ESP32 - problems reading a json response
Hi guys!
I'm trying to read weather data from a json request and extract temperature, rain and a few other things, but I have problems getting anything useful out and outputs are always 0..
My code is posted below :
#include <TimeLib.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeMono9pt7b.h>
#include <NewPing.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <time.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
#define pump_pin 5 // Output pin 5 for water pump
#define manual_pin 14 // Input pin 14 for manually starting irrigation
#define pwm_pin 23 // Pin for PWM output
#define SCREEN_ADDRESS 0x3C // See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32. GPIO21 for SDA and GPIO22 for SCL in ESP32.
Adafruit_SSD1306 display(128, 64, &Wire, -1);
// Declaring variables and settings
int button;
int start_day;
int now_day;
int now_hour;
int now_minute;
int last_minute;
int now_second;
int last_second;
int last_oxyminute;
int pwm_channel = 1;
int pwm_frequency = 25000;
int pwm_resolution = 8;
int temp_parameter = 0;
int rain_parameter = 6;
int cloud_parameter = 11;
int wind_parameter = 4;
int pres_parameter = 10;
const long lat = 59.319435;
const long lon = 18.147673;
// Wifi connection settings
const char* ssid = "devolo-guest-dd0";
const char* password = "password";
// NTP time synchronization settings
const char* ntpServer = "europe.pool.ntp.org";
const long  gmtOffset_sec = 3600;
const int   daylightOffset_sec = 3600;
// Loop time counter
long loopTime = millis();
  Serial.begin(115200); // For ESP32
  // Setup pwm frequency on channel 0
  ledcSetup(pwm_channel, pwm_frequency, pwm_resolution);  // Channel 0, 25 kHz frequency, 8-bit resolution
  ledcAttachPin(pwm_pin, pwm_channel);
  pinMode(pump_pin, OUTPUT);
  delay(50);
  // Connecting to Wifi
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  delay(50);
  Serial.println(" "); // Adding empty serial row
  // Checking internet connection and selecting time setting option
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Wifi connection failed! Rebooting..");
    delay(5000);
    ESP.restart();
  else {
    Serial.println("Wifi connection successful!");
    // Initializing NTP time
    configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
    fetchLocalTime();
    start_day = now_day;
    last_minute = now_minute;
  // OTA settings
  // Hostname defaults to esp3232-[MAC]
  ArduinoOTA.setHostname("Hostname");
  // No authentication by default
  ArduinoOTA.setPassword("Password"); // OTA password
  ArduinoOTA
    .onStart([]() {
      String type;
      if (ArduinoOTA.getCommand() == U_FLASH)
        type = "sketch";
      else // U_SPIFFS
        type = "filesystem";
      // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
      Serial.println("Start updating " + type);
    .onEnd([]() {
      Serial.println("\nEnd");
    .onProgress([](unsigned int progress, unsigned int total) {
      Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
    .onError([](ota_error_t error) {
      Serial.printf("Error[%u]: ", error);
      if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
      else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
      else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
      else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
      else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Network Ready");
  Serial.print("IP address: ");
  // Pause
  delay(50);
  // Start time for the first loop
  last_second = now_second;
void fetchLocalTime(){
  struct tm timeinfo;
  if(!getLocalTime(&timeinfo)){
    Serial.println("Failed to obtain time");
  now_hour = timeinfo.tm_hour;
  now_minute = timeinfo.tm_min;
  now_second = timeinfo.tm_sec;
  now_day = timeinfo.tm_mday;
const char fetchIndex(const char* paramName, String payload){
    int paramIndex = -1;
    // Deserialize JSON response
    DynamicJsonDocument doc(1024);
    deserializeJson(doc, payload);
    JsonArray parameters = doc["timeSeries"][0]["parameters"].as<JsonArray>();
    for (size_t i = 0; i < parameters.size(); i++) {
      const char* name = parameters[i]["name"].as<const char*>();
      if (strcmp(name, paramName) == 0) {
        paramIndex = i;
    return paramIndex;
void fetchWeather(){
  String weblink = "https://opendata-download-metanalys.smhi.se/api/category/mesan1g/version/2/geotype/point/lon/"+String(lon)+"/lat/"+String(lat)+"/data.json";
  // Make HTTP request to SMHI API
  HTTPClient http;
  http.begin(weblink);
  int httpCode = http.GET();
  if (httpCode == HTTP_CODE_OK) {
    Serial.println(".");
    // Parse JSON response
    String payload = http.getString();
    Serial.println(payload);
    // Extract data from JSON
    float temp = doc["timeSeries"][0]["parameters"]["t"][0]["values"].as<float>();
    float rain = doc["timeSeries"][0]["parameters"]["prec1h"][0]["values"].as<float>();
    int cloud = doc["timeSeries"][0]["parameters"]["tcc"][0]["values"].as<int>();
    float wind = doc["timeSeries"][0]["parameters"]["ws"][0]["values"].as<float>();
    int pres = doc["timeSeries"][0]["parameters"]["msl"][0]["values"].as<int>();
    int humi = doc["timeSeries"][0]["parameters"]["r"][0]["values"].as<int>();
    int symb = doc["timeSeries"][0]["parameters"][fetchIndex("Wsymb2",payload)][0]["values"].as<int>();
    Serial.print(F("Temp: "));
    Serial.print(temp);
    Serial.println(F(" C"));
    Serial.print(F("Rain: "));
    Serial.print(rain);
    Serial.println(F(" mm"));
    Serial.print(F("Clouds: "));
    Serial.print(cloud);
    Serial.println(F(" of 8"));
    Serial.print(F("Wind: "));
    Serial.print(wind);
    Serial.println(F(" m/s"));
    Serial.print(F("Pressure: "));
    Serial.print(pres);
    Serial.println(F(" hPa"));
    Serial.print(F("Humidity: "));
    Serial.print(humi);
    Serial.println(F(" % RH"));
    Serial.print(F("Weather: "));
    Serial.print(symb);
    Serial.println(F(" of 27"));
  else {
    Serial.println("HTTP Error: " + httpCode);
  // OTA
  ArduinoOTA.handle();
  if (millis() - loopTime > 1000) {
    // Getting time
    fetchLocalTime();
    if (now_minute != last_minute) {
      fetchWeather();
  // Reading button state for manual irrigation
  button = digitalRead(manual_pin);
  if (now_second != last_second) {
  // Rebooting daily
  if (now_day != start_day) {
    Serial.println("New day = Daily reset. Rebooting..");
    delay(5000);
    ESP.restart();
And this is the serial print it returns:
13:19:01.574 -> {"approvedTime":"2023-06-26T10:37:15Z","referenceTime":"2023-06-26T10:00:00Z","geometry":{"type":"Point","coordinates":[[18.020709,58.997085]]},"timeSeries":[{"validTime":"2023-06-26T10:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[22.1]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[17.0]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[7.8]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[144]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[4.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[51]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[55.4]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1014.3]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[2]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1995]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1988]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2488]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T09:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[22.1]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.9]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[5.7]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[143]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[3.7]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[50]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[48.8]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1014.6]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[2060]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[2052]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2552]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T08:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[21.4]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.6]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[4.7]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[139]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[2.5]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[55]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