Hi. Many thans for your update but... I'm still wondering if it is better to use the interrupt process instead of checking a value in the loop().
On an operational point of view, is it better ?
Example : in the loop, I have written onReceive(LoRa.parsePacket());, but I also do many other actions [please read my script below]. Is there a risk that, when doing other actions, I may loose a LORA Signal (as my processor is used to do something else at this moment) ? If yes (I may loose a signal), such a risk could be avoided when using the interruption process ?
// Energie Mairie - Gway ALL - 20241230.02 - tracking des relais.txt
Projet = ENERGIE MAIRIE
file = Energie Mairie - Gway LORA - ESP32 - 20240xxx---
Sketch pour Gway / LORA & OLED / Gateway centrale
P2P Lora - scenario Gway / Emission & reception
// !!!!!!!!!!!!!! DEBUT CONFIGURATION DE LA SOLUTION
// Qd ajout de capteur : chercher // ---- AJOUT de sonde
// 1) definir la Gway
#define GATEWAY_FE
// #define GATEWAY_FD
// 2) - type de carte
// #define ESP32_TTGO
#define ESP32 -LILYGOT31_6_1
// 3) DEBUG
//#define DEBUG_SERIAL
//#define DEBUG_OLED
#define OLED_LITE
// 4) - outil de compimation
// #define COMPILATION_CLOUD_IoT
#define COMPILATION_CLOUD_IDE
// #define COMPILATION_IDE
// 5)
#define BANDWITH433
// #define BANDWITH868
// ************* Donnees arduino
// 6) - Données Lora
const byte Header1 = 0x06; // pour reconnaire la trame Mairie
const byte Header2 = 0x07; // pour reconnaire la trame Mairie
const byte Adresse_Broadcast = 0xFF;
const byte Version_du_protocole_lora = 0x01; // version envoyée ds la trame Lora - prevu pour evolutions futures
const byte Message_de_donnee = 0x01;
const byte Message_de_keepalive = 0x02;
// 5) Connection Cloud ou non & Wifi
// #define DEVELOPPEMENT_NO_CLOUD_CONNEXION
#ifndef COMPILATION_CLOUD_IoT // // On exclut cette ligne en Cloud IoT car c'est déja inclu avec le Wifi etc...
#define WIFI_SSID "freecd9b4box8"
#define WIFI_PASSWORD "7869078690786"
#define SECRET_SSID WIFI_SSID
#define SECRET_OPTIONAL_PASS WIFI_PASSWORD
#endif
#ifdef GATEWAY_FE
int const Nbre_de_capteurs_configures = 8; // sur cette Gway - pour contrôle des adresses recues // ---- AJOUT de capteur
int const ID_premier_capteurs_configure = 1;
#define SECRET_DEVICE_KEY "Uxe3l5kmFfx3VM?daa5EBiYGv" // Ruches Connectees
const byte Adresse_Device = 0xFE; // address of this device / CH = that is the Gateway - uniquement en reception
#if defined COMPILATION_CLOUD_IoT || defined COMPILATION_CLOUD_IDE // Pour differencier complilation IDE & CLOUD
#include "thingProperties-Ruches-Connectees-GwayFE.h"
#endif
#endif
#ifdef GATEWAY_FD
int const Nbre_de_capteurs_configures = xxxx; // sur cette Gway - pour contrôle des adresses recues
int const ID_premier_capteurs_configure = xxxx;
const byte Adresse_Device = 0xFD; // address of this device / CH = that is the Gateway - uniquement en reception
#define SECRET_DEVICE_KEY "bJRc!2S#vVjap01YLGcRr#5H@"
#include "thingProperties-Energie-GwayFD.h"
#endif
#endif
float *Gway_donnee1OUT = &Gdonnee1OUT;
float *Gway_donnee2OUT = &Gdonnee2OUT;
float *Gway_donnee3OUT = &Gdonnee3OUT; // 29/12/2024
bool *Gway_donnee4OUT = &Gdonnee4OUT; // 29/12/2024
int *Gway_capteurIDOUT = &GcapteurIDOUT;
bool *Gway_donneeMAJOUT = &GdonneeMAJOUT;
String *PORTAIL_gateway_texte = >EXTE;
// 7) - Autres mesures
const int Duree_pour_MAJ_status_Gway_mn = 15;
// 8) - Données du PORTAIL non configurées - pour test avant déploiement IoT Mairie - DEBUT
#if not defined COMPILATION_CLOUD_IoT && not defined COMPILATION_CLOUD_IDE
float Gdonnee1OUT;
float Gdonnee2OUT;
float Gdonnee3OUT; // 29/12/2024
bool Gdonnee4OUT; // 29/12/2024
int GcapteurIDOUT;
bool GdonneeMAJOUT;
String Gtexte;
bool GSTATDEV;
#endif
//*** CONTEXT/CONSTANTES * TO BE UPDATED/FIN **********************************************************
#include <WiFi.h>
#endif
#include <SPI.h> // include libraries
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#ifdef BANDWITH433
#define BAND 433E6
#endif
#ifdef BANDWITH868
#define BAND 868E6
#endif
// version TTGO ESP32
#ifdef ESP32_TTGO
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14 // Changed CH - OLD = 16; NEW = 14
#define DIO0 26
#define DIO1 33
#define DIO2 32
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#endif
// version 2 ESP32 LillyGo [from Bidouilleurs https://www.youtube.com/watch?v=o8Pd-hZDYwc]
#ifdef ESP32 - LILYGOT31_6_1
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 23 // OLD = 16
#define DIO0 26
//OLED pins LiLYGo / T3 version 1.6.1
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 2 // n'est peut être pas le 2 mais e, tout cas, pas le 16
#endif
// Initialisation ecran OLED
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
// constante OLED
const int debut_ligne_status = 0;
