ESP32 Over the Air Upload + Send Data to Web Sever
Hello,
I followed this RandomNerdsTutorial in order to upload code wirelessly to my ESP32 S2 via OTA. ESP32 Over-the-air (OTA) Programming | Random Nerd Tutorials
I am using their exact code and it works. However, I want to send a variable output as an addition, in this case battery voltage, to the ip/serverindex window (below the upload/progress bar). Ideally, this variable would refresh each loop?
Here is the code I am using:
 * Rui Santos
 * Complete Project Details https://randomnerdtutorials.com
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
const char* host = "esp32";
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
WebServer server(80);
 * Login page
const char* loginIndex =
 "<form name='loginForm'>"
    "<table width='20%' bgcolor='A09F9F' align='center'>"
        "<tr>"
            "<td colspan=2>"
                "<center><font size=4><b>ESP32 Login Page</b></font></center>"
                "<br>"
            "</td>"
            "<br>"
            "<br>"
        "</tr>"
        "<td>Username:</td>"
        "<td><input type='text' size=25 name='userid'><br></td>"
        "</tr>"
        "<br>"
        "<br>"
        "<tr>"
            "<td>Password:</td>"
            "<td><input type='Password' size=25 name='pwd'><br></td>"
            "<br>"
            "<br>"
        "</tr>"
        "<tr>"
            "<td><input type='submit' onclick='check(this.form)' value='Login'></td>"
        "</tr>"
    "</table>"
"</form>"
"<script>"
    "function check(form)"
    "if(form.userid.value=='admin' && form.pwd.value=='admin')"
    "window.open('/serverIndex')"
    "else"
    " alert('Error Password or Username')/*displays error message*/"
"</script>";
 * Server Index Page
const char* serverIndex =
"<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js'></script>"
"<form method='POST' action='#' enctype='multipart/form-data' id='upload_form'>"
   "<input type='file' name='update'>"
        "<input type='submit' value='Update'>"
    "</form>"
 "<div id='prg'>progress: 0%</div>"
 "<script>"
  "$('form').submit(function(e){"
  "e.preventDefault();"
  "var form = $('#upload_form')[0];"
  "var data = new FormData(form);"
  " $.ajax({"
  "url: '/update',"
  "type: 'POST',"
  "data: data,"
  "contentType: false,"
  "processData:false,"
  "xhr: function() {"
  "var xhr = new window.XMLHttpRequest();"
  "xhr.upload.addEventListener('progress', function(evt) {"
  "if (evt.lengthComputable) {"
  "var per = evt.loaded / evt.total;"
  "$('#prg').html('progress: ' + Math.round(per*100) + '%');"
  "}, false);"
  "return xhr;"
  "success:function(d, s) {"
  "console.log('success!')"
 "error: function (a, b, c) {"
 "</script>";
 * setup function
void setup(void) {
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  /*use mdns for host name resolution*/
  if (!MDNS.begin(host)) { //http://esp32.local
    Serial.println("Error setting up MDNS responder!");
    while (1) {
  Serial.println("mDNS responder started");
  /*return index page which is stored in serverIndex */
  server.on("/", HTTP_GET, []() {
    server.sendHeader("Connection", "close");
    server.send(200, "text/html", loginIndex);
  server.on("/serverIndex", HTTP_GET, []() {
    server.send(200, "text/html", serverIndex);
  /*handling uploading firmware file */
  server.on("/update", HTTP_POST, []() {
    server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
    ESP.restart();
    HTTPUpload& upload = server.upload();
    if (upload.status == UPLOAD_FILE_START) {
      Serial.printf("Update: %s\n", upload.filename.c_str());
      if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
        Update.printError(Serial);
    } else if (upload.status == UPLOAD_FILE_WRITE) {
      /* flashing firmware to ESP*/
      if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
    } else if (upload.status == UPLOAD_FILE_END) {
      if (Update.end(true)) { //true to set the size to the current progress
        Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
  server.begin();
void loop(void) {
  server.handleClient();
  delay(1);
Does anyone know how to accomplish this? Is there a better/easier way?
Thanks!
okay, I have done it for you, this code is untested
 * Rui Santos
#include <WiFi.h>
#include <Update.h>
 * Login page
        "<tr>"
            "<td colspan=2>"
                "<br>"
            "</td>"
            "<br>"
            "<br>"
        "</tr>"
        "</tr>"
        "<br>"
        "<br>"
        "<tr>"
            "<br>"
            "<br>"
        "</tr>"
        "<tr>"
        "</tr>"
    "</table>"
"</form>"
"<script>"
    "else"
"</script>";
 * Server Index Page
    "</form>"
 "<br><br><div id='volt'> loading voltage... </div><br><br>"
  "<script>"
   "setInterval(getData, 1000);"
   "function getData() {"
           "sendData('getVolt?xx=xx',function(mm) {"
              "document.getElementById('volt').innerHTML = mm;"
   "function sendData (url,gotResp) {"
                            "var xhttp = new XMLHttpRequest();"
                            "xhttp.onreadystatechange = function() {"
                            "if (this.readyState == 4 && this.status == 200) {"
                            "gotResp( this.responseText );"
                            "xhttp.open('GET', url , true);"
                            "xhttp.send();"
  "</script>"
  "<script>"
  " $.ajax({"
  "url: '/update',"
  "type: 'POST',"
  "data: data,"
  "xhr: function() {"
  "}, false);"
  "return xhr;"
 "</script>";
 * setup function
void setup(void) {
  Serial.println("");
    Serial.print(".");
  Serial.println("");
    while (1) {
  server.on("/getVolt", gettingVoltage );  //  NEWLY ADDED
    ESP.restart();
  server.begin();
void loop(void) {
  delay(1);
void gettingVoltage() {  //  NEWLY ADDED
  String xx = server.arg("xx");
  int myVoltage = random(10,20);  // generate some random voltage value
  String gg = String(myVoltage) + " Volts";
  server.send(200, "text/plain", gg); // send voltage value back to web page
