ESP32 multiple digital ds18b20 and analog sensors softAP
Hello guys, I have set up an ESP32 to work as an access point with an Async webserver serving 3 sensors --> 2 digital (Temp - ds18b20) and 1 analog for pressure (will add 1 more as soon as this works :smiley: ).
Everything works as expected, the only issue is that after the addition of the second digital sensor it stopped auto refreshing the values on the website.
Code:
  Nicolas Constantinou
// Import required libraries
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is connected to GPIO 4
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
DeviceAddress sensor1 = { 0x28, 0x12, 0x9D, 0xD1, 0xD, 0x0, 0x0, 0xEE };
DeviceAddress sensor2 = { 0x28, 0xB5, 0xD5, 0x7, 0xB6, 0x1, 0x3C, 0x4C };
// Variables to store temperature values
String temperatureC1 = "";
String temperatureC2 = "";
String pressureValuePSI = "";
// Float Vars to store pressure values - NEW
const int pressureInput = 32; //select the analog input pin for the pressure OIL
//const int pressureInput2 = A2; //select the analog input pin for the pressure of FUEL
const int pressureZero = 285.3; //analog reading of pressure transducer at 0psi
const int pressureMax = 4095; //analog reading of pressure transducer at 100psi
const int pressuretransducermaxPSI = 100; //psi value of transducer being used
//const int baudRate = 115200; //constant integer to set the baud rate for serial monitor
//const int sensorreadDelay = 250; //constant integer to set the sensor read delay in milliseconds
String pressureValue = ""; //variable to store the value coming from the pressure transducer
//Call Sensors and store actual value after equation to string
String readPressureValues () {
    float pressureValueRead = analogRead(pressureInput); //reads value from input pin and assigns to variable
          pressureValuePSI = (((pressureValueRead-pressureZero)*pressuretransducermaxPSI)/(pressureMax-pressureZero))/14.504; //conversion equation to convert analog reading to psi
            Serial.print("OIL  Press:"); //prints label
            Serial.print(pressureValuePSI); //prints value from previous line to serial
            Serial.println("bar"); //prints label to serial
            Serial.println(pressureValueRead);
     return String(pressureValuePSI);
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 300;
// Replace with your network credentials - CHANGED
const char *ssid = "ESP32CarGauges";
const char *password = "123456789";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDSTemperatureC1() {
  // Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
  sensors.requestTemperatures();
  float tempC = sensors.getTempC(sensor1);
  if (tempC == -127.00) {
    Serial.println("Failed to read from DS18B20 sensor 1");
    return "--";
    Serial.print("Temperature 1 Celsius: ");
    Serial.println(tempC);
  return String(tempC);
String readDSTemperatureC2() {
  float tempC = sensors.getTempC(sensor2);
    Serial.println("Failed to read from DS18B20 sensor 2");
    return "--";
    Serial.print("Temperature 2 Celsius: ");
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <style>
    html {
     font-family: Arial;
     display: inline-block;
     margin: 0px auto;
     text-align: center;
    h2 { font-size: 3.0rem; }
    p { font-size: 3.0rem; }
    .units { font-size: 1.2rem; }
    .ds-labels{
      font-size: 1.5rem;
      vertical-align:middle;
      padding-bottom: 15px;
  </style>
</head>
<body>
  <h2>ESP32 Car Gauges</h2>
  <p>
    <span class="ds-labels">Temperature</span><br>
    <span id="temperaturec">%TEMPERATUREC1%</span>
    <sup class="units">&deg;C</sup>
  </p>
    <p>
      <p>
    <span id="temperaturec">%TEMPERATUREC2%</span>
  </p>
    <p>
    <span class="ds-labels">Oil Pressure</span><br>
    <span id="pressureValue">%pressureValue%</span>
    <sup class="units">BAR</sup>
  </p>
</body>
<script>
setInterval(function ( ) {
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      document.getElementById("temperaturec1").innerHTML = this.responseText;
  xhttp.open("GET", "/temperaturec1", true);
  xhttp.send();
      document.getElementById("temperaturec2").innerHTML = this.responseText;
  xhttp.open("GET", "/temperaturec2", true);
  xhttp.send();
      document.getElementById("pressureValue").innerHTML = this.responseText;
  xhttp.open("GET", "/pressureValue", true);
  xhttp.send();
}, 50) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DS18B20 values - NEW - pressure values too
String processor(const String& var) {
  //Serial.println(var);
  if (var == "TEMPERATUREC1") {
    return temperatureC1;
  else if (var == "TEMPERATUREC2") {
    return temperatureC2;
  else if (var == "pressureValue") {
    return pressureValuePSI;
  return String();
  // Serial port for debugging purposes
  // Start up the DS18B20 library
  sensors.begin();
  //Serial.println(xPortGetCoreID());
  //Declare strings to be used by webserver
  temperatureC1 = readDSTemperatureC1();
  temperatureC2 = readDSTemperatureC2();
  pressureValue = readPressureValues() ;
  // Wi-Fi Soft AP start
  WiFi.softAP(ssid, password);
  // Print ESP Local IP Address
  Serial.print("IP address: ");
  Serial.println(WiFi.softAPIP());
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/html", index_html, processor);
  server.on("/temperaturec1", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/plain", temperatureC1.c_str());
  server.on("/temperaturec2", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/plain", temperatureC2.c_str());
  server.on("/pressureValue", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/plain", pressureValue.c_str());
  // Start server
  server.begin();
  if ((millis() - lastTime) > timerDelay) {
    pressureValue = readPressureValues () ;
    lastTime = millis();
You didn't change the ID of the corresponding HTML element, both elements have the ID "temperaturec".