const int debut_ligne_received = 9;
const int debut_ligne_sent = 36;
const int increment_ligne = 9;
const int Clear_ecran_OLED = 1; //25/11/2024
const int Pas_clear_ecran_OLED = 0; //25/11/2024
const int Clear_ligne_OLED = 1; //25/11/2024
const int Pas_clear_ligne_OLED = 0; //25/11/2024
const int Couleur_OLED_blanc = 1; //25/11/2024
String *PORTAIL_gateway_text;
// enregistrement des numeros de essage reçus pour éviter le traitement en double de messages relayés par les relais
const int taille_tab_messages_recus = 6; // taille de la table de suivi de smessages reçus pour éviter les doublons
int index_courant_tab_messages_recus = 0; // index de remplissage du suivi de smessages reçus pour éviter les doublons
int tab_messages_recus[taille_tab_messages_recus]; // table qui garde les numéros des msg reçus pour éviter doublon
unsigned long tab_messages_recus_tempo_t0[taille_tab_messages_recus]; // table qui garde le moment "CurrentTime" où le message a été reçu
const float messages_recus_tempo_duree = 60 * 1000; // durée durant laquelle on garde les messages pour éviter les répets - en milisecondes
// Autres variables
unsigned long currentTime = 0;
const int MaxCurrentTime_Jour = 50;
unsigned long status_Gway_alive_tempo_t0;
unsigned long status_Gway_alive_tempo_duree = Duree_pour_MAJ_status_Gway_mn * 60 * 1000;
int nombre_de_fois_current_time_reached = 0;
int currentTimeJour = 0;
int currentTimeJourCumule = 0;
int currentTimeHeure = 0;
int currentTimeMinute = 0;
unsigned long keepalive_tempo_t0;
const int Duree_entre_keepalive_gateway_mn = 30;
const unsigned long keepalive_tempo_duree = Duree_entre_keepalive_gateway_mn * 60 * 1000;
unsigned long clean_portail_msg_text_t0 = 0;
unsigned long clean_portail_msg_text_duree = 3 * 24 * 60 * 60 * 1000; // changé valeur : passé à 48
unsigned long impression_variable_delais = 60 * 60 * 1000; // 08/01/2025
unsigned long impression_variable_t0 = 0; // 02/01/2025
#if defined DEBUG_OLED || defined OLED_LITE // 03/04/2025
// clignotement surt ecran //Ajputé 30/10/2024
unsigned long clignotement_OLED_t0 = 0;
unsigned long clignotement_OLED_duree = 3000; // 03/04/2025
int clignotement_OLED_horizontal = 120;
int clignotement_OLED_vertical = 60;
int clignotement_OLED_taille = 2;
#endif
// Structure relais - 27/11/2024
const int Nbre_de_relais = 3;
struct __attribute__((packed)) suivi_relais {
byte adresse_du_relais;
bool status_relais_Up;
bool *LED_status_relais_Up; // info fournie par paquest de mesures recus & keepalive du relais
bool donnee_de_travail_relais_Up;
bool status_relais_used;
bool *LED_relais_used; // info fournie par paquest de mesures recus
bool donnee_de_travail_relais_used;
suivi_relais tableau_de_suivi_des_relais[Nbre_de_relais] = { // 27/11/2024
{ 0xA0, false, &r01STATDEV, false, false, &r01USED, false },
{ 0xA1, false, &r02STATDEV, false, false, &r02USED, false },
{ 0xA2, false, &r03STATDEV, false, false, &r03USED, false }
unsigned long suivi_MAJ_relais_t0 = 0;
unsigned long suivi_MAJ_relais_duree_mn = 60 * 24 * 3;
unsigned long suivi_MAJ_relais_duree = suivi_MAJ_relais_duree_mn * 60 * 1000;
unsigned long clignotement_LED_relais_t0 = 0;
unsigned long clignotement_LED_relais_duree = 1 * 1000;
const int Check_if_relais_used = 1; // 27/11/2024
const int Check_if_relais_Up = 2; // 29/12/2024
String message_du_portail;
int numero_device = 0;
bool message_valable = false;
int index_numero_device = 0;
int message_status = 0;
int message_ERR = 0;
int n = 0;
bool bool_donnee_de_travail;
int suivi_automate = 0;
int phase_de_setup = 1;
const int debut_numero_du_message = 254; // pour les msg envoyés par la gateway
// LORA - Donnees pour traitement des infos reçues
byte header1_du_message;
byte header2_du_message;
byte version_du_message;
byte emetteur_du_message;
byte destinataire_du_message;
byte relais1_du_message;
byte relais2_du_message;
byte relais3_du_message;
int numero_du_message = 0;
byte type_du_message;
float donnee1_du_message;
const float Donnee1_MAX = 100000; //14/03/2025
const float Donnee1_MIN = 0; //14/03/2025
const float Donnee2_MAX = 0; //14/03/2025
const float Donnee2_MIN = 0; //14/03/2025
float donnee2_du_message;
float donnee3_du_message;
boolean donnee4_du_message;
float checksum_du_message;
char text_du_message[30];
int taille_du_message;
// Structure Lora
struct __attribute__((packed)) MessageLora {
byte header1; // pour reconnaitre trame ruche
byte header2; // pour reconnaitre trame ruche
byte version; // pour évolutions future
byte emetteur;
byte destinataire;
byte relais1;
byte relais2;
byte relais3;
int32_t numero_du_message;
float donnee1; // poids de la ruche
float donnee2; // pour évolution future
float donnee3; // pour évolution future
boolean donnee4; // pour évolution future
