I have an ESP32-S3-Box-Lite device and was happily coding a project when I seemed to have screwed things up. I can still 'see' the board but can't download to it. I'm looking to do a Factory Reset but again seem to get errors whatever I do.
The latest is using the ESP Flash Download tool and trying to flash the Bootloader - have also tried the latest firmware - and get the following;
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 115200
No serial data received.
[2023-09-27 16:57:53,668][ESP8266Loader_spi[1]][espDownloader.py][line:750][ERROR]: ESP32S3 Chip stub error esp_stub_and_set_baud.
no log file output ...
Getting desparate to do a factory reset - can anyone help.
The note I made to myself is below. You will have to install python and install esptool.py:
"pip install esptool"
Sorry this isn't a complete walkthrough but I hope you can figure it out nonetheless.
Good luck!
EDIT: Copy paste the code below into a txt and enable wordwrap, it will make more sense that way.
I had the same problem and solved it as follows. At first the esp32-s3 worked correctly. However, after uploading one of my sketches it gave me this error and I could not upload another sketch because of this. To fix it I did the following.
Create an empty sketch with a debug line in the loop. Something like Serial.println("debug line");. I tried to upload this code and connect via SERIAL to see if it was uploaded correctly.
Upload the code directly from esptool.py. As I program it from the arduino ide, the easiest way is to activate the upload debug in the ide. File > preferences> "Show detailed output while" > "Upload".
Upload the sketch from the debug line. It will generate the error "A fatal error occurred: Unable to verify flash chip connection (No serial data received.)."
But in the output console the executed esptool.py command will appear.
Something like this:
Las variables Globales usan 48428 bytes (14%) de la memoria dinámica, dejando 279252 bytes para las variables locales. El máximo es 327680 bytes. C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1/esptool.exe --chip esp32s3 --port COM3 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 8MB 0x0 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.bootloader.bin 0x8000 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.partitions.bin 0xe000 C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9/tools/partitions/boot_app0.bin 0x10000 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.bin esptool.py v4.5.1 Serial port COM3
Copy the command and run it,
adding the --no-stub parameter at the begining.
This will allow to upload the new sketch. With this you can upload sketches from the arduino IDE again. In my case was:
C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1/esptool.exe --no-stub --chip esp32s3 --port COM3 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 8MB 0x0 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.bootloader.bin 0x8000 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.partitions.bin 0xe000 C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9/tools/partitions/boot_app0.bin 0x10000 C:\Users\user\AppData\Local\Temp\arduino_build_393730/MySketch.ino.bin
new sketch:
#include <Streaming.h>
Serial << "Working !" << endl;
delay(2000);
