Esp32 reseting when running servo
hello, so im making a robosoccer car controlled by esp32 and ps4 controller
          front
      m1 |    |m2
      m4 |    |m3
#include <PS4Controller.h>
#include <L298N.h>
#include <ESP32Servo.h>
int servoPin = 32;
Servo myservo;
const unsigned int ENA = 19;
const unsigned int IN1 = 18;
const unsigned int IN2 = 5;
const unsigned int IN3 = 23;
const unsigned int IN4 = 22;
const unsigned int ENB = 15;
const unsigned int ENC = 12;
const unsigned int IN5 = 14;
const unsigned int IN6 = 27;
const unsigned int ENE = 33;
const unsigned int IN7 = 26;
const unsigned int IN8 = 25;
L298N motor1(ENA, IN1, IN2);
L298N motor2(ENB, IN3, IN4);
L298N motor3(ENC, IN5, IN6);
L298N motor4(ENE, IN7, IN8);
myservo.attach(servoPin);
  PS4.begin();
  int xAxis = PS4.RStickX();
  int yAxis = PS4.LStickY();
  int Rotate = PS4.LStickX();
  if (Rotate < -100) {
   motor1.setSpeed(190);
   motor2.setSpeed(190);
    motor3.setSpeed(190);
    motor4.setSpeed(190);
   motor1.backward();
    motor2.backward();
    motor3.backward();
    motor4.backward();
    Serial.println("ROTATE CCW 50%");
  else if (Rotate > 100) {
    motor1.forward();
    motor2.forward();
   motor3.forward();
    motor4.forward();
    Serial.println("ROTATE CW 50%");
  else if (yAxis > 100 && PS4.R2()) {
    motor1.setSpeed(255);
    motor2.setSpeed(255);
    motor3.setSpeed(255);
    motor4.setSpeed(255);
    motor1.forward();
    motor2.backward();
    motor3.backward();
    motor4.forward();
    Serial.println("Forward at 100%");
  else if (yAxis > 100) {
    motor1.forward();
    motor2.backward();
    motor3.backward();
    motor4.forward();
    Serial.println("Forward at 75%");
  else if (yAxis < -100 && PS4.R2()) {
   motor1.backward();
    motor2.forward();
    motor3.forward();
    motor4.backward();
    Serial.println("Backward at 100%");
  else if (yAxis < -100) {
    motor1.backward();
    motor2.forward();
    motor3.forward();
    motor4.backward();
    Serial.println("Backward at 75%");
  else if (xAxis > 100 && PS4.R2()) {
    motor1.forward();
    motor2.forward();
    motor3.backward();
    motor4.backward();
    Serial.println("Right sideway at 100%");
  else if (xAxis > 100) {
    motor1.forward();
    motor2.forward();
    motor3.backward();
    motor4.backward();
    Serial.println("Right sideway at 75%");
  else if (xAxis < -100 && PS4.R2()) {
    motor1.backward();
    motor2.backward();
    motor3.forward();
    motor4.forward();
    Serial.println("Left sideway at 100%");
  else if (xAxis < -100) {
   motor1.backward();
    motor2.backward();
    motor3.forward();
    motor4.forward();
    Serial.println("Left sideway at 75%");
  else if (PS4.R1()){
   myservo.write(60);
   Serial.println("ball trapped");
  else if (PS4.L1()) {
   myservo.write(90);
   Serial.println("ball Released");
  else {
    motor1.setSpeed(0);
    motor2.setSpeed(0);
    motor3.setSpeed(0);
    motor4.setSpeed(0);
    motor1.stop();
    motor2.stop();
    motor3.stop();
    motor4.stop();
    Serial.println("Stop");
  delay(100);
so when I press R1 to trap ball it moves the servo and resets the esp32
How is the servo powered ?
i powred it using 3.3v esp32
Servos usually run at 5V and, in any case, the ESP board cannot supply enough current to run a servo, hence the reset
You need to power the servo with an external power supply that can provide sufficient current for the servo
i tried using 5 from VIN pin of esp32 but is 5v and more than 1200mah and the servo is not working
Try running one of the Servo example sketches on the board
/* Sweep
 by BARRAGAN <http://barraganstudio.com>
 This example code is in the public domain.
 modified 8 Nov 2013
 by Scott Fitzgerald
 modified for the ESP32 on March 2017
 by John Bennett
 see http://www.arduino.cc/en/Tutorial/Sweep for a description of the original code
 * Different servos require different pulse widths to vary servo angle, but the range is
 * an approximately 500-2500 microsecond pulse every 20ms (50Hz). In general, hobbyist servos
 * sweep 180 degrees, so the lowest number in the published range for a particular servo
 * represents an angle of 0 degrees, the middle of the range represents 90 degrees, and the top
 * of the range represents 180 degrees. So for example, if the range is 1000us to 2000us,
 * 1000us would equal an angle of 0, 1500us would equal 90 degrees, and 2000us would equal 1800
 * degrees.