float checksum; // pour évolution future
char text[30];
MessageLora messageLora;
MessageLora messageLoraINIT; //03/04/2025
// Msg d'erreur
char *tab_message_ERR[10] = { "", "1)hd/ver KO", "2)emet. KO", "3)dest. KO", "4)broad.", "5)type KO", "6)d1/d2 KO", "7)check KO", "8)Dup. msg", "" };
// Initialize serial and wait for port to open:
#ifdef DEBUG_SERIAL
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(10000);
Serial.println("Entree / setup...");
#endif
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
// Mise en commentaire pour compilation IDE
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
#endif
#ifdef DEBUG_SERIAL
Serial.println("Arduino initialisé");
#endif
//reset OLED display via software
pinMode(OLED_RST, OUTPUT);
digitalWrite(OLED_RST, 0);
delay(20);
digitalWrite(OLED_RST, HIGH);
//initialize OLED
Wire.begin(OLED_SDA, OLED_SCL);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for (;;)
; // Don't proceed, loop forever
Serial.println("OLED ready");
#endif
// override the default CS, reset, and IRQ pins (optional)
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
if (!LoRa.begin(BAND)) { // initialize ratio for Europe
displayOLED(Clear_ecran_OLED, Pas_clear_ligne_OLED, 0, debut_ligne_status, 1, "LoRa init failed. Check your connections", 1);
#endif
while (true)
; // if failed, do nothing
displayOLED(Clear_ecran_OLED, Pas_clear_ligne_OLED, 0, debut_ligne_status, 1, "LoRa OK - Gway", 1);
#endif
#ifdef DEBUG_SERIAL
Serial.println("LoRa init succeeded");
#endif
LoRa.setSpreadingFactor(12);
LoRa.setSignalBandwidth(62.5E3);
LoRa.setCodingRate4(5); //min 5- max 8
currentTime = millis();
// MAJ_des_donnees_ms_t0 = currentTime;
*Gway_donneeMAJOUT = false;
*Gway_donnee1OUT = 0;
*Gway_donnee2OUT = 0;
*Gway_donnee3OUT = 0; // 29/12/2024
*Gway_donnee4OUT = false; // 29/12/2024
*Gway_capteurIDOUT = 0;
Serial.print("Gateway demarree - ");
Serial.println("GATEWAY_" + String(Adresse_Device) + " - ");
Serial.println("Données après initiaisation - ");
Serial.print("GFxdonneeMAJOUT = " + String(*Gway_donneeMAJOUT) + " /");
Serial.print("GFxcapteurIDOUT = " + String(*Gway_capteurIDOUT) + " /");
Serial.print("GFxdonnee1OUT = " + String(*Gway_donnee1OUT) + " /");
Serial.println("GFxdonnee2OUT = " + String(*Gway_donnee2OUT));
Serial.print("GFxdonnee3OUT = " + String(*Gway_donnee3OUT) + " /"); // 29/12/2024
Serial.println("GFxdonnee4OUT = " + String(*Gway_donnee4OUT)); // 29/12/2024
keepalive_tempo_t0 = currentTime;
status_Gway_alive_tempo_t0 = currentTime;
clean_portail_msg_text_t0 = currentTime;
suivi_MAJ_relais_t0 = currentTime; // 26/11/2024
clignotement_LED_relais_t0 = currentTime; // 27/11/2024
impression_variable_t0 = currentTime; // 02/01/2025
init_structure_lora(); // 03/04/2025
for (n = 0; n < taille_tab_messages_recus; n++) // 27/11/2024
tab_messages_recus[n] = 0; //27/11/2024
tab_messages_recus_tempo_t0[n] = 0;
for (n = 0; n < Nbre_de_relais; n++) // 26/12/2024
tableau_de_suivi_des_relais[n].status_relais_Up = false;
*tableau_de_suivi_des_relais[n].LED_status_relais_Up = false;
tableau_de_suivi_des_relais[n].donnee_de_travail_relais_Up = false;
tableau_de_suivi_des_relais[n].status_relais_used = false;
*tableau_de_suivi_des_relais[n].LED_relais_used = false; // info fournie par paquest de mesures recus
tableau_de_suivi_des_relais[n].donnee_de_travail_relais_used = false;
clignotement_OLED_t0 = currentTime; //30/10/2024
#endif
// Traitement des données de l'application ruche
#ifdef DEBUG_SERIAL
Serial.println("Sortie / setup");
Serial.print("Arduino Stack was set to bytes " + String(getArduinoLoopTaskStackSize()) + "bytes"); // 02/01/2025
// Print unused stack for the task that is running setup()
Serial.println(" - Free Stack Space: " + String(uxTaskGetStackHighWaterMark(NULL))); // 02/01/2025
#endif
// *PORTAIL_gateway_texte = PropertyActions::CLEAR; // on ne clean pas au depour voir si plantage - 19/01/2025 - CLEAR supprimé
*PORTAIL_gateway_texte = String("Gateway_") + String(Adresse_Device) + String(" démarée et initialisée");
*PORTAIL_gateway_texte = "Arduino Stack was set to " + String(getArduinoLoopTaskStackSize()) + " - Free Stack Space " + String(uxTaskGetStackHighWaterMark(NULL)); // 05/01/2025
phase_de_setup = 0;
#ifdef OLED_LITE
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Gway Ruche on-line", 1);
#endif
#if not defined DEVELOPPEMENT_NO_CLOUD_CONNEXION
if (WiFi.status() != WL_CONNECTED) // 26/11/2024
#if defined DEBUG_OLED // 03/04/2025
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "WIFI KO !!!!!", 1);
#endif
#ifdef DEBUG_SERIAL
Serial.println("WIFI KO !!!!!");
#endif
if (!ArduinoCloud.connected()) {
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Arduino Not connected", 1);
#endif
ArduinoCloud.update();
#endif
