What I'm trying to do:
I'm turning a PS/2 keyboard from 1998 into a 8-bit synthesizer piano thing. It has an audio jack connected to one of the DAC pins, a 27 RGB led strip for cool light effects (using FastLED library) and an SSD1306 128x64 OLED display. I wrote the synthesizer part - it works. The led strip works and OLED also works. Hooray!
The problem, however, is that I can't generate clean sound with RGB led strip or OLED update processes running within the same core. Luckily, this ESP32 devkit has 2 cores. I've successfuly made the 27 RGB diodes run on the second core, but when I try to update the OLED I get tons of weird artifacts like this:
YouTube video of OLED artifacts
I really want to get the OLED working on the second core so I could do live updates while generating synth sounds.
Repro code:
#include "SSD1306Wire.h"
SSD1306Wire display(0x3c, 21, 22);
// Second core test
TaskHandle_t Task1;
unsigned long last_update;
void CoreTest(void * parameter) {
while (true) {
if (millis() - last_update >= 20) {
last_update = millis();
SSD1306_DrawSineWave(30, 64, 200);
delay(20);
int sinewave[256] = {
0, 3, 6, 9, 13, 16, 19, 22,
25, 28, 31, 34, 37, 40, 43, 46,
49, 52, 55, 58, 61, 63, 66, 69,
71, 74, 77, 79, 81, 84, 86, 89,
91, 93, 95, 97, 99, 101, 103, 105,
107, 108, 110, 112, 113, 115, 116, 117,
118, 120, 121, 122, 123, 124, 124, 125,
126, 126, 127, 127, 127, 128, 128, 128,
128, 128, 128, 128, 127, 127, 126, 126,
125, 125, 124, 123, 122, 121, 120, 119,
118, 117, 115, 114, 112, 111, 109, 108,
106, 104, 102, 100, 98, 96, 94, 92,
90, 87, 85, 83, 80, 78, 75, 73,
70, 67, 65, 62, 59, 56, 53, 51,
48, 45, 42, 39, 36, 33, 30, 27,
24, 20, 17, 14, 11, 8, 5, 2,
-2, -5, -8, -11, -14, -17, -20, -24,
-27, -30, -33, -36, -39, -42, -45, -48,
-51, -53, -56, -59, -62, -65, -67, -70,
-73, -75, -78, -80, -83, -85, -87, -90,
-92, -94, -96, -98, -100, -102, -104, -106,
-108, -109, -111, -112, -114, -115, -117, -118,
-119, -120, -121, -122, -123, -124, -125, -125,
-126, -126, -127, -127, -128, -128, -128, -128,
-128, -128, -128, -127, -127, -127, -126, -126,
-125, -124, -124, -123, -122, -121, -120, -118,
-117, -116, -115, -113, -112, -110, -108, -107,
-105, -103, -101, -99, -97, -95, -93, -91,
-89, -86, -84, -81, -79, -77, -74, -71,
-69, -66, -63, -61, -58, -55, -52, -49,
-46, -43, -40, -37, -34, -31, -28, -25,
-22, -19, -16, -13, -9, -6, -3, 0,
void SSD1306_DrawSineWave(byte amplitude, int wavelength, int move_speed) {
amplitude = 0 - 30; (height of sinde wave)
wavelength = >0; lenght in pixels of one pulse
move_speed = >=0; movement of wave, pixels per second
display.clear();
unsigned long displacement = (millis() * move_speed / 1000);
for (byte x = 0; x <= 127; x++) {
int pos0 = sinewave[((x + displacement) % wavelength) * 255 / wavelength] * amplitude / 128;
int pos1 = sinewave[((x + displacement + 1) % wavelength) * 255 / wavelength] * amplitude / 128;
display.drawLine(x, pos0 + 32, x, pos1 + 32);
display.display();
display.init();
display.flipScreenVertically();
xTaskCreatePinnedToCore(
CoreTest,
"CoreTester",
100000,
NULL,
1,
&Task1,
0
what could possibly be the culprit of this behavior?
Update 1:
Here's some insight. When updating the OLED with the same picture, the artifacts remain static. The horizontal dot artifacts seem to appear around every 16 pixels.
