ESP32 / Robomaster C620 issue
Hello, I am trying to drive a Robomaster C620 ESC with ESP32, by controlling it with a DS4 controller. The controller and the board initializes just fine by connecting, but the C620 keeps giving a error code after start. On the manual, it says PWM output is not at the minimum, and I don't have the slightest idea how to make it at the minimum.
I have basic knowledge but not too deep so mostly it's chatgpt generated.
Also, when I jiggle the joystick randomly, the motor just initializes and works as intended. I need it to start ASAP so can anyone help me with this? Also I am trying to use 3 different motors so I need it to start working synchronized and fast as possible.
Documentation here
Any help would be greatly appreciated.
#include <Bluepad32.h>
#include <ESP32Servo.h>
// Global pointer for the connected gamepad
GamepadPtr myGamepad = nullptr;
// Set up the motor control pin and the Servo object
const int motorPin = 13;
Servo motorController;
// Deadzone to avoid drift when the joystick is nearly centered.
const int JOYSTICK_DEADZONE = 10;
// Updated PWM constants for two-way ESC calibration:
// 1000 µs = full reverse; 1500 µs = neutral; 2000 µs = full forward.
const int PWM_MIN  = 1000;   // Full reverse pulse width
const int PWM_STOP = 1500;   // Neutral (stop)
const int PWM_MAX  = 2000;   // Full forward pulse width
// Called when a gamepad connects.
void onConnectedGamepad(GamepadPtr gp) {
  Serial.println("Gamepad connected");
  myGamepad = gp;
  Serial.print("Model: ");
  Serial.println(gp->getModelName());
// Called when a gamepad disconnects.
void onDisconnectedGamepad(GamepadPtr gp) {
  Serial.println("Gamepad disconnected");
  if (gp == myGamepad) {
    // Set motor to stop when no controller is connected.
    motorController.writeMicroseconds(PWM_MIN);
  Serial.println("Initializing Bluepad32 and setting up motor...");
  // Initialize Bluepad32 (for gamepad handling)
  BP32.setup(&onConnectedGamepad, &onDisconnectedGamepad);
  // Allocate one timer for the ESP32 PWM control and set the PWM frequency to 50 Hz.
  ESP32PWM::allocateTimer(0);
  motorController.setPeriodHertz(50); // Standard frequency for ESC/servo control
  // Attach the motor controller to the specified pin with the given min and max pulse widths.
  motorController.attach(motorPin, PWM_MIN, PWM_MAX);
  // Initialize the motor to neutral (stop)
  motorController.writeMicroseconds(PWM_STOP);
  Serial.println("Motor initialized to stop (1500 µs). Waiting for controller input...");
  // Update Bluepad32 events
  BP32.update();
  // If a gamepad is connected, use its left joystick Y-axis value
  if (myGamepad && myGamepad->isConnected()) {
    int joystickY = myGamepad->axisY(); // Expected range: -127 (full forward) to +127 (full reverse)
    controlMotor(joystickY);
    printDebugInfo(joystickY);
    // If no gamepad is connected, ensure the ESC/motor is stopped.
  delay(50); // Small delay to prevent flooding the serial output.
// Map the joystick input to the PWM output required by the ESC.
void controlMotor(int joystickY) {
  // Apply deadzone: if the absolute value is below deadzone, set motor to neutral.
  if (abs(joystickY) < JOYSTICK_DEADZONE) {
    return;
  int pwmValue = PWM_STOP;
  // For negative values (joystick pushed forward) — map from neutral (1500 µs) to full forward (2000 µs)
  if (joystickY < 0) {
    pwmValue = map(joystickY, -127, 0, PWM_MAX, PWM_STOP);
  // For positive values (joystick pulled backward) — map from neutral (1500 µs) to full reverse (1000 µs)
  else {
    pwmValue = map(joystickY, 0, 127, PWM_STOP, PWM_MIN);
  // Send the PWM signal to the ESC.
  motorController.writeMicroseconds(pwmValue);
// Output debug information on the serial monitor.
void printDebugInfo(int joystickY) {
  Serial.print("Joystick Y: ");
  Serial.print(joystickY);
  Serial.print(" | PWM output: ");
  Serial.println(motorController.readMicroseconds());
Post an annotated schematic showing exactly how this is wired. Show all modules, power sources and note any wires over 10"/25cm. Post links to technical information on each of the devices.
c620's white pwm pin is connected to 13 black gnd pin is connected to esp32's ground on board, and the esc itself powered by a 24v li-po battery
esp32 is powered by a stepdown buck converter with 5.1v from the same 24v battery
dualshock controller is connected over bluetooth using the bluepad library
converter is LM2596-NB
and the motor is M3508 connected to the ESC
sorry for the late reply
That is nice but it does not show how things are connected, that is the reason for the schematic. There are many versions of some of the items you used, links to there technical information would help.