#endif
if (currentTime - clignotement_OLED_t0 > clignotement_OLED_duree) {
GSTATUSDEV = !GSTATUSDEV;
display.fillCircle(clignotement_OLED_horizontal, clignotement_OLED_vertical, clignotement_OLED_taille, INVERSE);
display.display(); // Update screen with each newly-drawn circle
#endif
if (suivi_automate != 1) {
#ifdef DEBUG_SERIAL
Serial.println("Gway #" + String(Adresse_Device) + " - attente msg.");
#endif
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Gway/attente msg", 1);
#endif
suivi_automate = 1;
// parse for a packet, and call onReceive with the result:
message_status = 0;
if (message_status == 1) // message recu
suivi_automate = 2;
// lecture du message recu
lecture_du_message();
// controle du message recu
message_ERR = 0;
ctrl_du_message();
if (message_ERR == 0) // pas d'erreur - message correct
suivi_automate = 3;
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received, 1, "Msg received OK", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received + increment_ligne, 1, String(emetteur_du_message) + "/" + String(destinataire_du_message) + "(r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + ")-#" + String(numero_du_message) + "-d1:" + String(donnee1_du_message), 1);
#endif
*PORTAIL_gateway_texte = "Msg received OK - #" + String(emetteur_du_message) + "/" + String(destinataire_du_message) + "(r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + ") / Num msg = " + String(numero_du_message) + " /d1 = " + String(donnee1_du_message) + " /d2 = " + String(donnee2_du_message) + " /d3 = " + String(donnee3_du_message) + " /d4 = " + String(donnee4_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); //13/01/2025 - correction display
traitement_des_donnees();
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received, 1, "Msg received KO", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received + increment_ligne, 1, "ERR" + String(tab_message_ERR[message_ERR]) + "#" + String(numero_du_message), 1);
#endif
// message par defaut
message_du_portail = String("Msg received KO - ERR ");
// Complément de message
if (message_ERR == 1) //pb header ou version
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - version = " + String(version_du_message) + " / h1 = " + String(header1_du_message) + " / h2 = " + String(header2_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - ver = " + String(version_du_message) + " / dev# = " + String(numero_device) + " / h1 = " + String(header1_du_message) + " / h2 = " + String(header2_du_message) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 2) // pb numero de device emetteur
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - dev# = " + String(numero_device));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 3) // Pb destinataire
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " – device dest = " + String(destinataire_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " – device dest = " + String(destinataire_du_message) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 4) // Adresse Broadcast
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " – De:" + String(emetteur_du_message)); //
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " – De:" + String(emetteur_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); // 19/03/2025
// si keepalive, alors on regarde si cela vient d'1 relais -
if (type_du_message == Message_de_keepalive) {
suivi_fonctionnement_de_un_relais(emetteur_du_message, Check_if_relais_Up); // on regarde si le msg est 1 keepalive et ds ce cas, on mentionne que le relais fonctionne. // 29/12/2024
if (message_ERR == 5) // erreur type de message
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - Type = " + String(type_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - Type = " + String(type_du_message) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 6) // Pb sur données
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message));
#endif
if (message_ERR == 7) // pb Checksum
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " / dev# = " + String(numero_device) + " / numero = " + String(numero_du_message) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message) + " / check = " + String(checksum_du_message);
if (message_ERR == 8) // duplicate msg - on peut supposer qu'il s"agit d'1 relais
#ifdef DEBUG_SERIAL
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - #" + String(numero_du_message) + " / dev# = " + String(numero_device) + " - r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); // 14/02/2025 - ajouté rrsi
Check_etat_des_relais(Check_if_relais_Up); // 29/12/2024 - C'est 1 message dupliqu. Mais on regarde si c'est à cause d'1 relais. Et ds ce cas, on mentionne que le relais est actif - mais pas utilisé car déja recu.
