hello, i want to ask. i use 2 esp, esp a (Antares LR-ESP201)+ rf96 and esp b (LYNX-32)+ rf96. esp a serves to send sensor data to esp b using LoRa. when the distance is 10m, it shows RSSI -85 dbm. i use a frequency of 920 MHz and Spreading Factor = 8.
well when I try to do testing to send data from esp a to esp b at a distance of 200 meters. there is no data received at esp b. what should I do? pls help
esp a :
#include <SPI.h>
#include <RH_RF95.h>
#define RFM95_CS 2
#define RFM95_INT 14
#define RF95_FREQ 920.0
RH_RF95 rf95(RFM95_CS, RFM95_INT);
HardwareSerial mySerial(1); // RX=16, TX=17 (sesuaikan)
unsigned long previousMillisSend = 0;
const unsigned long sendInterval = 60000; // Kirim data tiap 1 menit
unsigned long previousMillisRead = 0;
const unsigned long readInterval = 2000; // Baca data setiap 100 ms (baca data secara cepat)
String latestData = ""; // Menyimpan data terbaru yang dibaca
// Fungsi untuk set Spreading Factor (SF) di RH_RF95
void setSpreadingFactor(uint8_t sf) {
if (sf < 6) sf = 6;
else if (sf > 12) sf = 12;
uint8_t modemConfig1 = rf95.spiRead(RH_RF95_REG_1D_MODEM_CONFIG1);
uint8_t modemConfig2 = rf95.spiRead(RH_RF95_REG_1E_MODEM_CONFIG2);
// Clear bit SF lama (bit 4-7)
modemConfig2 &= 0x0F;
// Set SF baru (bit 4-7)
modemConfig2 |= (sf << 4);
rf95.spiWrite(RH_RF95_REG_1E_MODEM_CONFIG2, modemConfig2);
Serial.print("Spreading Factor set to SF");
Serial.println(sf);
mySerial.begin(9600, SERIAL_8N1, 16, 17);
Serial.println("LoRa Bridge ESP A Starting...");
if (!rf95.init()) {
Serial.println("LoRa init failed");
while (1);
Serial.println("LoRa init OK");
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
Serial.print("Frequency set to: ");
Serial.println(RF95_FREQ);
rf95.setTxPower(20, false);
// Set SF8
setSpreadingFactor(8);
// 1. Langsung baca data setiap kali ada data yang masuk
if (mySerial.available()) {
String data = mySerial.readStringUntil('\n');
data.trim();
if (data.length() > 0) {
latestData = data; // Simpan data terbaru
Serial.println("Data from Arduino:");
Serial.println(data);
// 2. Kirim data ke ESP B setiap 1 menit sekali
if (currentMillis - previousMillisSend >= sendInterval) {
previousMillisSend = currentMillis;
if (latestData.length() > 0) {
// Kirim data via LoRa
rf95.send((uint8_t *)latestData.c_str(), latestData.length());
rf95.waitPacketSent();
Serial.println("Data sending via LoRa :");
Serial.println(latestData); // Tampilkan data yang dikirim
esp b
#include <SPI.h>
#include <WiFi.h>
#include <HTTPClient.h>
#define RFM95_CS 5 // Pin CS LoRa ESP B
#define RFM95_INT 27 // Pin interrupt LoRa ESP B
#define RF95_FREQ 920.0 // Frekuensi LoRa
const char *ssid = "HUAWEI-2.4G-FTTR"; // Ganti SSID WiFi kamu
const char *password = "Telkom123"; // Ganti password WiFi kamu
const char* http_server = "http://192.168.3.129:3000/data"; // URL server backend
if (sf < 6) sf = 6;
Serial.println(sf);
while (!Serial);
Serial.println("LoRa Receiver + HTTP Client Starting...");
// Setup LoRa
if (!rf95.init()) {
while (1);
while (1);
Serial.print("Set Frequency to: ");
// Set SF8
// Connect to WiFi (Reconnection Loop)
connectToWiFi();
// Cek pesan LoRa yang masuk
if (rf95.available()) {
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.recv(buf, &len)) {
String pesan = "";
for (int i = 0; i < len; i++) {
pesan += (char)buf[i];
pesan.trim();
Serial.println("Data received via LoRa:");
Serial.println(pesan);
// Menampilkan kekuatan sinyal (RSSI)
int rssi = rf95.lastRssi(); // Mendapatkan nilai RSSI
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
// Simpan data terbaru dan waktu terima data
latestData = pesan;
// Kirim data ke backend HTTP segera setelah menerima data
sendHTTP(latestData);
// Update waktu terakhir menerima data setelah pengiriman HTTP berhasil
// Tidak perlu lagi timeout, cukup update waktu setelah setiap pengiriman HTTP
Serial.println("Gagal menerima pesan");
// Periksa status WiFi dan coba reconnect jika terputus
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi connection lost, attempting to reconnect...");
connectToWiFi(); // Coba reconnect ke WiFi
void connectToWiFi() {
WiFi.begin(ssid, password);
Serial.print("Connecting to WiFi...");
Serial.print(".");
Serial.println("Connected to WiFi");
Serial.print("IP Address: ");
void sendHTTP(String payload) {
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http;
http.begin(http_server);
http.addHeader("Content-Type", "application/json");
Serial.println("Mengirim data ke server Node.js (HTTP):");
Serial.println(payload);
int httpResponseCode = http.POST(payload);
if (httpResponseCode > 0) {
String response = http.getString();
Serial.print("Response Code: ");
Serial.println(httpResponseCode);
Serial.print("Response: ");
Serial.println(response);
Serial.print("HTTP POST gagal, kode: ");
if (httpResponseCode == -1) {
Serial.println("Masalah dengan koneksi HTTP. Cek URL atau firewall.");
http.end();
Serial.println("WiFi tidak terhubung.");
