ESP32 Not working... Exit status 2
The ESP32 Is not taking in any code... and this comes up in the logs...
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:esp32doit-devkit1:DebugLevel=none,FlashFreq=80,UploadSpeed=921600 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/272263075/build --build-path /tmp/arduino-build-B04EE2083656C0332FBA4519FD05D098 /tmp/272263075/Science_Fair_Project_feb20a
Sketch uses 1115281 bytes (85%) of program storage space. Maximum is 1310720 bytes.
Global variables use 51544 bytes (15%) of dynamic memory, leaving 276136 bytes for local variables. Maximum is 327680 bytes.
Upload started
Programming with: Serial
Flashing with command:C:/Users/admin/.arduino-create/esp32/esptool_py/4.2.1/esptool.exe --chip esp32 --port COM7 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 C:/Users/admin/AppData/Local/Temp/extrafiles626355886/Science_Fair_Project_feb20a.bootloader.bin 0x8000 C:/Users/admin/AppData/Local/Temp/extrafiles626355886/Science_Fair_Project_feb20a.partitions.bin 0xe000 C:/Users/admin/AppData/Local/Temp/extrafiles626355886/tools/partitions/boot_app0.bin 0x10000 C:/Users/admin/AppData/Local/Temp/arduino-create-agent389540299/Science_Fair_Project_feb20a.bin
esptool.py v4.2.1
Serial port COM7
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0xb)! The chip needs to be in download mode.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
I use the Online Web Editor for IOT cloud.
I tried the Boot+En Button method, Didnt work.
I switched through Many Esp32
With the IDE Serial monitor screen showing;
Hold down the Boot switch.
Presss and release the EN\Reset switch.
What text appears in the IDE Serial monitor ?
Some dev-board based on ESP32 are not able to entering in download mode automatically.
You can fix quickly this issue with a small capacitor between GND and EN pins.
In this tutorial is used a electrolytic 10uF, but can be also smaller (with mine I've used a 100nF polypropylene capacitor)