// MAj du message du portail pour signaler l'erreur
*PORTAIL_gateway_texte = message_du_portail;
// nettoyage de la structure Lora
nettoyage_structure_lora();
// envoi du keepalive pour test de distance
if ((currentTime - keepalive_tempo_t0) > keepalive_tempo_duree) {
envoi_keepalive();
#ifdef DEBUG_SERIAL
Serial.println("keepalive envoyé");
#endif
// calcul du nbre de mn la Gway a été lancé
if ((currentTime - status_Gway_alive_tempo_t0) > status_Gway_alive_tempo_duree) {
MAJdonneesportailGway();
if ((currentTime - clean_portail_msg_text_t0) > clean_portail_msg_text_duree) {
// gestion des relais - 27/11/2024
// Reinitialisation du tableau de MAJ
if ((currentTime - suivi_MAJ_relais_t0) > suivi_MAJ_relais_duree) {
MAJ_des_infos_des_relais_sur_portail;
#ifdef DEBUG_SERIAL
Serial.println("MAJ du tableau des relais");
#endif
// Clignotement des LEDs associées aux relais - 27/11/2024
if ((currentTime - clignotement_LED_relais_t0) > clignotement_LED_relais_duree) {
for (int h = 0; h < Nbre_de_relais; h++) {
if (tableau_de_suivi_des_relais[h].status_relais_Up == true) {
bool_donnee_de_travail = *tableau_de_suivi_des_relais[h].LED_status_relais_Up;
*tableau_de_suivi_des_relais[h].LED_status_relais_Up = !bool_donnee_de_travail;
} else
*tableau_de_suivi_des_relais[h].LED_status_relais_Up = false;
if (tableau_de_suivi_des_relais[h].status_relais_used == true) {
bool_donnee_de_travail = *tableau_de_suivi_des_relais[h].LED_relais_used;
*tableau_de_suivi_des_relais[h].LED_relais_used = !bool_donnee_de_travail;
} else
*tableau_de_suivi_des_relais[h].LED_relais_used = false;
if ((currentTime - impression_variable_t0) > impression_variable_delais) // 02/01/2025
// Print unused stack for the task that is running loop() - the same as for setup()
#ifdef DEBUG_SERIAL
Serial.println("Free Stack Space: " + String(uxTaskGetStackHighWaterMark(NULL)) + "Bytes"); // 02/01/2025
#endif
*PORTAIL_gateway_texte = "Arduino Stack was set to " + String(getArduinoLoopTaskStackSize()) + "- Free Stack Space " + String(uxTaskGetStackHighWaterMark(NULL)); // 05/01/2025
void MAJdonneesportailGway()
#ifdef DEBUG_SERIAL
Serial.println("Entrée / MAJdonneesportailGway");
#endif
// Si le compteur currentTime a recommencé à zéro, alors on compte 1 boucle
if (currentTime < status_Gway_alive_tempo_t0)
nombre_de_fois_current_time_reached = nombre_de_fois_current_time_reached + 1;
status_Gway_alive_tempo_t0 = currentTime; // on réinitialise t0
// calcul des données du portail
currentTimeJourCumule = nombre_de_fois_current_time_reached * MaxCurrentTime_Jour + round(currentTime / 1000 / 60 / 60 / 24);
currentTimeJour = currentTimeJourCumule - nombre_de_fois_current_time_reached * MaxCurrentTime_Jour;
currentTimeHeure = round((currentTime - currentTimeJour * 24 * 60 * 60 * 1000) / 1000 / 60 / 60);
currentTimeMinute = round(((currentTime - currentTimeHeure * 60 * 60 * 1000 - currentTimeJour * 24 * 60 * 60 * 1000) / 60 / 1000));
// MAJ des données du portail
*PORTAIL_gateway_jour = currentTimeJourCumule;
*PORTAIL_gateway_heure = currentTimeHeure;
*PORTAIL_gateway_minute = currentTimeMinute;
*PORTAIL_gateway_texte = "Gway Up&Running depuis " + String(currentTimeJour) + "j, " + String(currentTimeHeure) + "h, " + String(currentTimeMinute);
#ifdef DEBUG_SERIAL
Serial.println("currentTimeJourCumule = " + String(currentTimeJourCumule));
Serial.println("currentTimeHeure = " + String(currentTimeHeure));
Serial.println("currentTimeMinute = " + String(currentTimeMinute));
Serial.println("Sortie / Traitement_des_donnees");
#endif
void traitement_des_donnees()
#ifdef DEBUG_SERIAL
Serial.println("Entrée / Traitement_des_donnees");
#endif
Serial.println("MAJ des donnees");
*Gway_donnee1OUT = donnee1_du_message;
*Gway_donnee2OUT = donnee2_du_message;
*Gway_donnee3OUT = donnee3_du_message; //29/12/2024
*Gway_donnee4OUT = donnee4_du_message; //29/12/2024
// *Gway_donnee1OUT = random(0, 100);
// *Gway_donnee2OUT = random(0, 100);
*Gway_capteurIDOUT = index_numero_device + 1;
*Gway_donneeMAJOUT = true;
#ifdef DEBUG_SERIAL
Serial.println("AVANT - MAJ des donnees");
Serial.print("Gxxdonnee1OUT = " + String(*Gway_donnee1OUT) + " /");
Serial.print("Gxxdonnee2OUT = " + String(*Gway_donnee2OUT) + " /");
Serial.print("Gxxdonnee3OUT = " + String(*Gway_donnee3OUT) + " /"); //29/12/2024
