esp32 node32s wifi and reset
I have a prog which tests interrupt timer with software reset..it runs perfectly ok.
I have the exact same code but with the addition of a wifi connect...this gives a meditation error and core dump at the point of interrupt/reset....
does anybody know if there is an incompatibility issue between wifi and interrupt timer/reset?
I have searched and found many issues with interrupt reset from the early days of esp32 but none that seem relevant.
no wifi
//  test the interrupt timer
const int wdtTimeout = 300000;                                      //time in ms to trigger the interrupt(5 mins)
hw_timer_t *timer = NULL;
int counter;
void IRAM_ATTR resetModule()
  esp_restart();
  Serial.begin(19200);
  Serial.println("running setup");
  timer = timerBegin(0, 80, true);                            //timer 0, div 80
  timerAttachInterrupt(timer, &resetModule, true);            //attach interrupt routine
  timerAlarmWrite(timer, wdtTimeout * 1000, false);          //set interrupt time us
  timerAlarmEnable(timer);                                      //enable interrupt
 delay(60000);
 counter++ ;                              //display 1 minute intervals
 Serial.println(counter);
with wifi
//  test the interrupt timer with wifi
#include <WiFi.h>
const char* ssid       = "littleshark";
const char* password   = "xxx";
int counter;
  esp_restart();
//-------------connect to WiFi-------------
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
      Serial.print(".");
  Serial.println(" CONNECTED");
 delay(60000);
