ESP32 Project error
Error: """""......C:\Users\chara\OneDrive\Documents\Arduino\FUGU-ARDUINO-MPPT-FIRMWARE-main\FUGU-ARDUINO-MPPT-FIRMWARE-main\ARDUINO_MPPT_FIRMWARE_V1.1\8_LCD_Menu.ino: In function 'void LCD_Menu()':
8_LCD_Menu:554:6: error: insn does not satisfy its constraints:
554 | } }
(insn 11 4070 1574 179 (set (reg:SF 19 f0 [orig:139 _108 ] [139])
(mem/u/c:SF (symbol_ref/u:SI ("*.LC425") [flags 0x2]) [0 S4 A32])) "C:\Users\chara\OneDrive\Documents\Arduino\FUGU-ARDUINO-MPPT-FIRMWARE-main\FUGU-ARDUINO-MPPT-FIRMWARE-main\ARDUINO_MPPT_FIRMWARE_V1.1\8_LCD_Menu.ino":289:33 49 {movsf_internal}
(expr_list:REG_EQUAL (const_double:SF 0.0 [0x0.0p+0])
(nil)))
during RTL pass: postreload
C:\Users\chara\OneDrive\Documents\Arduino\FUGU-ARDUINO-MPPT-FIRMWARE-main\FUGU-ARDUINO-MPPT-FIRMWARE-main\ARDUINO_MPPT_FIRMWARE_V1.1\8_LCD_Menu.ino:554:6: internal compiler error: in extract_constrain_insn, at recog.cc:2692
Please submit a full bug report, with preprocessed source (by using -freport-bug).
See https://gcc.gnu.org/bugs/ for instructions.
exit status 1
I am making MPPT based solar charge controller using ESP32. I got this error when I tried to compile the project in Arduino IDE where I need to operate the LCD parameters using buttons. The output must look something like LCD display should show the values based on the push button input. But it is not happening instead the error "insn doesn't satisfy its constraints" is popping up. Kindly help me what can be done in solving this error and make my project work...????
void LCD_Menu(){
  int
  menuPages          = 4,
  subMenuPages       = 12,
  longPressTime      = 3000,
  longPressInterval  = 500,
  shortPressInterval = 100;
  //SETTINGS MENU
  if(settingMode==1){
    chargingPause = 1;
    //BUTTON KEYPRESS
    if(setMenuPage==0){
      if(digitalRead(buttonRight)==1){subMenuPage++;}
      if(digitalRead(buttonLeft)==1) {subMenuPage--;}
      if(digitalRead(buttonBack)==1) {settingMode=0;subMenuPage=0;}  //bool engage, main menu int page
      if(digitalRead(buttonSelect)==1){setMenuPage=1;} //enter sub menu settings - bool engage
      lcdBacklight_Wake();
      while(digitalRead(buttonRight)==1||digitalRead(buttonLeft)==1
      ||digitalRead(buttonBack)==1||digitalRead(buttonSelect)==1){}
    //SUB MENU PAGE CYCLING
    if(subMenuPage>subMenuPages){subMenuPage=0;}
    else if(subMenuPage<0){subMenuPage=subMenuPages;}
    //--------------------------- SETTINGS MENU PAGES: ---------------------------//
    ///// SETTINGS MENU ITEM: SUPPLY ALGORITHM SELECT /////
    if(subMenuPage==0){
      lcd.setCursor(0,0);lcd.print("SUPPLY ALGORITHM");
      if(setMenuPage==1){lcd.setCursor(0,1);lcd.print(" >");}
      else{lcd.setCursor(0,1);lcd.print("= ");}
      if(MPPT_Mode==1){lcd.print("MPPT + CC-CV  ");}
      else{lcd.print("CC-CV ONLY    ");}
      //SET MENU - BOOLTYPE
      if(setMenuPage==0){boolTemp = MPPT_Mode;}
      else{
        if(digitalRead(buttonRight)==1||digitalRead(buttonLeft)==1){
          while(digitalRead(buttonRight)==1||digitalRead(buttonLeft)==1){}
          if(MPPT_Mode==1){MPPT_Mode=0;}else{MPPT_Mode=1;}
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}MPPT_Mode = boolTemp;cancelledMessageLCD();setMenuPage=0;}
        if(digitalRead(buttonSelect)==1){while(digitalRead(buttonSelect)==1){}saveSettings();setMenuPage=0;savedMessageLCD();}
    ///// SETTINGS MENU ITEM: CHARER/PSU MODE /////
    else if(subMenuPage==1){
      lcd.setCursor(0,0);lcd.print("CHARGER/PSU MODE");
      if(output_Mode==1){lcd.print("CHARGER MODE  ");}
      else{lcd.print("PSU MODE      ");}
      if(setMenuPage==0){boolTemp = output_Mode;}
      else{