Serial.print("Gxxdonnee4OUT = " + String(*Gway_donnee4OUT) + " /"); //29/12/2024
Serial.print("GxxdonneeMAJOUT = " + String(*Gway_donneeMAJOUT) + " /");
Serial.println("GxxcapteurIDOUT = " + String(*Gway_capteurIDOUT));
#endif
Check_etat_des_relais(Check_if_relais_used); // 27/11/2024 - c'est 1 msg correct - on regarde s'il a été retransmis par un relais, et ds ce cas, on mentionne que le relais est actif et est UTILISé
} // fin du traitement des données
void Check_etat_des_relais(int type_de_controle) { // 27/11/2024
// Analyse des données relais reçues ds la trame
if (relais1_du_message != 0)
suivi_fonctionnement_de_un_relais(relais1_du_message, type_de_controle);
if (relais2_du_message != 0)
suivi_fonctionnement_de_un_relais(relais2_du_message, type_de_controle);
if (relais3_du_message != 0)
suivi_fonctionnement_de_un_relais(relais3_du_message, type_de_controle);
void suivi_fonctionnement_de_un_relais(byte adresse_du_relais_actif, int type_de_controle) // 24/11/2024
// si seulement controle relais actif > on en met à jour que les donnees du remais actif
// si demande de controle = relais used, alors on met aussi à jour relais used
#ifdef DEBUG_SERIAL
Serial.println("Entrée suivi_fonctionnement_des_relais #" + String(adresse_du_relais_actif));
#endif
for (int z = 0; z < Nbre_de_relais; z++) {
if (tableau_de_suivi_des_relais[z].adresse_du_relais == adresse_du_relais_actif) {
#ifdef DEBUG_SERIAL
Serial.println("Relais reconnu - " + String(adresse_du_relais_actif));
#endif
tableau_de_suivi_des_relais[z].status_relais_Up = true;
tableau_de_suivi_des_relais[z].donnee_de_travail_relais_Up = true; // 29/12/2024
// *PORTAIL_gateway_texte = "Relais [" + String(tableau_de_suivi_des_relais[z].adresse_du_relais) + "] Up";
if (type_de_controle == Check_if_relais_used) {
tableau_de_suivi_des_relais[z].status_relais_used = true;
// *PORTAIL_gateway_texte = "Relais [" + String(tableau_de_suivi_des_relais[z].adresse_du_relais) + "/" + String(adresse_du_relais_actif) + "] used - capteurID [#" + String(emetteur_du_message) + "] type ctrl=" + String(type_de_controle); // 30/12/24
tableau_de_suivi_des_relais[z].donnee_de_travail_relais_used = true;
void MAJ_des_infos_des_relais_sur_portail() // 27/11/2024
// controle des relais qui ne sont plus utilisés
for (int j = 0; j < Nbre_de_relais; j++) {
if (tableau_de_suivi_des_relais[j].donnee_de_travail_relais_Up == true) {
tableau_de_suivi_des_relais[j].status_relais_Up = true;
tableau_de_suivi_des_relais[j].status_relais_Up = false;
if (tableau_de_suivi_des_relais[j].donnee_de_travail_relais_used == true) {
tableau_de_suivi_des_relais[j].status_relais_used = true;
tableau_de_suivi_des_relais[j].status_relais_used = false;
// reinitialisation des données de travai
tableau_de_suivi_des_relais[j].donnee_de_travail_relais_Up = false;
tableau_de_suivi_des_relais[j].donnee_de_travail_relais_used = false;
void preparation_du_message_keepalive()
#ifdef DEBUG_SERIAL
Serial.println("Entree / preparation_du_message_keepalive");
#endif
header1_du_message = Header1;
header2_du_message = Header2;
version_du_message = Version_du_protocole_lora;
emetteur_du_message = Adresse_Device;
destinataire_du_message = Adresse_Broadcast;
relais1_du_message = 0x00;
relais2_du_message = 0x00;
relais3_du_message = 0x00;
numero_du_message = random(debut_numero_du_message, debut_numero_du_message + 99);
type_du_message = Message_de_keepalive;
donnee1_du_message = 0;
donnee2_du_message = 0;
donnee3_du_message = 0;
donnee4_du_message = 0;
checksum_du_message = numero_du_message + donnee1_du_message + donnee2_du_message + donnee3_du_message + donnee4_du_message;
// text_du_message = "";
#ifdef DEBUG_SERIAL
Serial.println("Sortie / preparation_du_message_keepalive");
#endif
void envoi_keepalive()
#ifdef DEBUG_SERIAL
Serial.println("Entree / envoi_keepalive");
#endif
preparation_du_message_keepalive();
ecriture_du_message();
sendMessage();
#ifdef DEBUG_SERIAL
Serial.println("Sortie / envoi_keepalive");
#endif
void ctrl_du_message()
#ifdef DEBUG_SERIAL
Serial.println("Entree / ctrl_du_message");
#endif
// Controle du message recu
if ((version_du_message != Version_du_protocole_lora) || (header1_du_message != Header1) || (header2_du_message != Header2)) {
message_ERR = 1;
