Hello!
I tried to compile this code, which I found here:GitHub - andi38/TPMS: Decode tire pressure monitoring system TPMS BLE 433MHz CC1101 ESP8266 ESP32.
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleScan.cpp
Ported to Arduino ESP32 by Evandro Copercini
#include "BLEDevice.h"
#include "BLEUtils.h"
#include "BLEScan.h"
#include "BLEAdvertisedDevice.h"
int scanTime = 5; //In seconds
BLEScan *pBLEScan;
BLEUtils utils;
char convertCharToHex(char ch)
char returnType;
switch(ch)
case '0':
returnType = 0;
case '1' :
returnType = 1;
case '2':
returnType = 2;
case '3':
returnType = 3;
case '4' :
returnType = 4;
case '5':
returnType = 5;
case '6':
returnType = 6;
case '7':
returnType = 7;
case '8':
returnType = 8;
case '9':
returnType = 9;
case 'a':
returnType = 10;
case 'b':
returnType = 11;
case 'c':
returnType = 12;
case 'd':
returnType = 13;
case 'e':
returnType = 14;
case 'f' :
returnType = 15;
default:
returnType = 0;
return returnType;
//class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks {
//void onResult(BLEAdvertisedDevice advertisedDevice) {
//Serial.printf("Advertised Device: %s \n", advertisedDevice.toString().c_str());
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
String addr = advertisedDevice.getAddress().toString().c_str();
String mfdata = advertisedDevice.getManufacturerData().c_str();
uint8_t* payload = advertisedDevice.getPayload();
uint8_t payloadlen = advertisedDevice.getPayloadLength();
char *payloadhex = utils.buildHexData(nullptr, payload, payloadlen);
if (addr.startsWith("ac:15:85")) { // my sensors MAC start with ac:15:85
Serial.print("Payload: "); Serial.print(payloadhex);
// convert hex-payload to array
char *pPL = utils.buildHexData(nullptr, (uint8_t*)advertisedDevice.getPayload(), advertisedDevice.getPayloadLength());
String sPL = (String) pPL;
byte plByte[16];
byte plNib[31];
sPL.getBytes(plNib,31);
for (int i=0; i<30; i=i+2) {
plByte[i/2] = convertCharToHex(plNib[i])*16 + convertCharToHex(plNib[i+1]);
Serial.print(" ADDR: "); Serial.print(addr.substring(12));
char*pHex = utils.buildHexData(nullptr, (uint8_t*)advertisedDevice.getManufacturerData().toInt(), advertisedDevice.getManufacturerData().length());
Serial.print(" MFG DATA: "); Serial.print(pHex);
String sHex = (String) pHex;
byte nib[16];
sHex.getBytes(nib,15);
for (int i=0; i<14; i++) {
nib[i] = convertCharToHex(nib[i]);
float Press = (float)((nib[7]*256+nib[8]*16+nib[9])-145)/10.0;
String sPress = (String)Press;
Serial.print(" p: "); Serial.print(sPress.substring(0,sPress.length()-1));
int Temp = nib[4]*16+nib[5];
Serial.print(" T: "); Serial.print(Temp);
float Batt = (float)(nib[2]*16+nib[3])/10.0;
String sBatt = (String)Batt;
Serial.print(" b: "); Serial.print(sBatt.substring(0,sBatt.length()-1));
Serial.print(" BIN: ");
for (int i=0; i<2; i++) {prtnib:(nib[i]);}
Serial.print(".");
for (int i=2; i<4; i++) {prtnib:(nib[i]);}
Serial.print(".");
for (int i=4; i<6; i++) {prtnib:(nib[i]);}
//Serial.print(".");
//for (int i=6; i<10; i++) {prtnib:(nib[i]);}
//for (int i=10; i<14; i++) {prtnib:(nib[i]);}
bool nl = false;
if (nib[0]==8) {Serial.print(" ALARM"); nl=true;}
if (nib[0]==4) {Serial.print(" ROTAT"); nl=true;}
if (nib[0]==2) {Serial.print(" STILL"); nl=true;}
if (nib[0]==1) {Serial.print(" BGROT"); nl=true;}
if (nib[1]==8) {Serial.println(" DECR2"); nl=false;}
if (nib[1]==4) {Serial.println(" RISIN"); nl=false;}
if (nib[1]==2) {Serial.println(" DECR1"); nl=false;}
if ((nib[0]*16+nib[1])==0xff) {Serial.println(" LBATT");}
if (nl) {Serial.println();}
Serial.println("Scanning...");
BLEDevice::init("");
pBLEScan = BLEDevice::getScan(); //create new scan
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
pBLEScan->setInterval(100);
pBLEScan->setWindow(99); // less or equal setInterval value
BLEScanResults *foundDevices = pBLEScan->start(scanTime, false);
Serial.print("Devices found: ");
Serial.println(foundDevices->getCount());
Serial.println("Scan done!");
pBLEScan->clearResults(); // delete results fromBLEScan buffer to release memory
delay(2000);
The error received:
C:\Users\yyordanov\Documents\Arduino\ESP32_TPMS_lite1\ESP32_TPMS_lite1.ino: In member function 'virtual void MyAdvertisedDeviceCallbacks::onResult(BLEAdvertisedDevice)':
C:\Users\yyordanov\Documents\Arduino\ESP32_TPMS_lite1\ESP32_TPMS_lite1.ino:121:32: error: duplicate label 'prtnib'
121 | for (int i=2; i<4; i++) {prtnib:(nib[i]);}
C:\Users\yyordanov\Documents\Arduino\ESP32_TPMS_lite1\ESP32_TPMS_lite1.ino:123:32: error: duplicate label 'prtnib'
123 | for (int i=4; i<6; i++) {prtnib:(nib[i]);}
exit status 1
Compilation error: duplicate label 'prtnib'
Don't understand why....