[51.7]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1014.8]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[4]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1767]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1760]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2260]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T07:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[20.9]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.0]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[3.2]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[135]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.9]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[54]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[48.5]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1015.1]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[3]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1415]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1408]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1908]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T06:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[19.5]},{"name":"tmax","levelType":"hl","level":2,"unit":"Cel","values":[20.6]},{"name":"tmin","levelType":"hl","level":2,"unit":"Cel","values":[12.6]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.4]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[2.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[89]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[67]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec12h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec24h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[49.0]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1015.3]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1104]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1096]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1596]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T05:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[17.1]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.8]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.4]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[51]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[87]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[41.8]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1015.5]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[2]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1220]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1212]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1712]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T04:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[13.7]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.2]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[29]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.2]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[100]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[23.6]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1015.8]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[0]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[543]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[536]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1036]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T03:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[11.5]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.1]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.4]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[6]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[100]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[12.8]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.0]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[8]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[276]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[268]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[768]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T02:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[11.4]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.1]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[2.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[8]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.2]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[100]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[10.5]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.2]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[0]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[104]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[96]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1168]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T01:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[11.8]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.9]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[6]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[100]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[9.3]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.4]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[1]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[0]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[120]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[112]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1028]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[1]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-26T00:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[12.3]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[0.9]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[350]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[0.8]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[100]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[13.3]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.5]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[178]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[170]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[888]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T23:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[12.7]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[272]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.0]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[93]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[19.2]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.8]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[378]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[370]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[872]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T22:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[13.5]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[14.8]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[0.6]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[333]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[0.6]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[92]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[28.3]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.0]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[520]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[512]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1012]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T21:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[14.6]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[1.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[352]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[0.5]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[89]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[42.9]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1016.9]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[2664]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[2656]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[3156]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T20:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[16.6]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.1]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[2.1]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[334]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[0.