ESP32_New_TimerInterrupt library
Why do we need this ESP32_New_TimerInterrupt library
Features
This library enables you to use Interrupt from Hardware Timers on an ESP32, ESP32_S2/C3-based board with ESP32 core v2.0.0-rc1+ to avoid the usage of deprecated functions. Check Deprecation warnings with esp32-v2.0.0-rc1
Currently supported Boards
- ESP32 boards, such as ESP32_DEV, etc.
- ESP32S2-based boards, such as ESP32S2_DEV, ESP32_S2 Saola, etc.
- ESP32C3-based boards, such as ESP32C3_DEV, etc.
Changelog
Releases v1.0.0
- Initial coding for ESP32, ESP32_S2, ESP32_C3 boards with ESP32 core v2.0.0-rc1+
Examples
- Argument_None
- ISR_RPM_Measure
- ISR_Switch
- ISR_Timer_4_Switches
- ISR_Timer_Complex
- ISR_Timer_Switch
- ISR_Timer_Switches
- RPM_Measure
- SwitchDebounce
- TimerInterruptTest
- Change_Interval.
- ISR_16_Timers_Array
- ISR_16_Timers_Array_Complex.
Example ISR_16_Timers_Array_Complex on ESP32S2_DEV
The following is the sample terminal output when running example ISR_16_Timers_Array_Complex on ESP32S2_DEV
Starting ISR_16_Timers_Array_Complex on ESP32S2_DEV
ESP32_New_TimerInterrupt v1.0.0
CPU Frequency = 240 MHz
Starting ITimer OK, millis() = 2537
SimpleTimer : 2, ms : 12542, Dms : 10004
Timer : 0, programmed : 5000, actual : 5008
Timer : 1, programmed : 10000, actual : 0
Timer : 2, programmed : 15000, actual : 0
Timer : 3, programmed : 20000, actual : 0
Timer : 4, programmed : 25000, actual : 0
Timer : 5, programmed : 30000, actual : 0
Timer : 6, programmed : 35000, actual : 0
Timer : 7, programmed : 40000, actual : 0
Timer : 8, programmed : 45000, actual : 0
Timer : 9, programmed : 50000, actual : 0
Timer : 10, programmed : 55000, actual : 0
Timer : 11, programmed : 60000, actual : 0
Timer : 12, programmed : 65000, actual : 0
Timer : 13, programmed : 70000, actual : 0
Timer : 14, programmed : 75000, actual : 0
Timer : 15, programmed : 80000, actual : 0
SimpleTimer : 2, ms : 22600, Dms : 10058
Timer : 0, programmed : 5000, actual : 5000
Timer : 1, programmed : 10000, actual : 10000
Timer : 2, programmed : 15000, actual : 15008
Timer : 3, programmed : 20000, actual : 20008
SimpleTimer : 2, ms : 32659, Dms : 10059
Timer : 2, programmed : 15000, actual : 15000
Timer : 4, programmed : 25000, actual : 25008
Timer : 5, programmed : 30000, actual : 30008
SimpleTimer : 2, ms : 42718, Dms : 10059
Timer : 3, programmed : 20000, actual : 20000
Timer : 6, programmed : 35000, actual : 35008
Timer : 7, programmed : 40000, actual : 40008
SimpleTimer : 2, ms : 52778, Dms : 10060
Timer : 4, programmed : 25000, actual : 25000
Timer : 8, programmed : 45000, actual : 45008
Timer : 9, programmed : 50000, actual : 50008
SimpleTimer : 2, ms : 62839, Dms : 10061
Timer : 5, programmed : 30000, actual : 30000
Timer : 10, programmed : 55000, actual : 55008
Timer : 11, programmed : 60000, actual : 60008
SimpleTimer : 2, ms : 72900, Dms : 10061
Timer : 6, programmed : 35000, actual : 35000
Timer : 12, programmed : 65000, actual : 65008
Timer : 13, programmed : 70000, actual : 70008
SimpleTimer : 2, ms : 82962, Dms : 10062
Timer : 7, programmed : 40000, actual : 40000
Timer : 14, programmed : 75000, actual : 75008
Timer : 15, programmed : 80000, actual : 80008
