ESP32 probleme de connection avec MySQL
Bonjour,
J'essaye de configurer un ESP32 pour transmettre les valeurs relevees par des capteurs (DHT22 et BMP) a une base de donnee sur un raspberry pi en local.
J'ai suivi ce tuto: ESP32/ESP8266 Insert Data into MySQL Database | Random Nerd Tutorials
Et ben... ca marche pas.....
Voila ce que j'obtient dans le serial Moniteur d"Arduino IDE :
Connected to WiFi network with IP Address: 192.168.8.136
Pressure = 1008.00 mb
Altitude = 42.21 meters
Humidity = 40.80 %
BMP Temperature = 33.50 *C
DHT Temperature = 32.40 *C
DHT + BMP Average Temp = 32.95 *C
httpRequestData: api_key= tPmAT5Ab3j7F9&sensor=GY68&location=Living room&value1=32.40&value2=40.80&value3=1008.21
Error code: -1
J'ai bien LAMP installe sur le raspi, la DB existe, etc.....
Mais j'obtient cette erreur meme lorsque le raspi est eteint.... Je pense donc qu'il y a un bug dans le code sur l'ESP32.....
Voila le code en question:
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-esp8266-mysql-database-php/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <HTTPClient.h>
#include "DHT.h"
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085.h>
// Replace with your network credentials
const char* ssid     = "Yann";
const char* password = "16421642";
// REPLACE with your Domain name and URL path or IP address with path
const char* serverName = "HTTP://192.168.8.140";
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /post-esp-data.php also needs to have the same key
String apiKeyValue = "tPmAT5Ab3j7F9";
String sensorName = "GY68";
String sensorLocation = "Living room";
// Humidity qnd Temperature
#define DHTPIN 13
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#define SEALEVELPRESSURE_HPA (1013.25)
//Pressure and Altitude
Adafruit_BMP085 bmp;
//WiFi.mode(WIFI_STA);
//WiFiServer server(80);
//WiFiClient client = server.available();
  dht.begin();
   if (!bmp.begin()) {
 Serial.println("Could not find a valid BMP085 sensor, check wiring!");
  while (1) {}
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  //Check WiFi connection status
  if(WiFi.status()== WL_CONNECTED){
    WiFiClientSecure *client = new WiFiClientSecure;
    client->setInsecure(); //don't use SSL certificate
    HTTPClient https;
  Serial.println("");
  Serial.println("");
 float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  //Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
 float p = bmp.readPressure()/100;
   Serial.print("Pressure = ");
   Serial.print(p);
   Serial.println(" mb");
  // Calculate altitude assuming 'standard' barometric
  // pressure of 1013.25 millibar = 101325 Pascal
  float a = bmp.readAltitude();
  float bt = bmp.readTemperature();
  Serial.print("Altitude = ");
  Serial.print(a);
  Serial.println(" meters");
  Serial.print("Humidity = ");
  Serial.print(h);
  Serial.println(" %\t");
  Serial.print("BMP Temperature = ");
  Serial.print(bmp.readTemperature());
  Serial.println(" *C ");
  Serial.print("DHT Temperature = ");
  Serial.print(t);
  Serial.print("DHT + BMP Average Temp = ");
  Serial.print((bt + t) /2);
    // Your Domain name with URL path or IP address with path
    https.begin(serverName);
    // Specify content-type header
    https.addHeader("Content-Type", "application/x-www-form-urlencoded");
    // Prepare your HTTP POST request data
    String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + sensorName
                          + "&location=" + sensorLocation + "&value1=" + String(dht.readTemperature())
                          + "&value2=" + String(dht.readHumidity()) + "&value3=" + String(bmp.readPressure()/100.0F) + "";
  Serial.print("httpRequestData: ");
  Serial.println(httpRequestData);
    // You can comment the httpRequestData variable above
    // then, use the httpRequestData variable below (for testing purposes without the BME280 sensor)
    //String httpRequestData = "api_key=tPmAT5Ab3j7F9&sensor=BME280&location=Office&value1=24.75&value2=49.54&value3=1005.14";
    // Send HTTP POST request
    int httpResponseCode = https.POST(httpRequestData);
    // If you need an HTTP request with a content type: text/plain
    //https.addHeader("Content-Type", "text/plain");
    //int httpResponseCode = https.POST("Hello, World!");
    // If you need an HTTP request with a content type: application/json, use the following:
    //https.addHeader("Content-Type", "application/json");
    //int httpResponseCode = https.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
    if (httpResponseCode>0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
    else {
      Serial.print("Error code: ");
    // Free resources
    https.end();
  else {
    Serial.println("WiFi Disconnected");
  //Send an HTTP POST request every 30 seconds
  delay(5000);
l'adresse IP du serveur apache sur le raspi est correcte (j'y accede depuis n'importe quel autre ordi sans probleme.....)
Une idee ? une suggestion?
Merci de votre aide
dans le tuto ils utilisent
const char* serverName = "https://example.com/post-esp-data.php";
je suppose que vous avez bien créé le script post-esp-data.php et votre URL (si votre RPi est sur cette IP) devrait être
const char* serverName = "https://192.168.8.140/post-esp-data.php";
Oui, j'ai bien cree le script "post-esp-data.php" sur le raspi... j'y accede sans probleme, et ca m'affiche:
No data posted with HTTP POST.
pour la ligne
j'ai bien moodifie pour avoir;
l'adresse du raspi et correcte, mais le moniteur serie affiche toujours:
Pressure = 1005.00 mb
Altitude = 63.55 meters
Humidity = 39.60 %
BMP Temperature = 33.30 *C
DHT Temperature = 32.10 *C
DHT + BMP Average Temp = 32.70 *C
httpRequestData: api_key=tPmAT5Ab3j7F9&sensor=GY68&location=Living room&value1=32.10&value2=39.60&value3=1005.66
Error code: -1
:sleepy:
postez le nouveau code
normalement une URL n'a pas le droit de contenir d'espace je ne sais pas si le framework remplace cela par un %20
essayez de modifier
en
String sensorLocation = "LivingRoom";
Bien vu pour l'espace vide!