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[75]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[56.5]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.0]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1488]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1480]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[1980]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T19:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[18.8]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.4]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[3.3]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[94]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.0]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[65]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[64.5]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.2]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1604]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1596]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2096]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T18:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[20.3]},{"name":"tmax","levelType":"hl","level":2,"unit":"Cel","values":[24.9]},{"name":"tmin","levelType":"hl","level":2,"unit":"Cel","values":[20.2]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.6]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[4.5]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[98]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[2.1]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[60]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec12h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[61.0]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.3]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[1]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[1876]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[1868]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2368]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T17:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[20.9]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.7]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[5.1]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[100]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[2.5]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[57]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[65.3]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.2]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[3]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[2388]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[2380]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[2880]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T16:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[21.4]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.7]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[5.7]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[104]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[3.2]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[54]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[59.2]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.2]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[3]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[2528]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[2520]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[3020]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T15:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[21.8]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.4]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[8.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[118]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[4.8]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[45]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[65.1]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.3]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[2]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[2520]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[2512]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[3012]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T14:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[22.3]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.2]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[8.0]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[139]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[4.8]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[35]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[59.4]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.4]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[4]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[3312]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[3304]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[3804]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T13:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[22.9]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.4]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[8.5]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[152]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[4.9]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[34]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[55.5]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.6]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[3]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[3332]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[3324]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[3824]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T12:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[23.1]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[15.9]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[6.5]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[76]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[0.6]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[29]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn3h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn12h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"frsn24h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[49.8]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.8]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[3]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[4151]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[4144]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[4644]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]},{"validTime":"2023-06-25T11:00:00Z","parameters":[{"name":"t","levelType":"hl","level":2,"unit":"Cel","values":[22.8]},{"name":"Tiw","levelType":"hl","level":2,"unit":"Cel","values":[16.3]},{"name":"gust","levelType":"hl","level":10,"unit":"m/s","values":[7.1]},{"name":"wd","levelType":"hl","level":10,"unit":"degree","values":[52]},{"name":"ws","levelType":"hl","level":10,"unit":"m/s","values":[1.2]},{"name":"r","levelType":"hl","level":2,"unit":"percent","values":[33]},{"name":"prec1h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"prec3h","levelType":"hl","level":0,"unit":"mm","values":[0.0]},{"name":"frsn1h","levelType":"hl","level":0,"unit":"cm","values":[0.0]},{"name":"vis","levelType":"hl","level":2,"unit":"km","values":[52.0]},{"name":"msl","levelType":"hmsl","level":0,"unit":"hPa","values":[1017.9]},{"name":"tcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"c_sigfr","levelType":"hl","level":0,"unit":"percent","values":[0]},{"name":"cb_sig","levelType":"hmsl","level":0,"unit":"m","values":[5248]},{"name":"cb_sig","levelType":"hl","level":0,"unit":"m","values":[5240]},{"name":"ct_sig","levelType":"hl","level":0,"unit":"m","values":[5740]},{"name":"lcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"prtype","levelType":"hl","level":0,"unit":"code","values":[-9]},{"name":"prsort","levelType":"hl","level":0,"unit":"code","values":[0]},{"name":"mcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"hcc","levelType":"hl","level":0,"unit":"octas","values":[0]},{"name":"spp","levelType":"hl","level":0,"unit":"percent","values":[-9]},{"name":"Wsymb2","levelType":"hl","level":0,"unit":"category","values":[1]}]}]}
13:19:05.343 -> Temp: 0.00 C
13:19:05.343 -> Rain: 0.00 mm
13:19:05.343 -> Clouds: 0 of 8
13:19:05.343 -> Wind: 0.00 m/s
13:19:05.343 -> Pressure: 0 hPa
13:19:05.343 -> Humidity: 0 % RH
13:19:05.343 -> Weather: 0 of 27
Can anyone please help me figure out what I'm doing wrong?
