I get an include error when trying to include the <I2S.h>
header file.
fatal error: I2S.h: No such file or directory
Here's the verbose output:
FQBN: esp32:esp32:esp32s3
Using board 'esp32s3' from platform in folder: C:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1
Using core 'esp32' from platform in folder: C:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1
cmd /c if exist "D:\\john\\Documents\\Arduino\\VoiceRec\\partitions.csv" COPY /y "D:\\john\\Documents\\Arduino\\VoiceRec\\partitions.csv" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\partitions.csv"
cmd /c if not exist "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\partitions.csv" if exist "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\partitions.csv" COPY "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\partitions.csv" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\partitions.csv"
cmd /c if not exist "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\partitions.csv" COPY "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\tools\\partitions\\default.csv" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "D:\\john\\Documents\\Arduino\\VoiceRec\\bootloader.bin" ( COPY /y "D:\\john\\Documents\\Arduino\\VoiceRec\\bootloader.bin" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\VoiceRec.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\bootloader.bin" ( COPY "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\bootloader.bin" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\VoiceRec.ino.bootloader.bin" ) ELSE ( "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\VoiceRec.ino.bootloader.bin" "C:\\Users\\casli\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
cmd /c if exist "D:\\john\\Documents\\Arduino\\VoiceRec\\build_opt.h" COPY /y "D:\\john\\Documents\\Arduino\\VoiceRec\\build_opt.h" "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\build_opt.h"
cmd /c if not exist "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\build_opt.h" type nul > "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F\\build_opt.h"
cmd /c type nul > "C:\\Users\\casli\\AppData\\Local\\Temp\\arduino\\sketches\\FFBD4E96CE5A569128365D615741A10F/file_opts"
Detecting libraries used...
C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/defines -ID:\john\Documents\Arduino\VoiceRec -iprefix C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/include/ @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/includes -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/qio_qspi/include -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\cores\esp32 -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\variants\esp32s3 @C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F/build_opt.h @C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F/file_opts C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F\sketch\VoiceRec.ino.cpp -o nul
Alternatives for Voice_Security_inferencing.h: [Voice_Security_inferencing@1.0.2]
ResolveLibrary(Voice_Security_inferencing.h)
-> candidates: [Voice_Security_inferencing@1.0.2]
C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/defines -ID:\john\Documents\Arduino\VoiceRec -iprefix C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/include/ @C:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/includes -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/qio_qspi/include -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\cores\esp32 -IC:\Users\casli\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\variants\esp32s3 -Id:\john\Documents\Arduino\libraries\Voice_Security_inferencing\src @C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F/build_opt.h @C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F/file_opts C:\Users\casli\AppData\Local\Temp\arduino\sketches\FFBD4E96CE5A569128365D615741A10F\sketch\VoiceRec.ino.cpp -o nul
D:\john\Documents\Arduino\VoiceRec\VoiceRec.ino:8:10: fatal error: I2S.h: No such file or directory
8 | #include <I2S.h>
compilation terminated.
Alternatives for I2S.h: []
ResolveLibrary(I2S.h)
-> candidates: []
exit status 1
Compilation error: I2S.h: No such file or directory
Here are the details of the device and software:
Board: ESP32_S3 Dev Module
Board Library Version: esp32 by Espressif Systems v3.0.1
Arduino IDE Version: 2.3.2
Platform: Windows10, x86-64
How do I resolve this ?
