ESP32 -S2/3 NAtive USB and Serial via TX/RX
HI,
I'm trying to get the native usb running along with the uart. The goal is to get the "regular" Serial to read/write data and then Write read data to the usb.
Basically forwarding data from the serial monitor to the USB and back.
I'm not so sure everything is working, so i would appreciate any help in explaining the things that should be done (and i might not did) Thanks.
The ESP should be in the OTG mode of course.
#include <Arduino.h>
#include <Wifi.h>
#include "USB.h"
  // pinMode(LED_IO1, OUTPUT);
  Serial.println("This is the PC test");
  Serial.println("Test Begin");
  // USB Communication init
  SerialUSB.begin(115200);
  USB.begin();
  while (Serial.available()>0) {
  char UART_Data_IN = Serial.read();//Read_UART0 ();
      SerialUSB.write(ART_Data_IN);
      }//if
  while (SerialUSB.available()) {
      char hex[3];
      hex[0] = SerialUSB.read();
      hex[1] = SerialUSB.read();
      hex[2] = '\0';
      long byteRead = strtol(hex, NULL, 16);
      Serial.write(byteRead);
The uart to USB is on com 4 and the usb is on com7. the problem is that i cant open the regular terminal even though it should be on com4, it says there's a probelm with com7. Any way i can configure that ? or understand what the problem is?
If it helps, i'm using VSCode with platformIO
Thanks,
Schematics would likely make more helpers interested.
A block diagram showing what the main idea is would also be good.
Hi @Railroader the idea is just to transfer data between UART0 and the natiev USB.
Apperantly i had a driver issue with the windows USB driver, so it didn't work. It did work on the Mac .
In addition, in order to get the ESP32 S3 S2 into usb otg in VSCODE you need to add this to the platformio.ini file:
build_unflags = -DARDUINO_USB_MODE=1
And after that it worked
Case solved. Thanks for telling.
