ESP32 + randomseed(10) should return each start the same random numbers?
Hey Folks
I'm using an ESP32. The sequence of numbers is different after each startup.
According to other forum entrys, the return value should always be the same?
  Serial.println("Hello, ESP32!");
  randomSeed(10);
  int rnd = random(1, 7);
  Serial.println(rnd);
  delay(1000); // this speeds up the simulation
What do i mixed here up?
thanks for you help
What happens if you use a random seed between 1 and 7 instead of 10 which is outside?
I don't see your problem, it is a proper random response.
If you need an array of particular numbers, then generate an array.
Tom.... :smiley: :+1: :coffee: :australia:
the ESP32 has a true Random Number Generator (generated based on the noise of the WiFi / Bluetooth RF subsystem) and does not rely on mathematical series
possibly if you shut the WiFi and BT down then you'll get the same sequence
Side note: your question was also raised here (no answer)
ESP32's Random number generator API, Random Number Generation - ESP32 - — ESP-IDF Programming Guide latest documentation.
here you go - the full doc and no guess work :slight_smile:
thx for the link
try skip using randomSeed()
(just for esp8266 and esp32)
i was searching for another issue and casually looked the source code for esp8266... and noticed when randomSeed() was NEVER used, random() uses the hardware random generator instead
additionally in arduino, readAnalog() on a not initialized pin (for randomSeed()) does not generate enough noise and the result is a very short range of numbers... i am searching for the "von newmann" technique but couldn't find it :frowning:
EDIT: i found it here = The reliable but not very sexy way to seed random - #29 by utopia