return; // skip rest of function
// Controle du type message recu
// Modifié 25/06/24 pour contrôle type du message
if ((type_du_message != Message_de_donnee) && (type_du_message != Message_de_keepalive)) {
message_ERR = 5;
// controle du numero de device recu
if ((type_du_message == Message_de_donnee) && ((numero_device < ID_premier_capteurs_configure) || (numero_device > ID_premier_capteurs_configure + Nbre_de_capteurs_configures - 1))) //
message_ERR = 2;
index_numero_device = numero_device - 1;
// Contrôle broadcast
if (destinataire_du_message == Adresse_Broadcast) {
message_ERR = 4;
// Controle du destinataire recu
if (destinataire_du_message != Adresse_Device) {
message_ERR = 3;
// Contrôle de la valeur mesurée
// Modifié 02/07/24
if ((donnee1_du_message > Donnee1_MAX) || (donnee1_du_message < Donnee1_MIN) || (donnee2_du_message < Donnee2_MIN) || (donnee2_du_message > Donnee2_MAX)) {
message_ERR = 6;
// Ctrl Checksum
if (checksum_du_message != numero_du_message + donnee1_du_message + donnee2_du_message + donnee3_du_message + donnee4_du_message) {
message_ERR = 7;
// verifiation que le message n'a pas déja été recu / eviter réémission par relais
for (int i = 0; i < taille_tab_messages_recus; i++) {
if (numero_du_message == tab_messages_recus[i] & (currentTime - tab_messages_recus_tempo_t0[i] < messages_recus_tempo_duree)) {
message_ERR = 8;
// enregistrement du numero de message
tab_messages_recus[index_courant_tab_messages_recus] = numero_du_message;
tab_messages_recus_tempo_t0[index_courant_tab_messages_recus] = currentTime;
index_courant_tab_messages_recus++;
if (index_courant_tab_messages_recus == taille_tab_messages_recus)
// Le message est valable
#ifdef DEBUG_SERIAL
Serial.println("Message recu valable");
Serial.println("Sortie / ctrl_du_message");
#endif
!! FONCTIONS COMMUNES AUX DEVICES - SYSTEMES, RELAIS, GATEWAY
!! A recopier
void onReceive(int packetSize)
if (packetSize == 0) {
message_status = 0;
return; // if there's no packet, return
taille_du_message = packetSize;
#ifdef DEBUG_SERIAL
Serial.println("Message recu...........................................");
Serial.print("Lora receive RSSI ");
Serial.print(LoRa.packetRssi());
Serial.print(" packet size ");
Serial.println(packetSize);
#endif
message_status = 1;
void nettoyage_structure_lora()
#ifdef DEBUG_SERIAL
Serial.println("nettoyage_structure_lora");
#endif
memcpy(&messageLora, &messageLoraINIT, sizeof(messageLoraINIT));
messageLora.header1 = 0x00;
messageLora.header2 = 0x00;
messageLora.version = 0x00;
messageLora.emetteur = 0x00;
messageLora.destinataire = 0x00;
messageLora.relais1 = 0x00;
messageLora.relais2 = 0x00;
messageLora.relais3 = 0x00;
messageLora.numero_du_message = 0;
messageLora.donnee1 = 0;
messageLora.donnee2 = 0;
messageLora.donnee3 = 0;
messageLora.donnee4 = false;
messageLora.checksum = 0;
for (n = 0; n < 30; n++)
messageLora.text[n] = ' ';
void init_structure_lora() // 03/04/2025
#ifdef DEBUG_SERIAL // 03/04/2025
Serial.println("Entree / init_structure_lora");
#endif
messageLoraINIT.header1 = 0x00;
messageLoraINIT.header2 = 0x00;
messageLoraINIT.version = 0x00;
messageLoraINIT.emetteur = 0x00;
messageLoraINIT.destinataire = 0x00;
messageLoraINIT.relais1 = 0x00;
messageLoraINIT.relais2 = 0x00;
messageLoraINIT.relais3 = 0x00;
messageLoraINIT.numero_du_message = 0;
messageLoraINIT.type_du_message = 0x00;
messageLoraINIT.donnee1 = 0;
messageLoraINIT.donnee2 = 0;
messageLoraINIT.donnee3 = 0;
messageLoraINIT.donnee4 = 0;
messageLoraINIT.checksum = 0;
messageLoraINIT.text[n] = ' ';
Serial.println("Sortie / init_structure_lora");
#endif
void ecriture_du_message()
#ifdef DEBUG_SERIAL
Serial.println("ecriture_du_message");
#endif
messageLora.header1 = header1_du_message;
messageLora.header2 = header2_du_message;
messageLora.version = version_du_message;
messageLora.emetteur = emetteur_du_message;
messageLora.destinataire = destinataire_du_message;
messageLora.relais1 = relais1_du_message;
messageLora.relais2 = relais2_du_message;
messageLora.relais3 = relais3_du_message;
messageLora.numero_du_message = numero_du_message;
messageLora.donnee1 = donnee1_du_message;
messageLora.donnee2 = donnee2_du_message;
messageLora.donnee3 = donnee3_du_message;
messageLora.donnee4 = donnee4_du_message;
