Hi Folks I am on ubuntu 22,04
I cant make the upload I installed the ESP32 module
I am using in preferences
https://dl.espressif.com/dl/package_esp32_index.json
afterwards installed ESP32.
Also selected the card Board manager >ESP32>ESP32 Dev Module,
I also have tested ESP32>ESP32 Wrover module,
I get followingg error:
Build options changed, rebuilding all
Sketch uses 197736 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13084 bytes (3%) of dynamic memory, leaving 314596 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port /dev/ttyS0
Connecting........_____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch
_
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header```
Please help me out
I also downloaded the driver from
https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all
but when I compile I get followingg error:
make -C /lib/modules/5.15.0-56-generic/build M=/home/xsisec/Downloads/CH341SER_LINUX
make[1]: Entering directory '/usr/src/linux-headers-5.15.0-56-generic'
CC [M] /home/xsisec/Downloads/CH341SER_LINUX/ch34x.o
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c: In function ‘ch34x_close’:
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:591:9: error: unknown type name ‘wait_queue_t’; did you mean ‘wait_event’?
591 | wait_queue_t wait;
| wait_event
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:591:22: warning: unused variable ‘wait’ [-Wunused-variable]
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:590:14: warning: unused variable ‘timeout’ [-Wunused-variable]
590 | long timeout;
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:589:13: warning: unused variable ‘bps’ [-Wunused-variable]
589 | int bps;
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c: At top level:
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:1297:27: error: initialization of ‘unsigned int (*)(struct tty_struct )’ from incompatible pointer type ‘int ()(struct tty_struct )’ [-Werror=incompatible-pointer-types]
1297 | .write_room = ch34x_write_room,
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:1297:27: note: (near initialization for ‘ch34x_device.write_room’)
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:1298:28: error: initialization of ‘unsigned int ()(struct tty_struct )’ from incompatible pointer type ‘int ()(struct tty_struct *)’ [-Werror=incompatible-pointer-types]
1298 | .chars_in_buffer = ch34x_chars_in_buffer,
/home/xsisec/Downloads/CH341SER_LINUX/ch34x.c:1298:28: note: (near initialization for ‘ch34x_device.chars_in_buffer’)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:297: /home/xsisec/Downloads/CH341SER_LINUX/ch34x.o] Error 1
make[1]: *** [Makefile:1903: /home/xsisec/Downloads/CH341SER_LINUX] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.15.0-56-generic'
make: *** [Makefile:5: default] Error 2
I Also tested following piece in the preferences:
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
Archiving built core (caching) in: /tmp/arduino_cache_297087/core/core_esp32_esp32_esp32s2_CDCOnBoot_default,MSCOnBoot_default,DFUOnBoot_default,UploadMode_default,PSRAM_disabled,PartitionScheme_default,CPUFreq_240,FlashMode_qio,FlashFreq_80,FlashSize_4M,UploadSpeed_921600,DebugLevel_none,EraseFlash_none_52bf19a6e2a33ef9e88e633d13bcdebe.a
Sketch uses 174874 bytes (13%) of program storage space. Maximum is 1310720 bytes.
Global variables use 9876 bytes (3%) of dynamic memory, leaving 317804 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Connecting.....................................An error occurred while uploading the sketch
A fatal error occurred: Failed to connect to ESP32-S2: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Many thanks in advance
