ESP32-PICO Flash
I am using the ESP32-PICO In the documentaion it says the board should have 4Mb of Flash.
When I compile my sketch it says
Sketch uses 738126 bytes (56%) of program storage space. Maximum is 1310720 bytes.
Global variables use 37720 bytes (11%) of dynamic memory, leaving 289960 bytes for local variables. Maximum is 327680 bytes.
I read this as I have 1310720 bytes of Flash and 327680 bytes of SRAM.
Flash 1310720 B / 1024 / 1024 = 1.25 MB
SRAM 327680 B / 1024 = 320 KB
From Espressif's documentation I couldn't find out how much SRAM I am supposed to have, but I certainly seem to be coming up short with the Flash.
Is my math right? Are there large portions of Flash being used for something else here or do I need to do something to access the other 2.75 MB?
The espressif forum, its they that support the ESP32 have this thread which has a comment at the bottom which might explain why you ‘only’ have 1310720 bytes of Flash.
https://www.esp32.com/viewtopic.php?t=4086
has a comment at the bottom which might explain why you 'only' have 1310720 bytes of Flash
TLDR: The flash on ESP32 is normally divided into three parts: a file system part, and two application areas (which allows for OTA upgrades.) This is user-changeable.
Thank you both for your responses.
srnet:
How much flash memory does my ESP32 really have - ESP32 Forum
Your link took me to quite a bit of useful information. Thank you.
westfw:
Do you know if this is something I can control through an Arduino library?
