I am checking the feasibility of a project where an ESP32 will be reading data from a canbus of a car. The canbus pin#16 continuously provides 12V even when the car's engine is not running
(see canbus pins in the picture)
After converting the 12V to 5V of pin#16, the ESP32 can be powered. The issue is that how to power-off the ESP32 when the car's engine is not running? My idea, so-far, is to put the esp32 to sleep when there is no activity in the canbus for a certain period of time. I will be grateful if someone can advise or share his/her experience.
Don’t power off the canbus connector direct . Use a relay off an ignition switched part to power your circuit
And perhaps you should explain the reason for your advice?
If my understanding is correct, Hammy's idea is to trigger the power on/off of the arduino using "signals" from other pins than pin#16. I think this can be possible if we use a MOSFET. The trigger will come from pin#6 or pin#14 which voltage swings between 5V and 2V when the engine in running (?? still to check). I will draw and attach a circuit to explain how the power on/off trigger would work.
I found an article that describes a solution for power latching. I will try it for my case and revert.
I was proposing you use a feed from say the radio /windscreen wipers or some other ignition switched part, to power a relay that in turn connects power to you Arduino from the OBD socket .
I tried the following in a circuit simulator (iCircuit).
I use the 555 timer to trigger the powering (on) of the esp32 via a relay. The power off is triggered by esp32 when the car engine is powered off (rpm=0).
Any comment is appreciated.
Update: I changed BC547 by BC337.
Typo: In the image: the power-on pulse is from pin#6 not pin#4
A bit complex for what you need !
Take a feed from an ignition switched fuse, run that to the coil of a relay . Contact of relay switches the 12v from the OBD port to you circuit