J'ai modifie ce probleme, mais toujours le meme resultat...
Voila le code a jour:
  Rui Santos
#include <WiFi.h>
#include "DHT.h"
#include <Wire.h>
const char* serverName = "HTTP://192.168.8.140/post-esp-data.php";
#define DHTPIN 13
  dht.begin();
   if (!bmp.begin()) {
  while (1) {}
    Serial.print(".");
  Serial.println("");
    HTTPClient https;
  Serial.println("");
  Serial.println("");
    return;
   Serial.print(p);
  Serial.print(a);
  Serial.print(h);
  Serial.print(t);
    else {
    // Free resources
    https.end();
  else {
  delay(5000);
vous utilisez juste http, pas https donc sans doute pas besoin de faire
    HTTPClient https;
regardez ESP32 HTTP GET and HTTP POST with Arduino IDE | Random Nerd Tutorials pour faire une simple requête POST en HTTP (pas HTTPS)
Merci!
J'ai viré toutes les references a https, et maintenant, je m'approche du but!
Voila ce que je recupere dans le terminal! il y a du mieux!
Altitude = 65.98 meters
Humidity = 38.50 %
httpRequestData: api_key=tPmAT5Ab3j7F9&sensor=GY68&location=Livingroom&value1=32.40&value2=38.50&value3=1005.40
HTTP Response code: 200
Reste a verifier que tout part dans la base de donnees, et ensuite je posterais le code complet et fonctionnel!
Encore 1000 Mercis pour ton aide!
Et bien sur, un probleme solutionne endecouvre d'autres...
Tout va bien au niveau de l'ESP32, mais nada/rien/que'dalle du cote base de donnees..pfff...
Voila mes pages php...
post-esp-data.php
<?php
  Rui Santos
  of this software and associated documentation filesyo
$servername = "192.168.8.140";
$dbname = "esp_data";
$username = "yoda";
$password = "ola";
// Keep this API Key value to be compatible with the ESP32 code provided in the project page.
// If you change this value, the ESP32 sketch needs to match
$api_key_value = "tPmAT5Ab3j7F9";
$api_key= $sensor = $location = $value1 = $value2 = $value3 = "";
if ($_SERVER["REQUEST_METHOD"] == "POST") {
    $api_key = test_input($_POST["api_key"]);
    if($api_key == $api_key_value) {
        $sensor = test_input($_POST["sensor"]);
        $location = test_input($_POST["location"]);
        $value1 = test_input($_POST["value1"]);
        $value2 = test_input($_POST["value2"]);
        $value3 = test_input($_POST["value3"]);
  GNU nano 5.4                                                  esp-data.php
<!DOCTYPE html>
<html><body>
<?php
  Rui Santos
$servername = "localhost";
// REPLACE with your Database name
// REPLACE with Database user
$username = "yoda";
// REPLACE with Database user password
$password = "ola";
// Create connection
$conn = new mysqli($servername, $username, $password, $dbname);
// Check connection
if ($conn->connect_error) {
    die("Connection failed: " . $conn->connect_error);
$sql = "SELECT id, sensor, location, value1, value2, value3, reading_time FROM SensorData ORDER BY id DESC";
echo '<table cellspacing="5" cellpadding="5">
      <tr>
        <td>ID</td>
        <td>Sensor</td>
        <td>Location</td>
        <td>Value 1</td>
        <td>Value 2</td>
        <td>Value 3</td>
        <td>Timestamp</td>
      </tr>';
if ($result = $conn->query($sql)) {
    while ($row = $result->fetch_assoc()) {
        $row_id = $row["id"];
        $row_sensor = $row["sensor"];
        $row_location = $row["location"];
        $row_value1 = $row["value1"];
        $row_value2 = $row["value2"];
        $row_value3 = $row["value3"];
        $row_reading_time = $row["reading_time"];
        // Uncomment to set timezone to - 1 hour (you can change 1 to any number)
        //$row_reading_time = date("Y-m-d H:i:s", strtotime("$row_reading_time - 1 hours"));
        // Uncomment to set timezone to + 4 hours (you can change 4 to any number)
        //$row_reading_time = date("Y-m-d H:i:s", strtotime("$row_reading_time + 4 hours"));
        echo '<tr>
                <td>' . $row_id . '</td>
                <td>' . $row_sensor . '</td>
                <td>' . $row_location . '</td>
                <td>' . $row_value1 . '</td>
  GNU nano 5.4                                                  esp-data.php                                                      M
                <td>' . $row_value2 . '</td>
                <td>' . $row_value3 . '</td>
                <td>' . $row_reading_time . '</td>
              </tr>';
    $result->free();
$conn->close();
</table>
</body>
</html>
Parmis les trucs que je ne comprends pas, pourquoi je ne me prends pas un message d'erreur si problee de connexion avec MySQL...?
Vous avez copié n’importe quoi dans le script d’origine?
Prenez la version raw
https://raw.githubusercontent.com/RuiSantosdotme/ESP32-ESP8266-PHP-MySQL/master/code/post-esp-data.php
Effectivement...quand je ne fais pas n'importe quoi... Ben ca marche!
Un ENORME Merci!
Super
Bonne continuation
