ESP32 Pico -D4 will not connect to arduino IDE
Hi all. I have a ESP32 pico D4 chip that i want to program. The circuit is very bare it includes just the chip a pull up resistor for the enable pin and a programming port. The port I designed is connecting 6 pins to a serial bridge.
GND-GND
EN pin9-EN
IO/0 pin 23 - IO/0
U0TX pin 41 - RX
U0RX pin 40 -TX
3.3v - 3.3V
The chip powers up and sucks 5mA of current so I know it is on and functioning properly. However the connection sequence goes on forever.
I'm using the latest Arduino version 1.8.12 and these programming parameters.
Board: esp32 pico kit
upload speed: 921600
partition scheme: default
Core debug LV: None
parallel programmer.
I'm running the latest version of Windows 7.
I have dozens of ESP32 wroom boards that program just fine. I can't get one of theses pico chips to program at all.
What am I missing?
in this document it states that 80mA is the standard consumption and you should deliver 500mAdocument
OK that does seem suspicious now that you mention it. Here are the pins I have connected to 3.3V. Let me know If I missed any.
3.3V Connected:
VDDA_1
VDDA3P3_1
VDD3P3_RTC
VDD_SDIO
VDD3P3_CPU
VDDA_2
The only pin I have connected to ground is EP_GND which is the large power pad underneath the chip.
Where did I mess up?
maybe by signalling the boot mode using GPIO 0 & GPIO,
IO/0 pin 23 - IO/0
ah that is what you mean ! Other option would be that the chip is waiting for upload and therefore uses little power, i am reluctant but i have to ask if you have RX & TX the right way round ? For the rest i think i would have done it the same way. Check the solder work, that i would do.. it wouldn't be the first time, make sure the connections are actually conductive.
