closed as of now please
Hi @waitsmd32. These errors are caused by you not wrapping what you intended to be string literals in double quotes.
For example:
Can be fixed by changing line 21 of your sketch to this:
const char* ssid = "Waits1";
Hi @waitsmd32 ,
Welcome to the forum..
need to double quote your strings??
good luck.. ~q
You must add double quotes to all the string literals.
careful when posting..
best to "*******" out the secrets..
~q
Perhaps you’re jumping in a bit deep….
the tutorials and examples show the basics, so you become familiar with them, how to use the elements, and understand the syntax,
Copy & paste rarely teaches anything, I’d guess you can’t explain every line of code in this project,,. that’s a long term recipe for disaster.
It’s ok, but as long as you can explain 80%, then say ‘that hidden function call does that’, you’re well on the way.
Being able to write code like this is different from understanding why it was written a particular way. That’s why many of the contributors on here are harsh when critiquing over-complex code performing a simple task.
absolutely. I want to learn. Can you point to any resources that could help me?
