Esp32 no video output but only shows white screen with broken image icon
hello everyone, i would like to ask that if you could take a look on whats the problem of my coding where i cannot see the video webstreaming even tho i can get on the designated IP `Use code tags to format code for the forum
#include "esp_camera.h"
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
HardwareSerial UNOSerial(2);
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
// Camera-related constants
camera_config_t config;
const char* ssid     = "LLLLLLLLLLLLLL";
const char* password = "59615330";
IPAddress staticIP(192, 168, 1, 150);
IPAddress gateway(192, 168, 1, 254);
IPAddress subnet(255, 255, 255, 0);
AsyncWebServer server(80);
AsyncWebSocket wsCamera("/Camera");
AsyncWebSocket wsData("/Data");
uint32_t cameraClientId = 0;
const char* htmlHomePage PROGMEM = R"HTMLHOMEPAGE(
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no">
  <style>
    .noselect {
      -webkit-touch-callout: none;
      -webkit-user-select: none;
      -khtml-user-select: none;
      -moz-user-select: none;
      -ms-user-select: none;
      user-select: none;
    .container {
      display: flex;
    .video-container {
      flex: 1;
      display: flex;
      flex-direction: column;
      align-items: center;
  </style>
</head>
<body class="noselect" style="background-color:white">
  <div class="container">
    <div class="video-container">
      <img id="cameraImage" src="" style="width:400px;height:250px">
    </div>
  </div>
</body>
</html>
)HTMLHOMEPAGE";
void handleRoot(AsyncWebServerRequest *request) {
  request->send_P(200, "text/html", htmlHomePage);
void handleNotFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "File Not Found");
void onCameraWebSocketEvent(AsyncWebSocket *server, AsyncWebSocketClient *client, AwsEventType type, void *arg, uint8_t *data, size_t len) {
  switch (type) {
    case WS_EVT_CONNECT:
      Serial.printf("WebSocket client #%u connected from %s\n", client->id(), client->remoteIP().toString().c_str());
      cameraClientId = client->id();
    case WS_EVT_DISCONNECT:
      Serial.printf("WebSocket client #%u disconnected\n", client->id());
      cameraClientId = 0;
    case WS_EVT_DATA:
      // Handle WebSocket data here
    case WS_EVT_PONG:
    case WS_EVT_ERROR:
    default:
void setupCamera() {
  UNOSerial.begin(115200, SERIAL_8N1, 12, 13);
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_HD;
  config.jpeg_quality = 15;
  config.fb_count = 1;
  // Camera initialization
   esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
void sendCameraPicture() {
  if (cameraClientId == 0) {
    return;
  unsigned long startTime1 = millis();
  // Capture a frame
  camera_fb_t *fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Frame buffer could not be acquired");
    return;
  unsigned long startTime2 = millis();
  wsCamera.binary(cameraClientId, fb->buf, fb->len);
  esp_camera_fb_return(fb);
  // Wait for the message to be delivered
  while (true) {
    AsyncWebSocketClient *clientPointer = wsCamera.client(cameraClientId);
    if (!clientPointer || !(clientPointer->queueIsFull())) {
  unsigned long startTime3 = millis();
  Serial.printf("Time taken Total: %d|%d|%d\n", startTime3 - startTime1, startTime2 - startTime1, startTime3 - startTime2);
void setup(void) {
  if (WiFi.config(staticIP, gateway, subnet) == false) {
    Serial.println("Configuration failed.");
  WiFi.begin(ssid, password);
    Serial.print("Connecting...\n\n");
  Serial.print("Local IP: ");
  Serial.print("Subnet Mask: ");
  Serial.println(WiFi.subnetMask());
  Serial.print("Gateway IP: ");
  Serial.println(WiFi.gatewayIP());
  server.on("/", HTTP_GET, handleRoot);
  server.onNotFound(handleNotFound);
  // Set event handlers for the camera WebSocket
  wsCamera.onEvent(onCameraWebSocketEvent);
  server.addHandler(&wsCamera);
  server.begin();
  Serial.println("HTTP server started");
  setupCamera();
  wsCamera.cleanupClients();
  sendCameraPicture();
