ESP32 - https Get with timestamp and some met. data with unofficel ssl certificate
i try to post some messured data (BME280 data and wind data) from an ESP32 to my server/mysql DB. The following code is working in the browser:
(https://my.domain.com/getdata-gc1.php?location_id=1&writepwd=xxxx&timestamp=2023-03-29%2019:52:23&temperature=30&humidity=14&pressure=1005.21&WindSpeedAvgMS=13&WindSpeedMinMS=12&WindSpeedMaxMS=16&windDirectionDegrees=20&windDirectionText=NNO)
My Arduino-Code to post is this:
#include <ArduinoJson.h>
#include <WebServer.h>
#include <TaskScheduler.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <WiFiClientSecure.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <time.h>
const char* host = "https://my.domain.com";
const int Port = 443;
// SSL certificate of the website
const char* certificate = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIFxzCCA6+gAwIBAgIUEu+oOFvUEoN1aaDtIW/KXIfqa3cwDQYJKoZIhvcNAQEL\n" \
and so one...
"xPATYnW+vRCH/BglQFRsnaNmDrXbziR9aU1MD08dY9gXQCTBWOEeybCa6w==\n" \
"-----END CERTIFICATE-----\n";
void sendData() {
  // Get the current timestamp
  // const char* location_id = LOCATIONID;
  // const char* write_pwd = WRITEPWD;
  time_t now;
  struct tm timeinfo;
  char buffer[20];
  time(&now);
  localtime_r(&now, &timeinfo);
  strftime(buffer, sizeof(buffer), "%Y-%m-%d %H:%M:%S", &timeinfo);
  String timestamp = buffer;
  // Send the data to the PHP script
 WiFiClientSecure client;
  client.setCACert(certificate);
  if (!client.connect(host, Port)) {
	Serial.print("Connection failed!");
    return;
  String url = "getdata-gc1.php?location_id="
      + LOCATIONID
      + "&writepwd=" + WRITEPWD
      + "&timestamp=" + String(timestamp)
      + "&temperature=" + String(bmeTemp)
      + "&humidity=" + String(bmeHum)
      + "&Pressure=" + String(bmePress)
      + "&WindSpeedAvgMS=" + String(minuteWindSpeedAvgMS)
      + "&WindSpeedMinMS=" + String(minuteWindSpeedMinMS)
      + "&WindSpeedMaxMS=" + String(minuteWindSpeedMaxMS)
      + "&windDirectionDegrees=" + String(directionMostCalculated)
      + "&windDirectionText=" + String(getWindDirectionDescriptionFromDegree(directionMostCalculated));
  client.print(String("GET ")
  		+ url + " HTTP/1.1\r\n"
     	+ "Host: " + host + "\r\n"
			+ "Connection: close\r\n\r\n");
  // Wait for the response
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
  // Print the response
  String response = client.readString();
  Serial.println(response);
  // Wait for 10 seconds before sending the next data
  delay(10000);
its not possible to get a ssl connection... the certificate i made on my server and in the browser it is mentioned that its no a valid certificate of an official authority - sure.... but i was thinking if i integrate it here in the code is used to encrypt the data transfer and thats the only need....
I also tried the above code without SSL encryption... and its was also not working... i think due to the "Space" in the timestamp... but when i try to substitute i with "%20" it was also ot working... maybe someone has done something like this already and has some hints...
nobody here who has an idea ???
