ESP32-S3-DevKitC-1 UART0 not working in Serial Monitor Window
I am evaluating a few ESP boards and the ESP32-S3-DevKitC-1 has an issue with UART0 (I selected board: ESP32S3 Dev Module).
When I run the simple attached code, Serial1 works and I can see the text in putty on COM6. However, I am not seeing the text for Serial0 in the Arduino Serial Monitor Window. If I connect to the U0TXD pin I can see the output for Serial0 in putty. Why is the default Serial0 not showing in the serial monitor?
  Serial.begin( 9600 );
  //Serial1.begin ( 9600, SERIAL_8N1, 7, 8 );   // rx, tx
  Serial1.begin ( 9600, SERIAL_8N1, 5, 4 );
  delay(2000);
  Serial1.println("****  PRINTING TO COM6 ****");
  Serial.println(">>>---- PRINTING TO COM15 ----");
Look under the tools menu..
do you have CDC on boot disabled??
If not flip it upload again..
good luck.. ~q
I previously tried that based on forum posts, and it did not work. I tried again just now, and it still does not work.
I have run the following code on a ESP32-S3 DevkitC-1 using Serial1
// ESP32-S3 DevkitC-1  Serial1 test - for loopback test connect pin GPIO17 U1TXD to pin GPIO18 U1RXD"
// ss https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/_images/ESP32-S3_DevKitC-1_pinlayout_v1.1.jpg
#define RXD1 18
#define TXD1 17
  // initialize both serial ports:
  Serial1.begin(9600, SERIAL_8N1, RXD1, TXD1);
  Serial.println("\n\nESP32-S3 DevkitC-1 serial1  test pin GPIO17 U1TXD pin GPIO18 U1RXD");
  Serial.write("   for loopback test connect pin GPIO17 U1TXD to pin GPIO18 U1RXD\n");
  // read from port 1, send to port 0:
  if (Serial1.available()) {
    int inByte = Serial1.read();
    Serial.write(inByte);
  // read from port 0, send to port 1:
  if (Serial.available()) {
    int inByte = Serial.read();
    //Serial.write(inByte);
    Serial1.write(inByte);
connected to a HC-06 serial monitor displays
10:49:21.756 -> ESP32-S3 DevkitC-1 serial1  test pin GPIO17 U1TXD pin GPIO18 U1RXD
10:49:21.756 ->    for loopback test connect pin GPIO17 U1TXD to pin GPIO18 U1RXD
10:49:21.756 -> hello esp32hc06 test 2
on android phone Bluetooth Terminal displays
maybe it's something silly..
older ide's had a tabbed structure, had to tab back to the serial monitor??
code in a sim, seems good, that's why i'm thinking it's a setting or something else..
code in a sim..
check windows device manager, see if port still exists??
try an external serial terminal??
strange.. ~q
Just tested you code on a real esp32s3..
got a freenove esp32s3 cam..
works fine..
strange still sorry.. ~q
Yes this is odd. Serial1 works. Serial works if I connect to the U0TXD pin, but not in the Arduino serial window. That bugs me.
BTW the USB cable is plugged into the UART USB connector.
This is what my screen shows:
OK. This is weird.
I changed the baud rate from 9600 to 115200 on Serial0 like this Serial.begin( 115200 );
And it worked.
This DevKit must have a hard coded baud rate of 115200. If I change it to 9600 I get junk characters.
Also note it only works with USB CDC on boot "disabled".
I was going to tell you to try that..
last pic just looks like baud is wrong, even though i can see it's not..
weird..
better to use a faster baud for debugging anyways..
glad you figured something out..
~q
