Bonjour je cherche à créer des signaux avec l esp32 (code ci dessous). Le problème est que l esp32 reboote tout le temps. J’ai mis les mssages que j’obtiens. Qui peut m’orienter sur la bonne piste? Je souhaite envoyer des signaux sans discontinuité. J’ai urilisé le timer0 de l’esp32 pour diminuer la fréquence. Merci pour votre aide.
/* Copyright (c) 2017 pcbreflux. All Rights Reserved.
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, version 3.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>. *
hw_timer_t * timer0 = NULL;
//hw_timer_t * timer1 = NULL;
portMUX_TYPE timerMux0 = portMUX_INITIALIZER_UNLOCKED;
//portMUX_TYPE timerMux1 = portMUX_INITIALIZER_UNLOCKED;
volatile uint8_t led1stat = 0;
volatile uint8_t led2stat = 0;
volatile int interruptCounter;
int totalInterruptCounter;
int ValueBit = 1; // valeur pour tester, remettre a 1 pour 58ms et 116ms
byte AdresseLoco, Commande, Controle;
byte Loco = 10;// locomotive 3
byte Direction=0; // en avant pour le test
int Vitesse = 10;
void IRAM_ATTR onTimer0(){
// Critical Code here
portENTER_CRITICAL_ISR(&timerMux0);
PREAMBULE();
OctetUN();
OctetDeux();
OctetTrois();
portEXIT_CRITICAL_ISR(&timerMux0);
//void IRAM_ATTR onTimer1(){
//portENTER_CRITICAL_ISR(&timerMux1);
//led2stat=1-led2stat;
// digitalWrite(20, led2stat); // turn the LED on or off
// portEXIT_CRITICAL_ISR(&timerMux1);
pinMode(19, OUTPUT);
pinMode(21, OUTPUT);
digitalWrite(19, LOW); // turn the LED off by making the voltage LOW
digitalWrite(21, LOW); // turn the LED off by making the voltage LOW
// Serial.println("start timer 1");
// timer1 = timerBegin(1, 80, true); // timer 1, MWDT clock period = 12.5 ns * TIMGn_Tx_WDT_CLK_PRESCALE -> 12.5 ns * 2320 -> 29000 ns = 29 us, countUp
// timerAttachInterrupt(timer1, &onTimer1, true); // edge (not level) triggered
//timerAlarmWrite(timer1, ValueBit, true); // 1 * 29 us = 29 us, autoreload true
Serial.println("start timer 0");
timer0 = timerBegin(0, 580, true); // timer 0, MWDT clock period = 12.5 ns * TIMGn_Tx_WDT_CLK_PRESCALE -> 12.5 ns * 80 -> 1000 ns = 1 us, countUp
timerAttachInterrupt(timer0, &onTimer0, true); // edge (not level) triggered
timerAlarmWrite(timer0, 1, true); // 2000000 * 1 us = 2 s, autoreload true
// at least enable the timer alarms
timerAlarmEnable(timer0); // enable
// timerAlarmEnable(timer1); // enable
// nope nothing here
vTaskDelay(portMAX_DELAY); // wait as much as posible ...
void BitZero() {
digitalWrite(19,LOW);
digitalWrite(21,HIGH);
delayMicroseconds(ValueBit * 116);
digitalWrite(19,HIGH);
digitalWrite(21,LOW);
delayMicroseconds(ValueBit*116);
void BitUn() {
delayMicroseconds(ValueBit*58);
void PREAMBULE()
BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitZero(); //20 BITS UN
void OctetUN() { // octect d'adressage
//byte AdresseLoco;
AdresseLoco=bitWrite(Loco,7,0);
for (int ii = 0; ii < 8; ii++) {
if (AdresseLoco & (B10000000 >> ii)) {
//BitUn();
Serial.print(1);
else {
//BitZero();
Serial.print(0);
Serial.print("\t");
//BitZero();
Serial.print(0);
void OctetDeux(){ //octet de direction et de vitesse
//byte Commande;
int CommandeVitesse;
if (Direction = 1) {
Commande = B01100000;
else {
Commande = B01000000;
CommandeVitesse=Vitesse+3;
static boolean VitesseOctetC=bitRead(CommandeVitesse,0);
Commande=bitWrite(Commande,5,VitesseOctetC);
static boolean VitesseOctetZERO=bitRead(CommandeVitesse,1);
Commande=bitWrite(Commande,0,VitesseOctetZERO);
static boolean VitesseOctetUN=bitRead(CommandeVitesse,2);
Commande=bitWrite(Commande,1,VitesseOctetUN);
static boolean VitesseOctetDEUX=bitRead(CommandeVitesse,3);
Commande=bitWrite(Commande,2,VitesseOctetDEUX);
static boolean VitesseOctetTROIS=bitRead(CommandeVitesse,4);
Commande=bitWrite(Commande,3,VitesseOctetTROIS);
static boolean VitesseOctetQUATRE=bitRead(CommandeVitesse,5);
Commande=bitWrite(Commande,4,VitesseOctetTROIS);
//Serial.print("\t");
if (Commande & (B10000000 >> ii)) {
//BitUn();
Serial.print(1);
else {
//BitZero();
Serial.print(0);
Serial.print("\t");
//BitZero();
Serial.print(0);
void OctetTrois(){
byte Controle;
Controle = AdresseLoco ^ Commande;
if (Controle & (B10000000 >> ii)) {
//BitUn();
Serial.print(1);
else {
//BitZero();
Serial.print(0);
Serial.print("\t");
//BitZero();
Serial.println(0);
void vide() {
PREAMBULE(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitZero(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(),BitUn(), BitUn();
J’obtiens ce type de message:
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
start timer 0
00001010 001100110 001101100 0
000
Guru Meditation Error: Core 1 panic’ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC : 0x4008166a PS : 0x00060c34 A0 : 0x80082166 A1 : 0x3ffbe6d0
A2 : 0x01af7972 A3 : 0x00000000 A4 : 0x40081240 A5 : 0x3ffbe7d0
A6 : 0x000000ff A7 : 0x3ffbe890 A8 : 0x00000000 A9 : 0x00000000
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x00000050 A13 : 0x4008a520
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000000b EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
Core 1 was running in ISR context:
EPC1 : 0x40081517 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008166a
Backtrace: 0x4008166a:0x3ffbe6d0 0x40082163:0x3ffbe6f0 0x40081143:0x3ffbe710 0x40081183:0x3ffbe730 0x400d0d0a:0x3ffbe750 0x400d0d47:0x3ffbe770 0x40080e80:0x3ffbe790 0x40081235:0x3ffbe7b0 0x40084699:0x3ffbe7d0 0x4008123d:0x3ffb1f80 0x400d1abb:0x3ffb1fb0 0x400882c1:0x3ffb1fd0
Core 0 register dump:
PC : 0x400e988a PS : 0x00060134 A0 : 0x800d4486 A1 : 0x3ffbbff0
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001
A6 : 0x00060120 A7 : 0x00000000 A8 : 0x800d404e A9 : 0x3ffbbfc0
A10 : 0x00000000 A11 : 0x40084e24 A12 : 0x00060120 A13 : 0x00000020
A14 : 0x00000020 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x400e988a:0x3ffbbff0 0x400d4483:0x3ffbc010 0x400897b2:0x3ffbc030 0x400882c1:0x3ffbc050