  while (UNOSerial.available()) {
    char c = UNOSerial.read();
    Serial.write(c);
 wsData.text(0, String(c));
  // Handle data WebSocket events here
  wsData.cleanupClients();
  // Add your data processing logic for wsData here
if you notice i have my hardwareserial which i am recieving a data from my reciever which it works but the problem is my video livestreaming suddenly wont function i have my original code where i havent put a hardwareserial here
#include <Arduino.h>
#include <WiFi.h>
#define LIGHT_PIN 4
const int PWMLightChannel = 4;
<!DOCTYPE html>
<!DOCTYPE html>
<html>
  <head>
    <style>
      .noselect {
        user-select: none;
      .slidecontainer {
        width: 100%;
      .slider {
        -webkit-appearance: none;
        width: 100%;
        height: 20px;
        border-radius: 5px;
        background: #d3d3d3;
        outline: none;
        opacity: 0.7;
        -webkit-transition: .2s;
        transition: opacity .2s;
      .slider:hover {
        opacity: 1;
      .slider::-webkit-slider-thumb {
        appearance: none;
        width: 40px;
        height: 40px;
        border-radius: 50%;
        background: red;
        cursor: pointer;
      .slider::-moz-range-thumb {
        width: 40px;
        height: 40px;
        border-radius: 50%;
        background: red;
        cursor: pointer;
    </style>
  </head>
  <body class="noselect" align="center" style="background-color:white">
    <table id="mainTable" style="width:400px;margin:auto;table-layout:fixed" CELLSPACING=10>
      <tr>
        <img id="cameraImage" src="" style="width:400px;height:250px"></td>
      </tr>
      <tr /><tr />
      <tr>
        <td style="text-align:left"><b>Light:</b></td>
        <td colspan=2>
          <div class="slidecontainer">
            <input type="range" min="0" max="255" value="0" class="slider" id="Light" oninput='sendButtonInput("Light", value)'>
          </div>
        </td>
      </tr>
    </table>
    <script>
      var webSocketCameraUrl = "ws:\/\/" + window.location.hostname + "/Camera";
      var webSocketServoInputUrl = "ws:\/\/" + window.location.hostname + "/ServoInput";
      var websocketCamera;
      var websocketServoInput;
      function initCameraWebSocket() {
        websocketCamera = new WebSocket(webSocketCameraUrl);
        websocketCamera.binaryType = 'blob';
        websocketCamera.onopen = function (event) {};
        websocketCamera.onclose = function (event) { setTimeout(initCameraWebSocket, 2000); };
        websocketCamera.onmessage = function (event) {
          var imageId = document.getElementById("cameraImage");
          imageId.src = URL.createObjectURL(event.data);
      function initServoInputWebSocket() {
        websocketServoInput = new WebSocket(webSocketServoInputUrl);
        websocketServoInput.onopen = function (event) {
          var lightButton = document.getElementById("Light");
          sendButtonInput("Light", lightButton.value);
        websocketServoInput.onclose = function (event) { setTimeout(initServoInputWebSocket, 2000); };
        websocketServoInput.onmessage = function (event) {};
      function initWebSocket() {
        initCameraWebSocket();
        initServoInputWebSocket();
      function sendButtonInput(key, value) {
        var data = key + "," + value;
        websocketServoInput.send(data);
      window.onload = initWebSocket;
      document.getElementById("mainTable").addEventListener("touchend", function (event) {
        event.preventDefault()
    </script>
  </body>
</html>
)HTMLHOMEPAGE";
                      AwsEventType type,
                      void *arg,
                      uint8_t *data,
                      size_t len)
  switch (type)
      cameraClientId = 0;
    case WS_EVT_DATA:
    case WS_EVT_PONG:
    case WS_EVT_ERROR:
    default:
void setupCamera()
  if (err != ESP_OK)
    return;
    return;
  // Capture a frame
  if (!fb)
    return;
  while (true)
void setup(void)
  server.begin();
  setupCamera();
