ESP32 I2C sniffer issue
Hi guys, I am a beginner I would like to ask someone more experienced for help why I lI am loosing the part of the data. I have my project which is a Bluetooth remote controller for an automatic antenna tuner for HF transciever. As a part of the project I am trying to catch the data which the tuner sends via I2C to an OLED (0.91") display.
The goal is to catch the data and send them via bluetooth to from the slave ESP32 board to the master ESP32 boards. Everything works well regarding the circular buffers on both sides and the transfer via BT. Also the sinffer used on the slave boards seemed to work well but then I found that I am loosing some data. I bought an easy digital analyzer and catched the data from the antenna tuner and then catched the data transfered via BT from slave to master on the display side and I found that alll the data catched by the slave I2C sniffer are transferd and sent to the display but the I found that the sniffer always doesn not catch part of the data from the tuner. It is always the same. I tried to catch the data with only the the ESP32 board and pnly the snoffer sketch (without the buffers and BT etc.) and the result is the same. Missing the same part of data always. A friend of mine told me that it looks like the author of the tuner ignores ACK bits it might be a part of the problem.
The used sniffer:
#include <Wire.h>
  Wire.begin(0x3c);        // join i2c bus (address optional for master)
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(115200);  // start serial for output
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
  while(Wire.available() > 0) // loop through all but the last
    byte c = Wire.read(); // receive byte as a character
    Serial.print(c, 16);         // print the character
    Serial.print(" ");
  Serial.println("");
Here you can see the data comparison. If you check the BLOCK 006 you can see there are missing 14 bytes at the end of the row and then all the data till the BLOCK 11 (it is good to open in e.g. Notepad++):
BLOCK 001
TUNER:		0x00 0xAE 0xD5 0x80 0xA8 0x3F 0xD3 0x01 0x40 0x8D 0x14 0x81 0xB4 0xD9 0x22 0x20 0x02 0x21 0x00 0x7F 0x2E 0xA0 0xC0 0xDA 0x02 0xDB 0x40 0xA4 0xA6
DISPLAY:	0x00 0xAE 0xD5 0x80 0xA8 0x3F 0xD3 0x01 0x40 0x8D 0x14 0x81 0xB4 0xD9 0x22 0x20 0x02 0x21 0x00 0x7F 0x2E 0xA0 0xC0 0xDA 0x02 0xDB 0x40 0xA4 0xA6
BLOCK 002
TUNER:		0x40
DISPLAY:	0x40
BLOCK 003
TUNER:		0x00 0xB0 0x02 0x10
DISPLAY:	0x00 0xB0 0x02 0x10
BLOCK 004
TUNER:		0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
DISPLAY:	0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
BLOCK 005
TUNER:		0x00 0xB1 0x02 0x10
DISPLAY:	0x00 0xB1 0x02 0x10
BLOCK 006
BLOCK 007
TUNER:		0x00 0xB2 0x02 0x10
DISPLAY:
BLOCK 008
DISPLAY:
BLOCK 009
TUNER:		0x00 0xB3 0x02 0x10
DISPLAY:
BLOCK 010
DISPLAY:
BLOCK 011
TUNER:		0x80 0xAF
DISPLAY:	0x80 0xAF
BLOCK 012
TUNER:		0x40
DISPLAY:	0x40
BLOCK 013
TUNER:		0x00 0xB0 0x02 0x12
DISPLAY:	0x00 0xB0 0x02 0x12
BLOCK 014
TUNER:		0x40 0xFC 0x03 0x03 0x03 0xFC 0x00 0x00 0x03 0x03 0xFF 0x03 0x03 0x00 0x00 0xFF 0x00 0x00 0x00 0xFF 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0x00 0x0C 0xFF 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00
