ESP32 Javascript display date not working
Hello
Can anyone help with this query. I have a ESP32 web server and an option to display and change the date using JS
(My time portion is working correctly - only the date does not work/display)
JS(javascript) that I call for updating the date values in the web page :
server.on("/displaydate", {
String s = "";
s+="$('date').value=('0' +"+ (String)MyDateDay + ").slice(-2)+'/'+ ('0' +" + (String)MyDateMonth + ").slice(-2)+'/'+ ('0' +" + (String)MyDateYear + ").slice(-2);";
Single line of html (out of the web page) to display the date in a small box :
Any help appreciated
Thanks
C
any
</script>
in the code we don't see?
if you save
<p>Date/Time: <span id="datetime"></span></p>
<script>
var dt = new Date();
document.getElementById("datetime").innerHTML = (("0"+(dt.getMonth()+1)).slice(-2)) +"/"+ (("0"+dt.getDate()).slice(-2)) +"/"+ (dt.getFullYear()) +" "+ (("0"+dt.getHours()+1).slice(-2)) +":"+ (("0"+dt.getMinutes()+1).slice(-2));
</script>
in a test.htm file and open it in your browser, it will should display the date/time (just mess around with the formula if it does not util you can see what you want)
Thanks for reply - will try.
Any other ideas would be welcome !
I should have been more specific :
I have 3 variables called :
unsigned char MyDateDay;
unsigned char MyDateMonth;
unsigned char MyDateYear;
MyJS(javascript) that I call for updating the date values in the web page :
String s = "";
Try to print on your arduino the s string to see if it’s built the way you expect it