          if(output_Mode==1){output_Mode=0;}else{output_Mode=1;}
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}output_Mode = boolTemp;cancelledMessageLCD();setMenuPage=0;}
    ///// SETTINGS MENU ITEM: MAX BATTERY V /////
    else if(subMenuPage==2){
      lcd.setCursor(0,0);lcd.print("MAX BATTERY V   ");
      lcd.setCursor(2,1);lcd.print(voltageBatteryMax,2);lcd.print("V");
      lcd.print("                ");
      //SET MENU - FLOATTYPE
      if(setMenuPage==0){floatTemp = voltageBatteryMax;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}voltageBatteryMax = floatTemp;cancelledMessageLCD();setMenuPage=0;}
        currentMenuSetMillis = millis();
        if(digitalRead(buttonRight)==1){                                                    //Right button press (increments setting values)
          while(digitalRead(buttonRight)==1){
            if(millis()-currentMenuSetMillis>longPressTime){                                //Long Press
              voltageBatteryMax += 1.00;                                                    //Increment by 1
              voltageBatteryMax = constrain(voltageBatteryMax,vOutSystemMin,vOutSystemMax); //Limit settings values to a range
              lcd.setCursor(2,1);lcd.print(voltageBatteryMax,2);delay(longPressInterval);   //Display settings data
            else{        //Short Press
              voltageBatteryMax += 0.01;                                                    //Increment by 0.01
              lcd.setCursor(2,1);lcd.print(voltageBatteryMax,2);delay(shortPressInterval);  //Display settings data
            lcd.print("V   ");                                                              //Display unit
        else if(digitalRead(buttonLeft)==1){                                                //Left button press (decrements setting values)
          while(digitalRead(buttonLeft)==1){
              voltageBatteryMax -= 1.00;                                                    //Increment by 1
            else{        //Short Press
              voltageBatteryMax -= 0.01;                                                     //Increment by 0.01
    ///// SETTINGS MENU ITEM: MIN BATTERY V /////
    else if(subMenuPage==3){
      lcd.setCursor(0,0);lcd.print("MIN BATTERY V   ");
      lcd.setCursor(2,1);lcd.print(voltageBatteryMin,2);lcd.print("V");
      lcd.print("                ");
      if(setMenuPage==0){floatTemp = voltageBatteryMin;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}voltageBatteryMin = floatTemp;cancelledMessageLCD();setMenuPage=0;}
              voltageBatteryMin += 1.00;                                                    //Increment by 1
              voltageBatteryMin = constrain(voltageBatteryMin,vOutSystemMin,vOutSystemMax); //Limit settings values to a range
              lcd.setCursor(2,1);lcd.print(voltageBatteryMin,2);delay(longPressInterval);   //Display settings data
            else{        //Short Press
              voltageBatteryMin += 0.01;                                                    //Increment by 0.01
              lcd.setCursor(2,1);lcd.print(voltageBatteryMin,2);delay(shortPressInterval);  //Display settings data
              voltageBatteryMin -= 1.00;                                                    //Increment by 1
            else{        //Short Press
              voltageBatteryMin -= 0.01;                                                     //Increment by 0.01
    ///// SETTINGS MENU ITEM: CHARGING CURRENT /////
    else if(subMenuPage==4){
      lcd.setCursor(0,0);lcd.print("CHARGING CURRENT");
      lcd.setCursor(2,1);lcd.print(currentCharging,2);lcd.print("A");
      lcd.print("                ");
