ESP32: runder slider über websocket
Hallo zusammen,
ich habe einen ESP32 laufen, der per PWM eine Leuchte dimmt. Die Bedienung läuft über eine HTML auf dem ESP-Webserver über websocket, per linearem slider. Dieser HTML code funktioniert auch seit längerem.
<html>
<head>
<meta charset="utf-8" name="viewport" content="width=device-width, initial-scale=1">
<title>Lichtsteuerung</title>
<style>
.slidecontainer {
    width: 100%;
    .slider {
        -webkit-appearance: none;
        width: 80%;
        height: 5px;
        border-radius: 5px;
        background: #8080F0;
        outline: none;
        opacity: 0.7;
        -webkit-transition: .2s;
        transition: opacity .2s;
    @media only screen and (orientation: portrait) {
       .slider {
        position: absolute;
        top: 55%;
        left: -20%;
        transform: rotate(270deg);
        -webkit-transform: rotate(270deg);
        width: 80%; }
    .slider:hover {
        opacity: 1;
    .slider::-webkit-slider-thumb {
        appearance: none;
        width: 35px;
        height: 35px;
        border-radius: 50%;
        background: #FFFFFF;
        cursor: pointer;
    .slider::-moz-range-thumb {
        width: 35px;
        height: 35px;
        border-radius: 50%;
        cursor: pointer;
</style>
<script>
var websock;
function start() {
  websock = new WebSocket('ws://' + window.location.hostname + ':81/');
  websock.onopen = function(evt) { console.log('websock open'); };
  websock.onclose = function(evt) { console.log('websock close'); };
  websock.onerror = function(evt) { console.log(evt); };
  websock.onmessage = function(evt) {
    //console.log(evt);
    var res = evt.data.split("=");
    if (res.length == 2) {
		console.log(res[0]);
		console.log(res[1]);
        var output = document.getElementById("demo");
		var sli = document.getElementById('myRange');
		if (res[0] == 'dimm') {
		  sli.value = Number(res[1]);
		  output.innerHTML = res[1];
    else {
      console.log('unknown event');
function sliderchange(e1) {
//  var output = document.getElementById("demo");
  var str1 = "dimm=" + e1.value;
  websock.send(str1);
//  output.innerHTML = str1;
</script>
</head>
<body onload="javascript:start();">
<h1>Lichtsteuerung</h1>
<div class="""slidecontainer">
  <input type="range" min="0" max="1000" value="50" class="slider" id="myRange" oninput="sliderchange(this);">
  <p>Value: <span id="demo"></span></p>
</div>
</body>
</html>
Jetzt möchte ich aber den linearen Slider durch einen kreisförmigen, round slider ersetzen. Dazu habe ich mir per jsfiddle folgendes generiert was auch grundsätzlich funktioniert, die speziellen Javascipt und CSS sind separat.
Ich bräuchte jetzt aber einen Tipp, wie ich den websocket Teil einfüge, und wie man die Übergabe der Daten als Variable zurück an den ESP macht. Meine Kenntnisse in HTML und script-Programmierung sind dafür leider nicht gut genug.