DISPLAY:	0x40 0xFC 0x03 0x03 0x03 0xFC 0x00 0x00 0x03 0x03 0xFF 0x03 0x03 0x00 0x00 0xFF 0x00 0x00 0x00 0xFF 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0x00 0x0C 0xFF 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00
BLOCK 015
TUNER:		0x00 0xB1 0x02 0x12
DISPLAY:	0x00 0xB1 0x02 0x12
BLOCK 016
TUNER:		0x40 0x3F 0x03 0x03 0x03 0x3F 0x00 0x00 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x0F 0x30 0x30 0x30 0x0F 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x3F 0x30 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00
DISPLAY:	0x40 0x3F 0x03 0x03 0x03 0x3F 0x00 0x00 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x0F 0x30 0x30 0x30 0x0F 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x3F 0x30 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00
BLOCK 017
TUNER:		0x40
DISPLAY:	0x40
BLOCK 018
TUNER:		0x00 0xB2 0x0B 0x11
DISPLAY:	0x00 0xB2 0x0B 0x11
BLOCK 019
TUNER:		0x40 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0x3C 0xC0 0x00 0xC0 0x3C 0x00 0x00 0x0C 0x0C 0xFC 0x0C 0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xC0 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0x00 0xFC 0x00 0x00
DISPLAY:	0x40 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0x3C 0xC0 0x00 0xC0 0x3C 0x00 0x00 0x0C 0x0C 0xFC 0x0C 0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xC0 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0xC0 0xC0 0x00 0xFC 0x00 0x00
BLOCK 020
TUNER:		0x00 0xB3 0x0B 0x11
DISPLAY:	0x00 0xB3 0x0B 0x11
BLOCK 021
TUNER:		0x40 0xFF 0xC3 0xC3 0xC3 0xC0 0x00 0x00 0xF0 0x0C 0x03 0x0C 0xF0 0x00 0x00 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0xC3 0xC0 0xC0 0x3F 0x00 0x00 0x3F 0xC0 0xC0 0xC0 0x3F 0x00 0x00 0x30 0xCC 0xCC 0xCC 0xFF 0x00 0x00 0xFF 0x03 0x00 0x00 0x03 0x00 0x00 0x3F 0xC0 0xC0 0xC3 0xFF 0x00 0x00
DISPLAY:	0x40 0xFF 0xC3 0xC3 0xC3 0xC0 0x00 0x00 0xF0 0x0C 0x03 0x0C 0xF0 0x00 0x00 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0xC3 0xC0 0xC0 0x3F 0x00 0x00 0x3F 0xC0 0xC0 0xC0 0x3F 0x00 0x00 0x30 0xCC 0xCC 0xCC 0xFF 0x00 0x00 0xFF 0x03 0x00 0x00 0x03 0x00 0x00 0x3F 0xC0 0xC0 0xC3 0xFF 0x00 0x00
BLOCK 022
TUNER:		0x40
DISPLAY:	0x40
BLOCK 023
BLOCK 024
TUNER:		0x40 0xFF 0xC0 0x30 0x30 0xC0 0x00 0x00 0xF0 0x00 0x00 0x00 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x30 0xC0 0x00 0xFF 0x00 0x00 0x03 0x03 0xC3 0x33 0x0F 0x00 0x00 0xFF 0x03 0x03 0x0C 0xF0 0x00 0x00 0xFF 0x03 0x03 0x0C 0xF0 0x00 0x00 0xFC 0x03 0x03 0x03 0x0C 0x00 0x00
DISPLAY:	0x40 0xFF 0xC0 0x30 0x30 0xC0 0x00 0x00 0xF0 0x00 0x00 0x00 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x30 0xC0 0x00 0xFF 0x00 0x00 0x03 0x03 0xC3 0x33 0x0F 0x00 0x00 0xFF 0x03 0x03 0x0C 0xF0 0x00 0x00 0xFF 0x03 0x03 0x0C 0xF0 0x00 0x00 0xFC 0x03 0x03 0x03 0x0C 0x00 0x00
BLOCK 025
BLOCK 026
TUNER:		0x40 0x3F 0x30 0x30 0x30 0x0F 0x00 0x00 0x00 0x33 0x33 0x33 0x0F 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0x00 0x00 0x03 0x3F 0x00 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00 0x3F 0x30 0x30 0x0C 0x03 0x00 0x00 0x3F 0x30 0x30 0x0C 0x03 0x00 0x00 0x0F 0x30 0x30 0x30 0x0C 0x00 0x00