      if(setMenuPage==0){floatTemp = currentCharging;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}currentCharging = floatTemp;cancelledMessageLCD();setMenuPage=0;}
              currentCharging += 1.00;                                                    //Increment by 1
              currentCharging = constrain(currentCharging,0.0,cOutSystemMax);             //Limit settings values to a range
              lcd.setCursor(2,1);lcd.print(currentCharging,2);delay(longPressInterval);   //Display settings data
            else{        //Short Press
              currentCharging += 0.01;                                                    //Increment by 0.01
              lcd.setCursor(2,1);lcd.print(currentCharging,2);delay(shortPressInterval);  //Display settings data
            lcd.print("A   ");                                                            //Display unit
              currentCharging -= 1.00;                                                    //Increment by 1
            else{        //Short Press
              currentCharging -= 0.01;                                                    //Increment by 0.01
    ///// SETTINGS MENU ITEM: COOLING FAN /////
    else if(subMenuPage==5){
      lcd.setCursor(0,0);lcd.print("COOLING FAN     ");
      if(enableFan==1){lcd.print("ENABLED       ");}
      else{lcd.print("DISABLE         ");}
      if(setMenuPage==0){boolTemp = enableFan;}
      else{
          if(enableFan==1){enableFan=0;}else{enableFan=1;}
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}enableFan = boolTemp;cancelledMessageLCD();setMenuPage=0;}
    ///// SETTINGS MENU ITEM: FAN TRIG TEMP /////
    else if(subMenuPage==6){
      lcd.setCursor(0,0);lcd.print("FAN TRIGGER TEMP");
      lcd.setCursor(2,1);lcd.print(temperatureFan);
      lcd.print((char)223);lcd.print("C");lcd.print("                ");
      //SET MENU - INTTYPE
      if(setMenuPage==0){intTemp = temperatureFan;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}temperatureFan = intTemp;cancelledMessageLCD();setMenuPage=0;}
            temperatureFan++;                                                       //Increment by 1
            temperatureFan = constrain(temperatureFan,0,100);                       //Limit settings values to a range
            lcd.setCursor(2,1);lcd.print(temperatureFan);delay(shortPressInterval); //Display settings data
            lcd.print((char)223);lcd.print("C    ");                                //Display unit
            temperatureFan--;                                                       //Increment by 1
    ///// SETTINGS MENU ITEM: SHUTDOWN TEMP /////
    else if(subMenuPage==7){
      lcd.setCursor(0,0);lcd.print("SHUTDOWN TEMP   ");
      lcd.setCursor(2,1);lcd.print(temperatureMax);
      if(setMenuPage==0){intTemp = temperatureMax;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}temperatureMax = intTemp;cancelledMessageLCD();setMenuPage=0;}
            temperatureMax++;                                                       //Increment by 1
            temperatureMax = constrain(temperatureMax,0,120);                       //Limit settings values to a range
            lcd.setCursor(2,1);lcd.print(temperatureMax);delay(shortPressInterval); //Display settings data
            temperatureMax--;                                                       //Increment by 1
    ///// SETTINGS MENU ITEM: WIFI FEATURE /////
    else if(subMenuPage==8){
      lcd.setCursor(0,0);lcd.print("WIFI FEATURE    ");
      if(enableWiFi==1){lcd.print("ENABLED       ");}
      else{lcd.print("DISABLED      ");}
      if(setMenuPage==0){boolTemp = enableWiFi;}
      else{
          if(enableWiFi==1){enableWiFi=0;}else{enableWiFi=1;}
