Hello everyone
I send X command to ESP32 over BT with Android application, but it keeps repeating as if sending this command
post your code using code tags </> plus output of serial monitor and the Android
#include <BluetoothSerial.h>
#include <EEPROM.h>
BluetoothSerial SerialBT;
byte BTData;
int kalanzaman;
const int tetik = 22;
const int role = 27;
int buttonState = 0;
int verilenhak = 500;
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
SerialBT.begin("AirSoft Silah Kontrol");
Serial.println("AirSoft Silah Kontrol v1");
Serial.println("Bluetooth baslatildi, Baglanmaya hazir...");
pinMode(tetik, INPUT);
pinMode(role, OUTPUT);
EEPROM.read(5);
void loop(){
if(SerialBT.available())
BTData = SerialBT.read();
if(BTData == '1')
digitalWrite(role, HIGH);
Serial.println("High");
if(BTData == '0')
digitalWrite(role, LOW);
Serial.println("Low");
if (digitalRead(tetik) == LOW){
verilenhak --;
EEPROM.write(5,verilenhak);
Serial.println(verilenhak);
if (verilenhak < 10){
SerialBT.write('K');
if (verilenhak < 1){
EEPROM.write(5,0);
Serial.println("Bitti");
SerialBT.write('X');
if(BTData == '2')
verilenhak = 20;
Serial.println("20 Atis");
if (BTData == '3')
verilenhak = 30;
Serial.println("30 Atis");
if(BTData == '4')
verilenhak = 40;
Serial.println("40 Atis");
if(BTData == '5')
verilenhak = 50;
Serial.println("50 Atis");
if(BTData == '6')
verilenhak = 60;
Serial.println("60 Atis");
if(BTData == '7')
verilenhak = 70;
Serial.println("70 Atis");
if(BTData == '8')
verilenhak = 80;
Serial.println("80 Atis");
if(BTData == '9')
verilenhak = 90;
Serial.println("90 Atis");
think at the start of loop() you need to clear the value of BTData, e.g.
void loop(){
BTData=' ';
otherwise it retains the previous value received and executes the corresponding if() again
Use C++ Switch instead if's. And clear the BTData with each iteration of the loop and before reading the new value.
thank you very much
and the button is constantly spinning, it works as if it was pressed all the time.
is the button press code
what should happen if the value read is HIGH?