DISPLAY:	0x40 0x3F 0x30 0x30 0x30 0x0F 0x00 0x00 0x00 0x33 0x33 0x33 0x0F 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0x00 0x00 0x03 0x3F 0x00 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00 0x3F 0x30 0x30 0x0C 0x03 0x00 0x00 0x3F 0x30 0x30 0x0C 0x03 0x00 0x00 0x0F 0x30 0x30 0x30 0x0C 0x00 0x00
BLOCK 027
TUNER:		0x40
DISPLAY:	0x40
BLOCK 028
BLOCK 029
TUNER:		0x40 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0xFC 0x00 0x00 0x00 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xC0 0x00 0x00 0x00 0xC0 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xC0 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x0C 0xCC 0x3C 0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x0C 0x0C 0x0C 0xF0 0x00 0x00
DISPLAY:	0x40 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0xFC 0x00 0x00 0x00 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xC0 0x00 0x00 0x00 0xC0 0x00 0x00 0x00 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xC0 0x00 0xC0 0xC0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x0C 0xCC 0x3C 0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x0C 0x0C 0x0C 0xF0 0x00 0x00
BLOCK 030
BLOCK 031
TUNER:		0x40 0xFF 0x03 0x03 0x00 0x00 0x00 0x00 0xFF 0x30 0x0F 0x30 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F 0x30 0xC0 0x30 0x0F 0x00 0x00 0x3F 0xCC 0xCC 0xCC 0x0F 0x00 0x00 0xFF 0x03 0x00 0x00 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0xC0 0xC0 0xC3 0x3C 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0xC0 0xF0 0xCC 0xC3 0xC0 0x00 0x00
DISPLAY:	0x40 0xFF 0x03 0x03 0x00 0x00 0x00 0x00 0xFF 0x30 0x0F 0x30 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F 0x30 0xC0 0x30 0x0F 0x00 0x00 0x3F 0xCC 0xCC 0xCC 0x0F 0x00 0x00 0xFF 0x03 0x00 0x00 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0xC0 0xC0 0xC3 0x3C 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0xC0 0xF0 0xCC 0xC3 0xC0 0x00 0x00
BLOCK 032
TUNER:		0x40
DISPLAY:	0x40
BLOCK 033
BLOCK 034
BLOCK 035
BLOCK 036
BLOCK 037
TUNER:		0x40
DISPLAY:	0x40
BLOCK 038
BLOCK 039
BLOCK 040
BLOCK 041
BLOCK 042
TUNER:		0x40
DISPLAY:	0x40
BLOCK 043
TUNER:		0x00 0xB0 0x06 0x10
DISPLAY:	0x00 0xB0 0x06 0x10
BLOCK 044
TUNER:		0x40 0xFF 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0xFF 0x00 0xC0 0x00 0xFF 0x00 0x00 0xFF 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFF 0x00 0xC0 0x00 0xFF 0x00 0x00
DISPLAY:	0x40 0xFF 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0xFF 0x00 0xC0 0x00 0xFF 0x00 0x00 0xFF 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFF 0x00 0xC0 0x00 0xFF 0x00 0x00
BLOCK 045
TUNER:		0x00 0xB1 0x06 0x10
DISPLAY:	0x00 0xB1 0x06 0x10
BLOCK 046
TUNER:		0x40 0x3F 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00 0x3F 0x00 0x03 0x0C 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00
DISPLAY:	0x40 0x3F 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00 0x3F 0x00 0x03 0x0C 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00
BLOCK 047
TUNER:		0x40
DISPLAY:	0x40
BLOCK 048
TUNER:		0x00 0xB2 0x06 0x10
DISPLAY:	0x00 0xB2 0x06 0x10
BLOCK 049
