I have an Adafruit QT Py esp32-s3. Works fine except when I try to put it into either light sleep or deep sleep. It goes to sleep and does not wake up.
Code is the standard ESP-32 Sleep timer example. Nothing fancy. V2.1.1 of the IDE on Windows 11.
Has anyone had success using sleep functions on the S3? It seems to be a different beast.
//Deep Sleep Test
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 5 /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
// How many internal neopixels do we have? some boards have more than one!
#define NUMPIXELS 1
Adafruit_NeoPixel pixels(NUMPIXELS, PIN_NEOPIXEL, NEO_GRB + NEO_KHZ800);
void setup(){
delay(1000); //Take some time to open up the Serial Monitor
pinMode(NEOPIXEL_POWER, OUTPUT);
digitalWrite(NEOPIXEL_POWER, HIGH);
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.setBrightness(30); // not so bright
ESP_NP_Blink(0x00FF00, 5); //Blink green 5 times to tell me you're awake
delay(2000);
bootCount = bootCount+1;
Serial.println("Boot number: " + String(bootCount));
ESP_NP_Blink(0x0000FF, bootCount); //Blink blue bootcount times to see how many cycles
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Going to sleep...");
delay(2000);
esp_deep_sleep_start();
void loop(){
void ESP_NP_Blink(uint32_t color, int blinkNum) {
for (int i = 0; i < blinkNum; i++) {
// set color to selected
pixels.fill(color);
pixels.show();
delay(200); // wait half a second
// turn off
pixels.fill(0x000000);
pixels.show();
delay(100); // wait 1/10 a second