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}enableWiFi = boolTemp;cancelledMessageLCD();setMenuPage=0;}
    ///// SETTINGS MENU ITEM: AUTOLOAD /////
    else if(subMenuPage==9){
      lcd.setCursor(0,0);lcd.print("AUTOLOAD FEATURE");
      if(flashMemLoad==1){lcd.print("ENABLED       ");}
      if(setMenuPage==0){boolTemp = flashMemLoad;}
      else{
          if(flashMemLoad==1){flashMemLoad=0;}else{flashMemLoad=1;}
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}flashMemLoad = boolTemp;cancelledMessageLCD();setMenuPage=0;}
        if(digitalRead(buttonSelect)==1){while(digitalRead(buttonSelect)==1){}saveAutoloadSettings();setMenuPage=0;savedMessageLCD();}
    ///// SETTINGS MENU ITEM: BACKLIGHT SLEEP /////
    else if(subMenuPage==10){
      lcd.setCursor(0,0);lcd.print("BACKLIGHT SLEEP ");
      lcd.setCursor(2,1);
      if(backlightSleepMode==1)     {lcd.print("10 SECONDS    ");}
      else if(backlightSleepMode==2){lcd.print("5 MINUTES     ");}
      else if(backlightSleepMode==3){lcd.print("1 HOUR        ");}
      else if(backlightSleepMode==4){lcd.print("6 HOURS       ");}
      else if(backlightSleepMode==5){lcd.print("12 HOURS      ");}
      else if(backlightSleepMode==6){lcd.print("1 DAY         ");}
      else if(backlightSleepMode==7){lcd.print("3 DAYS        ");}
      else if(backlightSleepMode==8){lcd.print("1 WEEK        ");}
      else if(backlightSleepMode==9){lcd.print("1 MONTH       ");}
      else{lcd.print("NEVER         ");}
      //SET MENU - INTMODETYPE
      if(setMenuPage==0){intTemp = backlightSleepMode;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}backlightSleepMode = intTemp;cancelledMessageLCD();setMenuPage=0;}
          backlightSleepMode++;                                                           //Increment by 1
          backlightSleepMode = constrain(backlightSleepMode,0,9);                         //Limit settings values to a range
          lcd.setCursor(2,1);
          while(digitalRead(buttonRight)==1){}
          backlightSleepMode--;                                                           //Increment by 1
          lcd.setCursor(2,1);
          while(digitalRead(buttonLeft)==1){}
    ///// SETTINGS MENU ITEM: FACTORY RESET /////
    else if(subMenuPage==11){
      if(setMenuPage==0){
        lcd.setCursor(0,0);lcd.print("FACTORY RESET   ");
        lcd.setCursor(0,1);lcd.print("> PRESS SELECT  ");
      else{
        if(confirmationMenu==0){lcd.setCursor(0,0);lcd.print(" ARE YOU SURE?  ");lcd.setCursor(0,1);lcd.print("  >NO      YES  ");}  // Display ">No"
        else{lcd.setCursor(0,0);lcd.print(" ARE YOU SURE?  ");lcd.setCursor(0,1);lcd.print("   NO     >YES  ");}                     // Display ">YES"
        if(digitalRead(buttonRight)==1||digitalRead(buttonLeft)==1){while(digitalRead(buttonRight)==1||digitalRead(buttonLeft)==1){}if(confirmationMenu==0){confirmationMenu=1;}else{confirmationMenu=0;}}  //Cycle Yes NO
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}cancelledMessageLCD();setMenuPage=0;confirmationMenu=0;} //Cancel
        if(digitalRead(buttonSelect)==1){while(digitalRead(buttonSelect)==1){}if(confirmationMenu==1){factoryReset();factoryResetMessageLCD();}setMenuPage=0;confirmationMenu=0;subMenuPage=0;}
    ///// SETTINGS MENU ITEM: FIRMWARE VERSION /////
    else if(subMenuPage==12){
      if(setMenuPage==0){
        lcd.setCursor(0,0);lcd.print("FIRMWARE VERSION");
        lcd.setCursor(0,1);lcd.print(firmwareInfo);
        lcd.setCursor(8,1);lcd.print(firmwareDate);
      else{
        lcd.setCursor(0,0);lcd.print(firmwareContactR1);
        lcd.setCursor(0,1);lcd.print(firmwareContactR2);