TUNER:		0x40 0xF0 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0xFC 0x00 0x00 0x00 0xFC 0x00 0x00 0xFC 0x0C 0x0C 0x0C 0xF0 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
DISPLAY:	0x40 0xF0 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0xFC 0x00 0x00 0x00 0xFC 0x00 0x00 0xFC 0x0C 0x0C 0x0C 0xF0 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
BLOCK 050
TUNER:		0x00 0xB3 0x06 0x10
DISPLAY:	0x00 0xB3 0x06 0x10
BLOCK 051
TUNER:		0x40 0xC0 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0xFF 0x30 0x0F 0x30 0xFF 0x00 0x00 0xFF 0x03 0x0F 0x33 0xC0 0x00 0x00 0x0C 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
DISPLAY:	0x40 0xC0 0xC3 0xC3 0xC3 0x3C 0x00 0x00 0xFF 0x30 0x0F 0x30 0xFF 0x00 0x00 0xFF 0x03 0x0F 0x33 0xC0 0x00 0x00 0x0C 0x0C 0x0C 0x0C 0x0C 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
BLOCK 052
TUNER:		0x40
DISPLAY:	0x40
BLOCK 053
TUNER:		0x00 0xB0 0x0E 0x13
DISPLAY:	0x00 0xB0 0x0E 0x13
BLOCK 054
BLOCK 055
TUNER:		0x00 0xB1 0x0E 0x13
DISPLAY:	0x00 0xB1 0x0E 0x13
BLOCK 056
TUNER:		0x40 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00
DISPLAY:	0x40 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00
BLOCK 057
TUNER:		0x40
DISPLAY:	0x40
BLOCK 058
TUNER:		0x00 0xB0 0x05 0x14
DISPLAY:	0x00 0xB0 0x05 0x14 (0x40)
BLOCK 059
TUNER:		0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00
DISPLAY:	0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00 0(0x00)
BLOCK 060
TUNER:		0xB1 0x05 0x14
DISPLAY:	0xB1 0x05 0x14 (0x40)
BLOCK 061
TUNER:		0x3F 0x30 0x30 0x30 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00
DISPLAY:	0x3F 0x30 0x30 0x30 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00
BLOCK 062
TUNER:		0x40
DISPLAY:	0x40
BLOCK 063
TUNER:		0x00 0xB0 0x0F 0x16
DISPLAY:	0x00 0xB0 0x0F 0x16
BLOCK 064
TUNER:		0x40 0xF0 0x00 0x00 0x00 0xF0 0x00 0x00 0xFF 0xC0 0xC0 0xC0 0xFF 0x00 0x00
DISPLAY:	0x40 0xF0 0x00 0x00 0x00 0xF0 0x00 0x00 0xFF 0xC0 0xC0 0xC0 0xFF 0x00 0x00
BLOCK 065
TUNER:		0x00 0xB1 0x0F 0x16
DISPLAY:	0x00 0xB1 0x0F 0x16
BLOCK 066
TUNER:		0x40 0x0F 0x30 0x30 0x0C 0x3F 0x00 0x00 0x3F 0x00 0x00 0x00 0x3F 0x00 0x00
DISPLAY:	0x40 0x0F 0x30 0x30 0x0C 0x3F 0x00 0x00 0x3F 0x00 0x00 0x00 0x3F 0x00 0x00
BLOCK 067
TUNER:		0x40
DISPLAY:	0x40
BLOCK 068
TUNER:		0x00 0xB0 0x03 0x15
DISPLAY:	0x00 0xB0 0x03 0x15
BLOCK 069
TUNER:		0x40 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00
DISPLAY:	0x40 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00
BLOCK 070
TUNER:		0x00 0xB1 0x03 0x15
DISPLAY:	0x00 0xB1 0x03 0x15
BLOCK 071
TUNER:		0x40 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00
DISPLAY:	0x40 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00
BLOCK 072
TUNER:		0x40
DISPLAY:	0x40
BLOCK 073
TUNER:		0x00 0xB2 0x05 0x14
DISPLAY:	0x00 0xB2 0x05 0x14
BLOCK 074
TUNER:		0x40 0xF0 0x0C 0x0C 0x0C 0x30 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00
DISPLAY:	0x40 0xF0 0x0C 0x0C 0x0C 0x30 0x00 0x00 0xC0 0xC0 0xC0 0xC0 0xC0 0x00 0x00
BLOCK 075
TUNER:		0x00 0xB3 0x05 0x14
DISPLAY:	0x00 0xB3 0x05 0x14
BLOCK 076
TUNER:		0x40 0x3F 0xC0 0xC0 0xC0 0x30 0x00 0x00 0x0C 0x0C 0x0C 0x0C 0x0C 0x00 0x00
DISPLAY:	0x40 0x3F 0xC0 0xC0 0xC0 0x30 0x00 0x00 0x0C 0x0C 0x0C 0x0C 0x0C 0x00 0x00
