I try to manipulate the esp32 port to run 74HC4067. However, I only found an example of arduino uno . Could you guy show me how to manipulate the port of esp32 to run 74HC4067 ?
how internet example manipulate the port of uno
DDRD = B11111111; // set PORTD (digital 7~0) to outputs
void setPin(int outputPin)
// function to select pin on 74HC4067
PORTD = controlPins[outputPin];
Full code found on internet:
// 74HC4067 multiplexer demonstration (16 to 1)
// control pins output table in array form
// see truth table on page 2 of TI 74HC4067 data sheet
// connect 74HC4067 S0~S3 to Arduino D7~D4 respectively
// connect 74HC4067 pin 1 to Arduino A0
byte controlPins[] = {B00000000,
B10000000,
B01000000,
B11000000,
B00100000,
B10100000,
B01100000,
B11100000,
B00010000,
B10010000,
B01010000,
B11010000,
B00110000,
B10110000,
B01110000,
B11110000 };
// holds incoming values from 74HC4067
byte muxValues[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
void displayData()
// dumps captured data from array to serial monitor
Serial.println("Values from multiplexer:");
Serial.println("========================");
for (int i = 0; i < 16; i++)
Serial.print("input I");
Serial.print(i);
Serial.print(" = ");
Serial.println(muxValues[i]);
setPin(i); // choose an input pin on the 74HC4067
muxValues[i]=analogRead(0); // read the vlaue on that pin and store in array
// display captured data
displayData();
delay(2000);
