I'm new to this community, though it doesn't feel like it, been visiting this forum for years.
It is a new account though.
I'm having an infuriating problem that I've been struggling with for 3 days.
The idea: Create an OTA method of uploading a new firmware bin, all over secure connections
I already have a WSS client up and running.
So I thought I'd try giving that a go first.
After almost a day of trail and error(cuz there absolutely no support out of the box for that), I gave up on that due to the fact that I cannot find a way to stream the data coming in effectively.
(The program is at 1.3mb compiled and I still have a ways to go, so a LARGE APP).
Theoretically it should be possible by fragmenting the incoming binary data (frames) and then
Update.write()
Presuming MD5 has been set.
I couldn't make that work.
So I attempted an HTTPS GET from the WSS servers' webserver.
This is where I am now...
Status: It uploads and then the stream stops at 1024000 bytes received.
Problem: The stream given by HTTPSClient.getStream();
limits the received binary data to 1mb.
The code is almost 3000 lines long, so I won't attempt to upload it.
I will create an sketch here with the relevant data.
If something obvious is wrong, like a varbiable being used before it's declared it's just a copy paste error, the program works
My problem is the stream limit please advise on that and not silly stuff
Note: that the sketch here is just an exerp and hasn't been compiled or tested
#include <WiFi.h>
#include <HTTPClient.h>
#include <WiFiClientSecure.h>
#include <Update.h>
if (Update.hasError()) {
Update.printError(Serial);
Update.clearError();
//upgradeOTA is just a global bool to block other events that could interrupt the flashing
//Also set to true in WSS task to start the flashing
if (upgradeOTA) {
HTTPClient https;
https.setTimeout(5000);
// DEBUG
Serial.print("Target URL: ");
Serial.println(target_uri); //SET BY WSS
Serial.print("FileSize: ");
Serial.println(upgradeOTA_fileSize); //SET BY WSS
Serial.print("Given MD5 HASH: ");
Serial.println(upgradeOTA_MD5); //SET BY WSS
Serial.print("");
Serial.println("");
// END DEBUG
https.begin(target_uri,wss_cacert); //wss_cacert loaded out of eeprom
Serial.println(" HTTPs Connection Successfull");
int httpResponseCode = https.GET();
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
Update.onProgress([](unsigned int progress, unsigned int total) {
//Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
Serial.printf("Uploaded: %u%%\r", (progress));
if (Update.isFinished()) { //I assume finished when the specified length is reached
if (Update.end(true)) {
Serial.printf("Update Success: %u\nRebooting...\n");
ESP.restart();
} else { }
Serial.println("Upload Finished");
Update.setMD5((char*)upgradeOTA_MD5); //upgradeOTA_MD5 SET BY WSS (char[32])
if (!Update.begin(upgradeOTA_fileSize)) { //upgradeOTA_fileSize SET BY WSS (size_t)
} else upgradeOTA = false;
//HERE IS WHERE THE STREAM THAT LIMITS UPLOAD TO 1MB IS RETURNED
if (Update.writeStream(https.getStream())) {
else {
Serial.print("Error code: ");
upgradeOTA = false;
I've run through every library's code and I can't find any solution
So my question: Is this a limitation by the client stream like I suspect or might it be somewhere else like on the webserver side?
And: How, if possible, do I set the stream limit for a HTTP GET request.
If you think I should go back to trying to do this in WSS please provide a working snippet of a firmware flash that is LARGE(like at least 1.5mb capable)
PS: It uploads perfectly and gives Serial feedback all the way up to 1024000bytes received then stops and after the timeout expires it gives a serial error saying
"Stream Read Timeout"
Thank You for reading my 'assay' and for the help provided.