I've tried 2 different approaches that you can see in the code and also calling the elements by index, but the index variant returned values from other elements in the response so I gave up on that alternative..
Hello
payload is a very long string, more than 40kB of data. doc size is only 1kB.
I think you should use a filter
parameters is an array containing objects identified by the name attribute. So you cannot access that value directly, you have to search in the array for an object with attribute name set to "t" (in this example). And values is again an array, so you have to select the first item.
I thought that was what I did with this line and the fetchIndex() function?
Do you mean it's neccessary to solve for this or just make it smaller?
Didn't seen that line but there's an error too. The fetchindex() function is a resource killer. Why do you parse the complete JSON again? That needs much memory and is completely unnecessary. And on the result you use index 0 although it returns an object. Then you access attribute "values" but you use (better cast) that directly although that returns an array.
Here is an example t1141772 - Wokwi ESP32, STM32, Arduino Simulator
It's just experimentation until I figure out a solution that returns the variables I need :frowning: Not permanent solution of course.
I haven't been able to figure out what it returns yet. I'm completely new to json requests and responses so this is a lot of trial and error for me :slight_smile:
But perhaps you can help me with how this response handling need to look to be able to get the variables out?
Ok guys so I made some progress :slight_smile: I managed to get data out which is fantastic, BUT I can only get out 6 parameters, even though it should be 23. Can you guys see why?
#include <Wire.h>
#include <WiFi.h>
#include <time.h>
int button;
int start_day;
int now_day;
int now_hour;
int now_minute;
int last_minute;
int now_second;
int last_second;
int last_oxyminute;
const char* password = "Password";
  delay(50);
  delay(50);
    delay(5000);
    ESP.restart();
  else {
    fetchLocalTime();
    last_minute = now_minute-1;
  // OTA settings
  ArduinoOTA
    .onStart([]() {
      String type;
        type = "sketch";
      else // U_SPIFFS
    .onEnd([]() {
  ArduinoOTA.begin();
  // Pause
  delay(50);
  struct tm timeinfo;
const char fetchIndex(const char* paramName, DynamicJsonDocument doc){
    Serial.print("Parameter size: ");
    Serial.println(parameters.size());
      Serial.print("Name variable: ");
      Serial.print(name);
      float data = parameters[i]["values"][0].as<float>();
      Serial.print(" ,Data: ");
      Serial.println(data);
      String strname = name;
      String strparam = paramName;
      if (strname == strparam) {
        paramIndex = i;
        Serial.println("Found index!");
    Serial.print("Parameter: ");
    Serial.print(paramName);
    Serial.print(" ,Index: ");
    Serial.println(paramIndex);
    return paramIndex;
  HTTPClient http;
    // Serial.println(payload);
    float temp = doc["timeSeries"][0]["parameters"][fetchIndex("t",doc)]["values"][0].as<float>();
    float rain = doc["timeSeries"][0]["parameters"][fetchIndex("prec1h",doc)]["values"][0].as<float>();
    int cloud = doc["timeSeries"][0]["parameters"][fetchIndex("tcc",doc)]["values"][0].as<int>();
    float wind = doc["timeSeries"][0]["parameters"][fetchIndex("ws",doc)]["values"][0].as<float>();
    int pres = doc["timeSeries"][0]["parameters"][fetchIndex("msl",doc)]["values"][0].as<int>();
    int humi = doc["timeSeries"][0]["parameters"][fetchIndex("r",doc)]["values"][0].as<int>();
    int symb = doc["timeSeries"][0]["parameters"][fetchIndex("Wsymb2",doc)]["values"][0].as<int>();
    Serial.print(temp);
    Serial.print(rain);
    Serial.print(wind);
    Serial.print(pres);
    Serial.print(humi);
    Serial.print(symb);
  else {
  // OTA
    // Getting time
    fetchLocalTime();
      fetchWeather();
  // Rebooting daily
    delay(5000);
    ESP.restart();
Found it :slight_smile:
It was this:
Thanks guys, I think I got it from here!
At least break out of the loop when the index is found.. :nerd_face:
Thanks yes, did that too :slight_smile:
Provide the JSON document by reference and not by copy to the fetchIndex() function, that saves a lot of memory and CPU time.
