I have a requirement to use 10 PWMs to control 10 individual LED drivers, however it looks like esp32-s3 has only 8 native PWM channels and found out that it has MCPWM and PDM too with which I can extend the PWMs count.
What's the easiest way of using MCPWM as a normal PWM generator? I need to generate a very simple 500Hz or 1Khz signal whose duty cycle has to be varied dynamically. Any help would be appreciated
Why not use pulse generation capable peripherals? The reason I can't use multiplexer is I have a feature which requires to toggle all the LED drivers for 200mS to generate a small flash of light
