Hardware:
Board: ESP32 from D32 board from Lolin
Core Installation version: 1.0.6
IDE name: Platformio (platform-espressif32 v.3.2.1)
LIB Used: pubsubclient for MQTT, world most used MQTT lib I think (v2.8)
Flash Frequency: 40Mhz
PSRAM enabled: no
Upload Speed: 500.000 or 1.000.000 or 2.000.000
Computer OS: Windows 10 and Ubuntu
Description:
ESP32 is at least 3 times slower than ESP8266 when using MQTT or TCP more in general.
I have created a sketch that subscribe to an MQTT topic and increment a counter, every five seconds print the number of received message per second.
With ESP32 that sketch goes up to 45 messages per second,
ESP8266 scores 145 messages per second.
Sketch:
This is a really small sketch that shows the problem, it works on both ESP8266 and ESP32
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#else
#include <WiFi.h>
#endif
#include <ESP8266WebServer.h>
#else
#include <WebServer.h>
#endif
#include <PubSubClient.h>
#include <FastLED.h>
const char *mqtt_server = "192.168.1.3"; //mqtt server
const char *ssid = "XXX";
const char *password = "XXX";
float framerate = 0;
float framerateCounter = 0;
WiFiClient espClient;
PubSubClient client(espClient); //lib required for mqtt
void callback(char *topic, byte *payload,
unsigned int length) { //callback includes topic and payload ( from which (topic) the payload is comming)
framerateCounter++;
void reconnect() {
while (!client.connected()) {
Serial.println("Attempting MQTT connection...");
if (client.connect("ESP32_clientID")) {
Serial.println("connected");
client.subscribe("lights/glowwormluciferin/set/stream"); //topic=Demo
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void connectmqtt() {
client.connect("ESP32_clientID"); // ESP will connect to mqtt broker with clientID
Serial.println("connected to MQTT");
if (!client.connected()) {
reconnect();
Serial.begin(1000000);
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
WiFi.begin(ssid, password);
client.setServer(mqtt_server, 1883);//connecting to mqtt server
client.setCallback(callback);
//delay(5000);
connectmqtt();
reconnect();
client.loop();
EVERY_N_SECONDS(10) {
framerate = framerateCounter > 0 ? framerateCounter / 10 : 0;
Serial.println("framerate");
Serial.println(framerate);
Isn't ESP32 supposed to be faster than ESP32?
Is it a problem in its WiFiClient ?
