ESP32 is not booting after ESP32 Core Updated to 3.1.3
Hi experts,
I am facing a problem after esp32 core updated to 3.1.3. The device is not booting after uploading. I have tested with 3 different boards, I have tried to solve this issue but its beyond my limit. I had tested with many sketches but result is same.I need an immediate help to resolve this issue.
The tested sketch is below:
I had tested many sketches but result is same.
# define ENABLE_DEBUG
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <HTTPClient.h>
#include "thermistor.h"
// Replace with your network credentials
const char* ssid     = "SUNIL-WiFi-2G";
const char* password = "Aarush@2011";
// REPLACE with your Domain name and URL path or IP address with path
const char* serverName = "https://cloudcontrol.tech/post-esp-data.php";
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /post-esp-data.php also needs to have the same key
String apiKeyValue = "tPmAT5Ab3j7F9";
String sensorName = "BME280";
String sensorLocation = "Office";
// Analog pin used to read the NTC
#define NTC_PIN               34
// Thermistor object
THERMISTOR thermistor(NTC_PIN,        // Analog pin
                      10000,          // Nominal resistance at 25 ºC
                      3950,           // thermistor's beta coefficient
                      10000);         // Value of the series resistor
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
void RequestData() {
  //Check WiFi connection status
  if(WiFi.status()== WL_CONNECTED){
    WiFiClientSecure *client = new WiFiClientSecure;
    client->setInsecure(); //don't use SSL certificate
    HTTPClient https;
    // Your Domain name with URL path or IP address with path
    https.begin(*client, serverName);
    // Specify content-type header
    https.addHeader("Content-Type", "application/x-www-form-urlencoded");
    // Prepare your HTTP POST request data
    String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + sensorName
                          + "&location=" + sensorLocation + "&value1=" + String(thermistor.read()/10) + "";
                          //+ "&value2=" + String(readHumidity()) + "&value3=" + String(readPressure()/100.0F) + "";
    //Serial.print("httpRequestData: ");
   // Serial.println(httpRequestData);
    // You can comment the httpRequestData variable above
    // then, use the httpRequestData variable below (for testing purposes without the BME280 sensor)
    //String httpRequestData = "api_key=tPmAT5Ab3j7F9&sensor=BME280&location=Office&value1=24.75&value2=49.54&value3=1005.14";
    // Send HTTP POST request
    int httpResponseCode = https.POST(httpRequestData);
    // If you need an HTTP request with a content type: text/plain
    //https.addHeader("Content-Type", "text/plain");
    //int httpResponseCode = https.POST("Hello, World!");
    // If you need an HTTP request with a content type: application/json, use the following:
    //https.addHeader("Content-Type", "application/json");
    //int httpResponseCode = https.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
    if (httpResponseCode>0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
    else {
      Serial.print("Error code: ");
    // Free resources
    https.end();
  else {
    Serial.println("WiFi Disconnected");
  //Send an HTTP POST request every 30 seconds
  delay(30000);
void loop(){
  RequestData();
Waiting for experts feedback.
Thanks in advance..
Regards,
Sunil
