ul, ENABLED, NO      //Time, Interval, timerFlag, Restart
makeTIMER delayValue =
  0, 25ul, ENABLED, NO      //Time, Interval, timerFlag, Restart
  //Serial.begin(115200);
  Wire.begin();
  mpu.initialize();
  //measure range of mpu6050(±16g)
  mpu.setFullScaleAccelRange(3);
void loop(){
  int16_t ax, ay, az;
  mpu.getAcceleration(&ax, &ay, &az);
  static float smoothForce = 0;
  float gForceX = (float(ax) / 32768.0) * 16.0;
  float gForceY = (float(ay) / 32768.0) * 16.0;
  float gForceZ = (float(az) / 32768.0) * 16.0;
  float accelX = gForceX;
  float accelY = gForceY;
  float accelZ = gForceZ;
  float accelTotal = (sqrt(pow(accelX, 2) + pow(accelY, 2) + pow(accelZ, 2))*9.81) - 9.81;
  smoothForce += 0.01 * (accelTotal - smoothForce);
  float myForce = smoothForce;  // smoothed accelTotal;
  if (myForce > thresholdForce && myForce > peakForce){
    peakForce = myForce;
    lastPeakForce = peakForce;
    lastPeakMs = millis();
    forceChecker.Time = millis();
  if(forceChecker.checkTIMER() && peakForce > 0){
    peakForce = 0;
    Serial.println(lastPeakForce); //sends this to the ESP32
I see. Could you print the URL the ESP32 tries to connect to, too, when it does gets 404?
Just the URL?
This one right?
oh and one more thing is that every time I want to upload the code to the esp32, I have to hold the boot button on the esp32, don't know if that will affect the code
here it is, and when I copied this and pasted it into my search bar, things were still normal
here's a pic of it
Now that's odd. 404 comes from the server, so you have a connection and the URL looks sane. Can you fire up wireshark and look at the traffic? Maybe the URL is not that sane as it looks...
I'm going to do it right now
Is this a program that I have to download?
well I downloaded it, so what should I do now
well I don't know what to say about this but the traffic looks kinda... unstable
I tried another code but it still not working
I'm having a feeling about the boot mode, like every time I try to upload the code, I have to hold the boot button