BLOCK 077
TUNER:		0x40
DISPLAY:	0x40
BLOCK 078
TUNER:		0x00 0xB2 0x0F 0x16
DISPLAY:	0x00 0xB2 0x0F 0x16
BLOCK 080
TUNER:		0x40 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00
DISPLAY:	0x40 0xC0 0xC0 0xC0 0xC0 0x00 0x00 0x00 0xFC 0x0C 0x0C 0x0C 0x0C 0x00 0x00
BLOCK 081
TUNER:		0x00 0xB3 0x0F 0x16
DISPLAY:	0x00 0xB3 0x0F 0x16
BLOCK 082
TUNER:		0x40 0xFF 0x0C 0x0C 0x0C 0x03 0x00 0x00 0xFF 0x03 0x03 0x00 0x00 0x00 0x00
DISPLAY:	0x40 0xFF 0x0C 0x0C 0x0C 0x03 0x00 0x00 0xFF 0x03 0x03 0x00 0x00 0x00 0x00
BLOCK 083
TUNER:		0x40
DISPLAY:	0x40
BLOCK 084
TUNER:		0x00 0xB2 0x03 0x15
DISPLAY:	0x00 0xB2 0x03 0x15
BLOCK 085
TUNER:		0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
DISPLAY:	0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
BLOCK 086
TUNER:		0x00 0xB3 0x03 0x15
DISPLAY:	0x00 0xB3 0x03 0x15
BLOCK 087
TUNER:		0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
DISPLAY:	0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
BLOCK 088
TUNER:		0x40
DISPLAY:	0x40
BLOCK 089
BLOCK 090
TUNER:		0x40 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00
DISPLAY:	0x40 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x30 0x30 0x30 0x30 0x00 0x00
BLOCK 091
TUNER:		0x00 0xB1 0x05 0x14
DISPLAY:	0x00 0xB1 0x05 0x14
BLOCK 092
TUNER:		0x40 0x3F 0x30 0x30 0x30 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00
DISPLAY:	0x40 0x3F 0x30 0x30 0x30 0x30 0x00 0x00 0x03 0x03 0x03 0x03 0x03 0x00 0x00
BLOCK 093
TUNER:		0x40
DISPLAY:	0x40
BLOCK 094
BLOCK 095
BLOCK 096
BLOCK 097
BLOCK 098
TUNER:		0x40
DISPLAY:	0x40
BLOCK 099
BLOCK 100
BLOCK 101
BLOCK 102
BLOCK 103
TUNER:		0x40
DISPLAY:	0x40
BLOCK 104
BLOCK 105
BLOCK 106
BLOCK 107
BLOCK 108
TUNER:		0x40
DISPLAY:	0x40
BLOCK 109
BLOCK 110
BLOCK 111
BLOCK 112
BLOCK 113
TUNER:		0x40
DISPLAY:	0x40
BLOCK 114
BLOCK 115
BLOCK 116
BLOCK 117
BLOCK 118
TUNER:		0x40
DISPLAY:	0x40
BLOCK 119
TUNER:		0x00 0xB2 0x02 0x12
DISPLAY:	0x00 0xB2 0x02 0x12
BLOCK 120
TUNER:		0x40 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
DISPLAY:	0x40 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00 0xF0 0x0C 0x0C 0xCC 0xF0 0x00 0x00
BLOCK 121
TUNER:		0x00 0xB3 0x02 0x12
DISPLAY:	0x00 0xB3 0x02 0x12
BLOCK 122
TUNER:		0x40 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
DISPLAY:	0x40 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x00 0x3C 0x3C 0x00 0x00 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00 0x3F 0xCC 0xC3 0xC0 0x3F 0x00 0x00
BLOCK 123
TUNER:		0x40
DISPLAY:	0x40
BLOCK 124
DISPLAY:	0x00 0xB0 0x02 		(x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 x00 0xC0 0x00 0xFF 0x00 0x00 0x00 0xB1 x00 0x00 0x00 0x0F 0x0F 0x00)
BLOCK 125
TUNER:		0x40 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xFC 0x03 0xC3 0x33 0xFC 0x00 0x00 0xFF 0x00 0xC0 0x00 0xFF 0x00 0x00
DISPLAY:
BLOCK 126
DISPLAY:
BLOCK 127
TUNER:		0x40 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x00 0x0F 0x0F 0x00 0x00 0x00 0x00 0x0F 0x33 0x30 0x30 0x0F 0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00
DISPLAY:																										0x00 0x00 0x3F 0x0C 0x03 0x0C 0x3F 0x00 0x00
You got yourself into a whole lot of trouble.