 * Circuit: (using an ESP32 Thing from Sparkfun)
 * Servo motors have three wires: power, ground, and signal. The power wire is typically red,
 * the ground wire is typically black or brown, and the signal wire is typically yellow,
 * orange or white. Since the ESP32 can supply limited current at only 3.3V, and servos draw
 * considerable power, we will connect servo power to the VBat pin of the ESP32 (located
 * near the USB connector). THIS IS ONLY APPROPRIATE FOR SMALL SERVOS.
 * We could also connect servo power to a separate external
 * power source (as long as we connect all of the grounds (ESP32, servo, and external power).
 * In this example, we just connect ESP32 ground to servo ground. The servo signal pins
 * connect to any available GPIO pins on the ESP32 (in this example, we use pin 18.
 * In this example, we assume a Tower Pro MG995 large servo connected to an external power source.
 * The published min and max for this servo is 1000 and 2000, respectively, so the defaults are fine.
 * These values actually drive the servos a little past 0 and 180, so
 * if you are particular, adjust the min and max values to match your needs.
Servo myservo;  // create servo object to control a servo
// 16 servo objects can be created on the ESP32
int pos = 0;    // variable to store the servo position
// Recommended PWM GPIO pins on the ESP32 include 2,4,12-19,21-23,25-27,32-33
// Possible PWM GPIO pins on the ESP32-S2: 0(used by on-board button),1-17,18(used by on-board LED),19-21,26,33-42
// Possible PWM GPIO pins on the ESP32-S3: 0(used by on-board button),1-21,35-45,47,48(used by on-board LED)
// Possible PWM GPIO pins on the ESP32-C3: 0(used by on-board button),1-7,8(used by on-board LED),9-10,18-21
#if defined(CONFIG_IDF_TARGET_ESP32S2) || defined(CONFIG_IDF_TARGET_ESP32S3)
int servoPin = 17;
#elif defined(CONFIG_IDF_TARGET_ESP32C3)
int servoPin = 7;
#else
int servoPin = 32;
#endif
	// Allow allocation of all timers
	ESP32PWM::allocateTimer(0);
	ESP32PWM::allocateTimer(1);
	ESP32PWM::allocateTimer(2);
	ESP32PWM::allocateTimer(3);
	myservo.setPeriodHertz(50);    // standard 50 hz servo
	myservo.attach(servoPin, 1000, 2000); // attaches the servo on pin 18 to the servo object
	// using default min/max of 1000us and 2000us
	// different servos may require different min/max settings
	// for an accurate 0 to 180 sweep
	for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
		// in steps of 1 degree
		myservo.write(pos);    // tell servo to go to position in variable 'pos'
		delay(15);             // waits 15ms for the servo to reach the position
	for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
I tried this example code and it is working fine
Does the board reset if you comment out the Servo.write() for the R1 detection ?
no, it does not reset I removed the delay and when I press L1 to release the ball the motor comes at one spot and stops but when I press R1 to trap the ball it keeps rotating 360 degrees
edit-it and now it resets sometimes and sometimes it doesn't
Apart from any other problem. if the servo keeps rotating 360 degrees then you have a not got a servo at all, you have an electronically controlled motor. Such a motor will not allow you to set its position, only its speed and direction
Such a motor will also not do what is intended when you run the Sweep example. When you ran it, what did you observe the "servo" doing ?
Hi, @malharja123
Can you post some images of your project?
So we can see your component layout.
Thanks... Tom.. :smiley: :+1: :coffee: :australia:
Is this an SG90 servo?
This is the circuit diagram, Sorry in the Battery section I accidentally write 18560 instead of 18650
components used-
1)l298n Motor driver x 2
2)Mecanum Wheels x 4
3)esp32 x 1
4)18650 3.7v 1200mah x 1
5)18650 3.7v 2500mah x 2
4)12v Gear Motor 500rpm x 4
These are my motors-
https://robu.in/product/500rpm-12v-low-noise-dc-motor-with-metal-gears-grade-a/?gad_source=1&gclid=Cj0KCQiA_qG5BhDTARIsAA0UHSL12n1OStm3ghaxiTP1IMFaxfGUQP3lrxt9ILoeZ0Mi0pLBYu8fWf8aAnlfEALw_wcB
pin-
ENA = 19;
IN1 = 18;
IN2 = 5;
IN3 = 23;
IN4 = 22;
ENB = 15;
ENC = 12;
IN5 = 14;
IN6 = 27;
ENE = 33;
IN7 = 26;
IN8 = 25;
motor configuration-
      front
  m1 |    |m2
  m4 |    |m3
And yes I'm using sg90 pro servo motor
https://robu.in/product/towerpro-sg90-9g-mini-servo-9-gram/
how can i upload videos here
There are many copies and fakes of the SG90. Many people on the forum have reported receiving continuous rotating servos when they ordered 180 degree.
I think you need a new servo.
Hi, @malharja123
Thanks for the diagram, but it doesn't tell us pin numbers etc.
You will find it easier to draw and annotate.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
the pin diagram is given in the discription but ill try to draw
Thank you, pen(cil) and paper would be clearer.
That's fine but you need a new servo
sure sir ill try with different servo
