ESP32 read VT pin on HT12D
I am building security system and I have the RF signal working (the transmitter in the sensors sends a message through a HT12E and the control box receives it through HT12D) and I have LED wired to VT (valid transmission) pin. However, I have been trying to get my esp32 to read this value to trigger an alert. This is my code that doesn't seem to be working:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
int red = 5;
int buzzer = 23;
int rf_in = 36;
int rf_state = LOW;
bool armed = false;
bool alarm_ = false;
unsigned long previousMillisRed = 0;
const long interval = 1000;
  SerialBT.begin("Security Control Box");
  pinMode(red, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(rf_in, INPUT_PULLUP);
  digitalWrite(red, LOW);
  digitalWrite(buzzer, LOW);
  rf_state = digitalRead(rf_in);
  if (rf_state == HIGH && armed) {
    alarm_ = true;
      if (armed) {
        digitalWrite(red, HIGH);
  if (alarm_) {
    unsigned long currentMillisRed = millis();
    if (currentMillisRed - previousMillisRed >= interval) {
      previousMillisRed = currentMillisRed;
      digitalWrite(red, !digitalRead(red));
      digitalWrite(buzzer, HIGH);
  if (SerialBT.available()) {
    if (SerialBT.read() == 'a') {
      armed = !armed;
    if (SerialBT.read() == 'r') {
      alarm_ = false;
So you have connected both an LED and pin 36 to the VT pin? How did you wire this exactly?
Also, the pullup is probably not needed, but I did not read the datasheet of the HT12D.
When an r is available when this snippet is executed, it will not be detected. Likewise an a may not be detected when the buffer contains ra. You would be better off putting the result of SerialBT.read() in a variable first and then do the tests.
Try...
    char received = SerialBT.read();
    if (received == 'a') {
      armed = !armed;
    if (received == 'r') {
      alarm_ = false;
sorry for late reply. thanks guys this is very helpful!