This is the same question as your previous posts and I see no progress. It might never work, but maybe there are other ways.
A moderator might even combine all your posts.
The very first reply about your project is by @srnet : I2C commands via Bluetooth (OLED) + control buttons - #2 by srnet
He writes: "Very very very challenging project for a novice" and that is exactly how it is.
First of all, I don't know what is what, and I don't understand how it is connected.
Can you make a drawing that shows the parts and all the wires. Don't forget the GND and the 3.3V wires. What are the distances ? The I2C bus is not designed to go through a cable.
What is the tuner ? Does it have a schematic ? A brand and type ? What is it ? Can you change the firmware on the tuner ? Does it have a 3.3V I2C bus or a 5V I2C bus ?
Which Logic Analyzer did you buy ? Which software do you use with it ?
If you don't give that basic information, then most of us abandon a topic.
Then about your project.
Do you know a ESP32 as a Slave parallel to a I2C device and reading all the data ? I don't. Maybe it is not possible to make it 100% reliable.
OLED displays don't always behave as normal I2C devices. It is indeed possible that the tuner ignores the ACK by the OLED (which it may give or not). Your friend is right. Did your friend warn you that your project is not easy ?
Please give us a broader view of your project. What is the goal ? What are you trying to achieve ?
At first, thank you for your reply.
It is a hobby and ways finding. It is something I am trying to solve and I think there is a big step from the 0 knowledge about Arduino, ESP32 etc. at the beginnig of the 2023.
At this time we can forget the BT commnucication, buttons etc. It is already done and working. The only issue is that I am not able to sniff all the date sent from the tunner via I2C to the display. If you check my previous post. I was able to read almost all the data correctly with the code above as the digital analyzator (easy cheap device https://www.amazon.de/Saleae-Analyzer-8Channel-saleae-support/dp/B00DPCDEV2, SW: Salae LOGIC2).
In the data provided above you can see that there is only one data loss from the BLOCK 06 to the BLOCK 11). From the BLOCK 11 it works correctly again.
The distance between the tuner and ESP board is like 10cm max. The same is for the analyzator. So now long distances. I am using the logic level converter to decerase the 5V from the tuner to 3,3V to the ESP board.
I can't make the scheme now but this is the basic connection just to sniff the I2C data:
The wider view of the project and the goal is following:
I have an antenna tuner on my balcony. The tuner anables me to work on different HF bands with my HF transceiver. The best place where to place the tuner is directly next to the antenna feed point. The tuner is controlled by 3-buttons and provides setup and working data via an OLED display. But the issue is, that originally the buttons and the display is is included in the tuner's box. So the goal is to place the buttons and disply on my desk (ca 6m distance via the air ca 10 via a wire). I already did something in the past a wired connecuton. It works but on some HF bands the display data are corrupted when the transciever is keying and it confirms what you wrote about the wires and distances (This video shows the "wired" solution. You can imagine the top box with the OLED display on my desk and the botton box on my balcony https://youtu.be/JVSsiDsb-XM):
I am tring replaced the wired connection with BT.