messageLora.checksum = checksum_du_message;
*messageLora.text = *text_du_message;
void lecture_du_message()
#ifdef DEBUG_SERIAL
Serial.println("lecture_du_message");
#endif
volatile int packetReceived = 0;
packetReceived = taille_du_message;
LoRa.readBytes((byte *)&messageLora, packetReceived);
header1_du_message = messageLora.header1;
header2_du_message = messageLora.header2;
version_du_message = messageLora.version;
emetteur_du_message = messageLora.emetteur;
// numero_device = hexTodec(String(emetteur_du_message));
numero_device = emetteur_du_message; // Correction le 05/07/26
destinataire_du_message = messageLora.destinataire;
relais1_du_message = messageLora.relais1;
relais2_du_message = messageLora.relais2;
relais3_du_message = messageLora.relais3;
numero_du_message = messageLora.numero_du_message;
type_du_message = messageLora.type_du_message;
donnee1_du_message = messageLora.donnee1;
donnee2_du_message = messageLora.donnee2;
donnee3_du_message = messageLora.donnee3;
donnee4_du_message = messageLora.donnee4;
checksum_du_message = messageLora.checksum;
*text_du_message = *messageLora.text;
#ifdef DEBUG_SERIAL
// display des données reçues
Serial.print("/h1=" + String(header1_du_message) + "/h2/=" + String(header2_du_message) + "/ver=" + String(version_du_message) + "/rel=" + String(relais1_du_message) + "-" + String(relais2_du_message) + "-" + String(relais3_du_message) + "/De=" + String(emetteur_du_message) + "/num dev=" + String(numero_device) + "/A=" + String(destinataire_du_message) + "/Num=" + String(numero_du_message));
Serial.println("/type=" + String(type_du_message) + "/d1=" + String(donnee1_du_message) + "/d2=" + String(donnee2_du_message) + "/d3=" + String(donnee3_du_message) + "/d4=" + String(donnee4_du_message) + "/check=" + String(checksum_du_message) + " text = " + String(text_du_message));
#endif
packetReceived = 0; // clear for next time
void sendMessage() {
LoRa.beginPacket(); // start packet
LoRa.write((byte *)&messageLora, sizeof(messageLora)); // transmit packet
LoRa.endPacket(true); // finish packet and send it
#ifdef DEBUG_SERIAL
Serial.print("Message envoyé : ");
Serial.print("Sent to: 0x" + String(messageLora.destinataire));
Serial.print(" - From: 0x" + String(messageLora.emetteur));
Serial.print(" - Message ID: " + String(messageLora.numero_du_message));
Serial.print("Message: " + *messageLora.text);
//Serial.println("Msg envoyé " + String(msgCount) + " destination= " + String(destination));
#endif
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent, 1, "Msg sent ", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent + increment_ligne * 1, 1, "De=" + String(messageLora.emetteur) + "/A=" + String(messageLora.destinataire), 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent + increment_ligne * 2, 1, "Num=" + String(messageLora.numero_du_message), 1);
#endif
void displayOLED(int clearEcran, int ClearLigne, int positionHorizontale, int positionVerticale, int tailleText, String messageText, int couleur)
// Affichage OLED
if (clearEcran == 1) {
display.clearDisplay();
if (ClearLigne == 1)
nettoyage_ligne_OLED(positionVerticale, couleur);
display.setTextColor(couleur);
display.setTextSize(tailleText);
display.setCursor(positionHorizontale, positionVerticale);
display.print(messageText);
display.display();
#endif
void nettoyage_ligne_OLED(int ligne_a_nettoyer, int couleur_ligne)
const int largeur_ecran = 127;
const int hauteur_d_une_ligne = 7;
int couleur_inverse = 0;
if (couleur_ligne == 1)
if (couleur_ligne == 0)
couleur_inverse = 1;
for (int h = ligne_a_nettoyer; h < ligne_a_nettoyer + hauteur_d_une_ligne; h++) {
for (int l = 0; l < largeur_ecran; l++) {
display.drawPixel(l, h, couleur_inverse);
#endif
void onGdonnee1OUTChange() {
// Add your code here to act upon GFDdonnee1OUT change
void onGdonnee2OUTChange() {
// Add your code here to act upon GFDdonnee2OUT change
void onGdonnee3OUTChange() { // 29/12/2024
// Add your code here to act upon GFDdonnee3OUT change
void onGdonnee4OUTChange() { // 29/12/2024
// Add your code here to act upon GFDdonnee4OUT change
void onGcapteurIDOUTChange() {
// Add your code here to act upon GFDcapteurIDOUT change
void onGdonneeMAJOUTChange() {
// Add your code here to act upon GFDdonneeMAJOUT change
#endif