<!DOCTYPE html>
<html class=" waloraln idc0_349"><head>
  <meta http-equiv="content-type" content="text/html; charset=UTF-8">
  <title>round slider - a demo for arc slider</title>
  <meta name="robots" content="noindex, nofollow">
  <meta name="googlebot" content="noindex, nofollow">
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <script type="text/javascript" src="data/jquery-1.11.0.js"></script>
  <link rel="stylesheet" type="text/css" href="data/result-light.css">
  <link rel="stylesheet" type="text/css" href="data/roundslider.min.css">
  <script type="text/javascript" src="data/roundslider.min.js"></script>
  <style id="compiled-css" type="text/css">
    #arc-slider {
  height: 300px !important;
  width: 300px !important;
  border: 0px dashed;
  overflow: hidden;
  padding: 15px;
#arc-slider .rs-container {
  margin-left: -150px;
  /* here 300 is the radius value */
  left: 50%;
#arc-slider .rs-tooltip {
  top: 60px;
#arc-slider .rs-tooltip-text {
  font-size: 25px;
#arc-slider .rs-border {
  border-width: 0px;
/* Appearance related changes */
.rs-control .rs-range-color {
  background-color: #54BBE0;
.rs-control .rs-path-color {
  background-color: #5f5f5f;
.rs-control .rs-handle {
  background-color: #51c5cf;
    /* EOS */
  </style>
  <script id="insert"></script>
</head>
<body>
    <h2>Lichtsteuerung</h2>
<div id="arc-slider" class="rslider rs-control rs-animation" style="height: 300px; width: 300px;"><div class="rs-container full pie" style="height: 300px; width: 300px;"><div class="rs-inner-container"><div class="rs-block rs-outer rs-border rs-split"><div class="rs-path rs-transition rs-range-color" style="transform: rotate(315deg);"></div><div class="rs-path rs-transition rs-range-color" style="opacity: 0; transform: rotate(153.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; transform: rotate(333.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; z-index: 1; transform: rotate(135deg);"></div><span class="rs-block" style="padding: 6px;"><div class="rs-inner rs-bg-color rs-border"></div></span></div></div><div class="rs-bar rs-transition rs-first" style="z-index: 4; transform: rotate(333.9deg);"><div class="rs-handle rs-move" index="2" tabindex="0" role="slider" aria-label="arc-slider_handle" style="height: 38px; width: 38px; margin: -19px 0px 0px -16px;" aria-valuenow="70" aria-valuemin="0" aria-valuemax="1000"></div></div><span class="rs-bar rs-transition rs-start" style="transform: rotate(315deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><span class="rs-bar rs-transition rs-end" style="transform: rotate(585deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><div class="rs-overlay rs-transition rs-bg-color" style="transform: rotate(585deg);"></div><span class="rs-tooltip rs-tooltip-text edit" style="margin-top: -21px; margin-left: -25px;">70 </span></div><input type="hidden" name="arc-slider" value="70"></div>
<script type="text/javascript">//<![CDATA[
  $("#arc-slider").roundSlider({
  sliderType: "min-range",
  circleShape: "pie",
  value: 70,
  startAngle: -45,
  max: "1000",
  editableTooltip: true,
  radius: 150,
  width: 6,
  handleSize: "+32",
  tooltipFormat: function(args) {
    return args.value + " ";
</script>
</body></html>
Gruß,
Dieter
PS: die Docu zum round slider hier habe ich gelesen, leider komme ich damit auch nicht weiter
Javascript Websocket example: http://jurca.dyn.ts.si/example10.html
Tut mir leid, aber was soll ich mit der Info anfangen?
Auf meiner exisitierenden Seite habe ich ja schon websocket laufen, ich bekomme es aber in den round slider nicht übertragen
Es tut mir leid, dass ich es nicht sorgfältig gelesen habe.
Wenn ich es recht verstanden habe, ist das obere HTML in Post #1 der funktionierende Code und das untere der neue "runde" Slider, korrekt?
Der webSocket-Anteil ist dann im ersten Code zwischen zwei tags eingeschlossen vor dem Body des HTML zusammengefasst. Wenn ich das richtig verstehe, wird die dort definierte Funktion sliderchange(e1) anscheinend etwas später in
</div>
mit dem oninput-Event von "slidecontainer" verbunden. Ich habe den webSocket-Anteil mal vor
< body > in den zweiten HTML-Code eingefügt und (mangels besseren Wissens) das "oninput" ans Ende der arc-slider Definition eingefügt ... Vielleicht mal hiermit versuchen:
<!DOCTYPE html>
    #arc-slider {
  border: 0px dashed;
  overflow: hidden;
  padding: 15px;
  left: 50%;
  top: 60px;
  font-size: 25px;
  border-width: 0px;
    /* EOS */
  </style>
</head>
<script>
var websock;
function start() {
    //console.log(evt);
    else {
  websock.send(str1);
</script>
<div id="arc-slider" class="rslider rs-control rs-animation" style="height: 300px; width: 300px;"><div class="rs-container full pie" style="height: 300px; width: 300px;"><div class="rs-inner-container"><div class="rs-block rs-outer rs-border rs-split"><div class="rs-path rs-transition rs-range-color" style="transform: rotate(315deg);"></div><div class="rs-path rs-transition rs-range-color" style="opacity: 0; transform: rotate(153.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; transform: rotate(333.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; z-index: 1; transform: rotate(135deg);"></div><span class="rs-block" style="padding: 6px;"><div class="rs-inner rs-bg-color rs-border"></div></span></div></div><div class="rs-bar rs-transition rs-first" style="z-index: 4; transform: rotate(333.9deg);"><div class="rs-handle rs-move" index="2" tabindex="0" role="slider" aria-label="arc-slider_handle" style="height: 38px; width: 38px; margin: -19px 0px 0px -16px;" aria-valuenow="70" aria-valuemin="0" aria-valuemax="1000"></div></div><span class="rs-bar rs-transition rs-start" style="transform: rotate(315deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><span class="rs-bar rs-transition rs-end" style="transform: rotate(585deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><div class="rs-overlay rs-transition rs-bg-color" style="transform: rotate(585deg);"></div><span class="rs-tooltip rs-tooltip-text edit" style="margin-top: -21px; margin-left: -25px;">70 </span></div><input type="hidden" name="arc-slider" value="70" oninput="sliderchange(this);"></div>
  circleShape: "pie",
  value: 70,
  startAngle: -45,
  max: "1000",
  radius: 150,
  width: 6,
  handleSize: "+32",
</script>
</body></html>
Ob das so geht ...? Keine Garantie fürs Funktionieren ... :wink:
Vielleicht kommt aber ja auch noch jemand um die Ecke, der sich besser mit JavaScript auskennt.