You can see more here in my blog. You can see what data and how the display shows the data and the buttons working via BT :. There is Blog Feed – OK1TK HAM Radio /
I already switched all the functionality to ESP32 boards and now fighting with the I2C data sniffer.
Thank you for all the information.
I can not say if it is possible or not :thinking:
Those Logic Analyzers are okay, but the usb connector might break from the board. I use it with PulseView/sigrok (the website is down when I'm writing this).
ATU-100
This Github repository has firmware for the ATU-100: GitHub - Dfinitski/N7DDC-ATU-100-mini-and-extended-boards
It is not Arduino code.
It should be possible to add a serial port and send data to the bluetooth module. However, I can not find that someone has made firmware for that.
The I2C bus is with software. There are only four functions. They are not fully according to the I2C standard, they are just enough for a OLED display: N7DDC-ATU-100-mini-and-extended-boards/oled_control.c at master · Dfinitski/N7DDC-ATU-100-mini-and-extended-boards · GitHub
It uses 5 µs timing, for a 100 kHz I2C bus.
The PIC processor runs at 5V, so you need indeed a I2C Level Shifter for the ESP32.
I2C Over Air
Capturing the I2C data, then sending it wireless to an Arduino which then sends it to a OLED display is really weird. I don't know any other project like it. Any other option would be better. For example using a wireless webcam to look at the display.
TEST
Can you do more tests.
A OLED display is a 3.3V device with a 3.3V I2C bus.
Can you put the ESP32 parallel with the OLED display, both after the I2C level shifter.
Does the display still work, while you are capturing the data ?
Maybe a buffer is getting full.
Do you know the maximum amount of bytes that is transferred ? I think that the ESP32 can not receive more than 256 bytes (it is only 32 bytes for an Arduino Uno).
Could you try to put the data in a buffer, and print it in the loop(). It is possible to add variables to check if a buffer is full or if it was not emptied in time.
byte buffer[256];
volatile byte newDataSize = 0;
volatile error = 0;
  if (newDataSize != 0)
    error++;
    for (i=0; i<howMany; i++)
      buffer[i] = Wire.read();
    newDataSize = howMany;
  if (newDataSize > 0)
    for(i=0; i<newDataSize; i++)
      Serial.print(buffer[i],HEX);
      Serial.print(",");
    newDataSize = 0;
  if(error > 0)
    Serial.println("ERROR, buffer was not emptied");
    error--;
Thank you for your answer and time. I will go step by step and do the recommended tests when I have a bit more time.
Anyway I tried to increase the buffer size in the Wire.h library and you confirmed what I tested some time ago. The max size was 256 bytes. If I increased more it the the sniffer was able to catch just 2-3 rows and then it freeze or it got frozen immediately.
You can see here what happend when I sent the captured data via BT to from the slave ESP32 to the Master ESP with an OLED connected:
It looks like the longest data transfer has 128 bytes. In the video example above I use the circular buffer to store the captured I2C data and then I send the data to BT. The similar solution is on the other ESP board. The captured BT data ae stored in the circular buffer and then sent to the OLED.
I'm not ready to look into Bluetooth :cold_sweat:
You should first get valid data in the Serial Monitor. Can you tie Bluetooth to Serial2 ?
If you have a 100kHz I2C bus, that can be 10kbyte per second.
A Serial communication with 115200 baud can also do 10kbyte per second.
That means your Bluetooth must operate at 115200 baud and a byte should be send as a byte. Like this:
    Serial.write(buffer,newDataSize); // <-- send a byte as a byte
    Serial.write( ? ? some kind of marker ? ? );
    newDataSize = 0;
Even then, you might need about ten of those 256 bytes buffers.
I think that you are sending a single byte from the I2C bus as three bytes over Bluetooth.
The last example videos were just to show what happend if I sent the incomplete data to the display. Yes, the first goal is to focus to sniff all the data from the tuner. No need to focus on BT etc. right now.