        if(digitalRead(buttonBack)==1||digitalRead(buttonSelect)==1){while(digitalRead(buttonBack)==1||digitalRead(buttonSelect)==1){}setMenuPage=0;} //Cancel
  //MAIN MENU
  else if(settingMode==0){
    chargingPause = 0;
    //LCD BACKLIGHT SLEEP
    lcdBacklight();
    //BUTTON KEYPRESS
    if(digitalRead(buttonRight)==1) {buttonRightCommand=1;lcdBacklight_Wake();}
    if(digitalRead(buttonLeft)==1)  {buttonLeftCommand=1;lcdBacklight_Wake();}
    if(digitalRead(buttonBack)==1)  {buttonBackCommand=1;lcdBacklight_Wake();}
    if(digitalRead(buttonSelect)==1){buttonSelectCommand=1;lcdBacklight_Wake();}
    currentLCDMillis = millis();
    if(currentLCDMillis-prevLCDMillis>=millisLCDInterval&&enableLCD==1){   //Run routine every millisLCDInterval (ms)
      prevLCDMillis = currentLCDMillis;
      //MENU PAGE BUTTON ACTION
      if(buttonRightCommand==1)      {buttonRightCommand=0;menuPage++;lcd.clear();}
      else if(buttonLeftCommand==1)  {buttonLeftCommand=0;menuPage--;lcd.clear();}
      else if(buttonBackCommand==1)  {buttonBackCommand=0;menuPage=0;lcd.clear();}
      else if(buttonSelectCommand==1&&menuPage==4){buttonSelectCommand=0;settingMode=1;lcd.clear();}
      if(menuPage>menuPages){menuPage=0;}
      else if(menuPage<0){menuPage=menuPages;}
      if(menuPage==0)     {displayConfig1();}
      else if(menuPage==1){displayConfig2();}
      else if(menuPage==2){displayConfig3();}
      else if(menuPage==3){displayConfig4();}
      else if(menuPage==4){displayConfig5();}
which project, which source code?
➜ please read How to get the best out of this forum and post accordingly (including code with code tags and necessary documentation for your ask like your exact circuit and power supply, links to components etc).
I could see an attempt at code tags so I fixed your post. Code tags are three backticks (not a single tick) on their own lines before and after the code
your code here
Your code is missing parts; not sure why but the code that you presented is only 443 lines long. And as it's missing loop() and setup() and possibly other stuff (I suspect that they are in other ino files) we will not be able to reproduce.
Please describe the history of this project. Did you write it yourself? Or did you copy it from somewhere? Did you test your lcd menu on its own without integration into other code?
Note that the problem with multiple ino files is that a mistake in an other file (alphabetically before it) can result in errors in the next file (e.g. an error in a.ino can be reported as an error in b.ino).
Lastly, you might be the victim of the V3.x of the ESP32 board package where a lot of stuff was changed. Rolling back to the last V2.x might solve the problem (for now); older code that you did find on the web might not have been reworked for V3.x.
Note:
I have no experience with ESP32 based boards.
Hello Sir @sterretje
As you said you don't have any experience in ESP32 based boards, then sorry to hear from you that I copied code from somewhere else. As my project have multiple tabs in it, I am facing only this error at this particular point of code with LCD interface with buttons in ESP32. There were no errors in the previous tabs of my code where I tried in disabling the error code and tested the remaining. There is no issue with the other part of code. That's the reason I posted the part of the code along with the error.
I could not post entire project code here since it has multiple tabs in it.
I just asked. It's a long piece of code and somewhere it went wrong.
I gave 2 pieces of advice
  1. Try your code in a smaller application.
  2. Roll your board package back to see if it solves the problem.
Good luck.
