Esp32 json kodi
Hello everyone
Can anyone help me with my problem?
I want to get information from KODI (coreelec) using JSON and read it over wifi (ESP32) so I can display it on the LCD. I have the basic code in python but I don't know how to do it in arduino.
import time
import requests
import json
def main():
    base_url = "http://192.168.0.150:8081"
    rpc_url   = base_url + "/jsonrpc"
    headers  = {'content-type': 'application/json'}
    payload = {
            "jsonrpc": "2.0",
            "method"  : "XBMC.GetInfoLabels",
            "params"  : {"labels": [ "System.Date" ]},
            "id"      : 5,
    response = requests.post(rpc_url, data=json.dumps(payload), headers=headers).json()
    print( response ) # output: {'id': 5, 'jsonrpc': '2.0', 'result': {'System.Date': '11. marca 2025'}}
    info = response['result']
#    print (info [ 'System.Date' ]) # output:  11. marca 2025
while True:
    main()
    time.sleep(1)
This is the link I want to extract from. No matter what I do, no output. I just need to point to a specific library and a way to extract, in this case System.Date.
I'm not asking anyone to write me the whole code.
http://192.168.0.150:8081/jsonrpc?request={"jsonrpc":"2.0","method":"XBMC.GetInfoLabels","params":{"labels":["System.Date"]},"id":5}
This is the output in a web browser.
{"id":5,"jsonrpc":"2.0","result":{"System.Date":"12. marca 2025"}}
Post the code that you've tried.
I tried it differently and I got an output.
Now I need to clean out the exit. Remove everything that doesn't belong there.
The next step should be to use one link to get multiple different data and then just select them.
"VideoPlayer.ChannelName",
"System.Date"
and so on.
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h> //JSON
#define WIFI_SSID     "WIFI_AP"
#define WIFI_PASSWORD "WIFI_PASSWORD"
      WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
      Serial.print("Connecting to Wi-Fi");
      while (WiFi.status() != WL_CONNECTED)
             Serial.print(".");
             delay(300);
      Serial.print("Connected with IP: ");
      if ((WiFi.status() == WL_CONNECTED))
          HTTPClient http; //Instanz von HTTPClient starten
          http.begin("http://192.168.0.150:8081/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22XBMC.GetInfoLabels%22,%22params%22:{%22labels%22:[%22System.Date%22]},%22id%22:5}");
          int httpCode = http.GET(); //Antwort des Servers abrufen
          if (httpCode == 200)
              String payload = http.getString(); //Daten in eine Variable speichern
              Serial.println(payload);
Done.
Now just a few small adjustments for Display.
// Kodi JSON Info Labels                                 by:Jojo
#include <WiFi.h>
             Serial.print(".");
             delay(300);
  String inRaw;
  int httpCode;
          HTTPClient http;
          http.begin("http://192.168.0.150:8081/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22XBMC.GetInfoLabels%22,%22params%22:{%22labels%22:[%22System.Date%22,%22VideoPlayer.ChannelName%22,%22VideoPlayer.Title%22,%22VideoPlayer.Year%22,%22PVR.EpgEventDuration%22,%22PVR.EpgEventElapsedTime%22,%22PVR.EpgEventFinishTime%22]},%22id%22:5}");
          inRaw = http.getString();
//---- Deserialization + Filter -----
          StaticJsonDocument<0> filter;
          filter.set(true);
          StaticJsonDocument<512> doc;
          DeserializationError error = deserializeJson(doc, inRaw, DeserializationOption::Filter(filter));
          if (error)
              Serial.print("deserializeJson() failed: ");
              Serial.println(error.c_str());
              return;
          int id = doc["id"]; // 5
          const char* jsonrpc = doc["jsonrpc"]; // "2.0"
          JsonObject result = doc["result"];
          const char* result_PVR_EpgEventDuration = result["PVR.EpgEventDuration"];
          const char* result_PVR_EpgEventElapsedTime = result["PVR.EpgEventElapsedTime"];
          const char* result_PVR_EpgEventFinishTime = result["PVR.EpgEventFinishTime"];
          const char* result_System_Date = result["System.Date"];
          const char* result_VideoPlayer_ChannelName = result["VideoPlayer.ChannelName"];
          const char* result_VideoPlayer_Title = result["VideoPlayer.Title"];
          const char* result_VideoPlayer_Year = result["VideoPlayer.Year"];
          Serial.println(result_PVR_EpgEventDuration);
          Serial.println(result_PVR_EpgEventElapsedTime);
          Serial.println(result_PVR_EpgEventFinishTime);
          Serial.println(result_System_Date);
          Serial.println(result_VideoPlayer_ChannelName);
          Serial.println(result_VideoPlayer_Title);
          Serial.println(result_VideoPlayer_Year);
