I have connected a Wemos OLED ESP32 with another OLED display and a 3-wire DHT11 sensor breakout (with pull-up resistor). I have tested the displays and they both produce the test picture. I can't get the I2C_scanner to work - it says there are no devices. SLC - pin 4, SDA - pin 5. I'm running the devices off the 3.3V pin.
Update: When I unplug the DHT11 sensor I2C:scanner finds the OLED.
/*** Rui Santos ***/
#include <Wire.h>
Wire.begin();
while(!Serial);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address<16) {
Serial.print("0");
Serial.println(address,HEX);
nDevices++;
else if (error==4) {
Serial.print("Unknow error at address 0x");
if (address<16) {
Serial.print("0");
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
else {
Serial.println("done\n");
delay(5000);