Danke dir, das war genau der Denkanstoß der mich weitergebracht hat. Direkt funktioniert hatte es zwar nicht (wie von dir vorhergesehen), aber nachdem ich "oninput" durch den richtigen eventtrigger von roundslider ersetzt habe, spielt es zusammen. Nachdem das jetzt so funktioniert, kann es ans ausfeilen gehen. Hier noch der funktionierende code:
<!DOCTYPE html>
    #arc-slider {
  border: 0px dashed;
  overflow: hidden;
  padding: 15px;
  left: 50%;
  top: 60px;
  font-size: 25px;
  border-width: 0px;
    /* EOS */
  </style>
</head>
<script>
var websock;
function start() {
    //console.log(evt);
    else {
</script>
<div id="arc-slider" class="rslider rs-control rs-animation" style="height: 300px; width: 300px;"><div class="rs-container full pie" style="height: 300px; width: 300px;"><div class="rs-inner-container"><div class="rs-block rs-outer rs-border rs-split"><div class="rs-path rs-transition rs-range-color" style="transform: rotate(315deg);"></div><div class="rs-path rs-transition rs-range-color" style="opacity: 0; transform: rotate(153.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; transform: rotate(333.9deg);"></div><div class="rs-path rs-transition rs-path-color" style="opacity: 1; z-index: 1; transform: rotate(135deg);"></div><span class="rs-block" style="padding: 6px;"><div class="rs-inner rs-bg-color rs-border"></div></span></div></div><div class="rs-bar rs-transition rs-first" style="z-index: 4; transform: rotate(333.9deg);"><div class="rs-handle rs-move" index="2" tabindex="0" role="slider" aria-label="arc-slider_handle" style="height: 38px; width: 38px; margin: -19px 0px 0px -16px;" aria-valuenow="70" aria-valuemin="0" aria-valuemax="1000"></div></div><span class="rs-bar rs-transition rs-start" style="transform: rotate(315deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><span class="rs-bar rs-transition rs-end" style="transform: rotate(585deg);"><span class="rs-seperator" style="width: 6px; margin-left: 0px;"></span></span><div class="rs-overlay rs-transition rs-bg-color" style="transform: rotate(585deg);"></div><span class="rs-tooltip rs-tooltip-text edit" style="margin-top: -21px; margin-left: -25px;">70 </span></div><input type="hidden" name="arc-slider" value="70" change="traceEvent(this);" ></div>
  circleShape: "pie",
  value: 70,
  startAngle: -45,
  max: "1000",
  radius: 150,
  width: 6,
  handleSize: "+32",
  change: "traceEvent",
function traceEvent(e) {
  var str1 = "dimm=" + e.value;
  websock.send(str1);
</script>
</body></html>
Freut mich, dass mein empirisch zusammengestockelter Beitrag Dir helfen konnte :wink:
Nur aus Wissensdurst: Wie hast Du den korrekten Funktionsaufruf gefunden?
Aus der Doku der Funktion (selber gelesen :slight_smile: ).
Daher wusste ich, welche events es gibt, "oninput" gehört nicht dazu, sondern "change". Aber zum dass und wie das einzusetzen ist, hast du mir den richtigen Hinweis gegeben.
