ESP32 not working on IDE
I have worked on few projects with esp32. But, today, suddenly my ide has stopped working. Can someone help ?
I have already
  1. uninstalled and reinstalled Arduino IDE
  2. checked the authentic version of the esp32 add-on
  3. checked other versions of the add-on
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default, QIO, 80MHz, 4MB (32Mb), 921600, Info"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\NEW\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\NEW\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\NEW\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=info -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\NEW\AppData\Local\Temp\arduino_build_905498 -warnings=none -build-cache C:\Users\NEW\AppData\Local\Temp\arduino_cache_859529 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\esptool\2.3.1 -prefs=runtime.tools.esptool-2.3.1.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\esptool\2.3.1 -prefs=runtime.tools.mkspiffs.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\NEW\Documents\Arduino\sketch_jun04a\sketch_jun04a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\NEW\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\NEW\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\NEW\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=info -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\NEW\AppData\Local\Temp\arduino_build_905498 -warnings=none -build-cache C:\Users\NEW\AppData\Local\Temp\arduino_cache_859529 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\esptool\2.3.1 -prefs=runtime.tools.esptool-2.3.1.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\esptool\2.3.1 -prefs=runtime.tools.mkspiffs.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\NEW\Documents\Arduino\sketch_jun04a\sketch_jun04a.ino
Using board 'esp32' from platform in folder: C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
Using core 'esp32' from platform in folder: C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
cmd /c if exist "C:\Users\NEW\Documents\Arduino\sketch_jun04a\partitions.csv" COPY /y "C:\Users\NEW\Documents\Arduino\sketch_jun04a\partitions.csv" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\partitions.csv"
cmd /c if not exist "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\partitions.csv" if exist "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\partitions.csv" COPY "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\partitions.csv" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\partitions.csv"
cmd /c if not exist "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\partitions.csv" COPY "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\partitions\default.csv" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\partitions.csv"
    1 file(s) copied.
cmd /c IF EXIST "C:\Users\NEW\Documents\Arduino\sketch_jun04a\bootloader.bin" ( COPY /y "C:\Users\NEW\Documents\Arduino\sketch_jun04a\bootloader.bin" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch_jun04a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\bootloader.bin" ( COPY "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\bootloader.bin" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch_jun04a.ino.bootloader.bin" ) ELSE ( COPY /y "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\sdk\esp32\bin\bootloader_qio_80m.bin" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch_jun04a.ino.bootloader.bin" ) )
    1 file(s) copied.
cmd /c if exist "C:\Users\NEW\Documents\Arduino\sketch_jun04a\build_opt.h" COPY /y "C:\Users\NEW\Documents\Arduino\sketch_jun04a\build_opt.h" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\build_opt.h"
cmd /c if not exist "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\build_opt.h" type nul > "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\build_opt.h"
Detecting libraries used...
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-"C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch\sketch_jun04a.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=3 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\NEW\AppData\Local\Temp\arduino_build_905498/build_opt.h" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch\sketch_jun04a.ino.cpp" -o "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=3 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\NEW\AppData\Local\Temp\arduino_build_905498/build_opt.h" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch\sketch_jun04a.ino.cpp" -o "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\sketch\sketch_jun04a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-gcc" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=3 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\NEW\AppData\Local\Temp\arduino_build_905498/build_opt.h" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\esp32-hal-bt.c" -o "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\core\esp32-hal-bt.c.o"
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-gcc" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=3 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\NEW\AppData\Local\Temp\arduino_build_905498/build_opt.h" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\esp32-hal-adc.c" -o "C:\Users\NEW\AppData\Local\Temp\arduino_build_905498\core\esp32-hal-adc.c.o"
In file included from C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include/driver/adc.h:14:0,
             from C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\esp32-hal-adc.c:20:
C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include/hal/adc_types.h:90:27: error: expected ',' or '}' before 'attribute'
 ADC_DIGI_FORMAT_12BIT __attribute__((deprecated)),  /*!<ADC to DMA data format,                [15:12]-channel, [11: 0]-12 bits ADC data (`adc_digi_output_data_t`). Note: For single convert mode. */
cc1.exe: warning: unrecognized command line option '-Wno-frame-address'
"C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-gcc" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=3 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0
In file included from C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include/hal/dac_types.h:4:0,
             from C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include/driver/dac_common.h:16,
             from C:\Users\NEW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32\esp32-hal-dac.c:22:
exit status 1
Error compiling for board ESP32 Dev Module.
i dont know if this gonna work or not, but I am suggesting this cuz u said it worked before,
got to the,
"C:\Users{USERNAME}\AppData\Local\Arduino15"
and delete Arduino15 folder and reinstall the boards!
i don't know if this gonna work or not, but worth to try I think!
Try complete Uninstall Arduino IDE and then re-install the Arduino IDE (consider using Arduino IDE 2.1.1).
Check also Installing ESP32 in Arduino IDE (Windows, Mac OS X, Linux)
