I have a Python Maker Esp32 with audio expansion MP3 player it work fine the only issue is that I can’t run more than 22 tracks in the SDcard because it crash and restart. If I get the 35 tracks of mp3 on the sdcard the screen remains black
Any help will be appreciated
Let me know if I need to upload the sketch
Thanks
Yes you do need to do that, and post a schematic of your circuit and post links to the specs of the components you are using. Please read the forum guide in the sticky post at the top of most forum sections. This will tell you what you need to post to allow the forum to help you.
You only have a little string RAM. Are you reading the directory in as a block? Memory overflow will freeze your board until reset.
Yes. Each track song has 30 min to 1 hour of mp3 play time. Y tried to include a folder with some tracks but it doesn’t recognize folders
I guess due to Ram I can’t do much unless change maybe the tracks to wav and less playing time(limited to 5 min)
Thanks
The length of the song doesn’t matter. but pulling a directory listing does!
can you see what it needs to be change for the pulling directory in my code below
thanks
#include <TFT_eSPI.h>
#include "Arduino.h"
#include "Audio.h"
#include "SPI.h"
#include "SD.h"
#include "FS.h"
#include "fonts.h"
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite img = TFT_eSprite(&tft);
//SD Card
#define SD_CS 22
#define SPI_MOSI 23
#define SPI_MISO 19
#define SPI_SCK 18
//Digital I/O used //Makerfabs Audio V2.0
#define I2S_DOUT 27
#define I2S_BCLK 26
#define I2S_LRC 25
const int Pin_vol_up = 39;
const int Pin_vol_down = 36;
const int Pin_mute = 35;
const int Pin_previous = 15;
const int Pin_pause = 33;
const int Pin_next = 2;
int visuals[6]={5,20,14,26,8,14};
int dir[5];
Audio audio;
const int pwmFreq = 5000;
const int pwmResolution = 8;
const int pwmLedChannelTFT = 0;
bool paused=0;
struct Music_info
String name;
int length;
int runtime;
int volume;
int status;
int mute_volume;
int m;
int s;
} music_info = {"", 0, 0, 0, 0, 0,0,0};
String file_list[20];
String runtimes[20];
int file_num = 0;
int file_index = 0;
bool started=0;
int counter=0;
//IO mode init
pinMode(Pin_vol_up, INPUT_PULLUP);
pinMode(Pin_vol_down, INPUT_PULLUP);
pinMode(Pin_mute, INPUT_PULLUP);
pinMode(Pin_previous,INPUT);
pinMode(Pin_pause, INPUT_PULLUP);
pinMode(Pin_next, INPUT_PULLUP);
tft.init();
tft.setRotation(3);
tft.setSwapBytes(true);
tft.invertDisplay(1);
ledcSetup(pwmLedChannelTFT, pwmFreq, pwmResolution);
ledcAttachPin(5, pwmLedChannelTFT);
ledcWrite(pwmLedChannelTFT, 144);
//SD(SPI)
pinMode(SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH);
SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
SPI.setFrequency(1000000);
if (!SD.begin(SD_CS, SPI))
Serial.println("Card Mount Failed");
lcd_text("SD ERR");
while (1);
lcd_text("SD OK");
//Read SD
file_num = get_music_list(SD, "/", 0, file_list);
Serial.print("Music file count:");
Serial.println(file_num);
Serial.println("All music:");
int y=0;
tft.setTextColor(0xFFFF,TFT_BLACK);
for (int i = 0; i < file_num; i++)
Serial.println(file_list[i]);
tft.drawString(file_list[i].substring(1,file_list[i].length()-4),18,118+y,2);
y=y+15;
//Audio(I2S)
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(21); // 0...21
drawStart();
open_new_song(file_list[file_index]);
print_song_time();
drawVolume();
uint run_time = 0;
uint button_time = 0;
int tempSeconds=0;
int tempMinutes=0;
bool dd[6]={1,1,0,1,0,1};
audio.loop();
if(paused==0)
for(int i=0;i<5;i++)
if(dd[i]==1)
visuals[i]=visuals[i]+1;
if(dd[i]==0)
visuals[i]=visuals[i]-1;
if(visuals[i]==0 || visuals[i]==30)
dd[i]=!dd[i];
tft.fillRect(110+(i*6),4,3,4+visuals[i],TFT_BLACK);
tft.fillRect(110+(i*6),4+visuals[i],3,34-visuals[i],TFT_ORANGE);
if (millis() - run_time > 1000)
run_time = millis();
print_song_time();
tft_music();
if (millis() - button_time > 300)
if (digitalRead(Pin_next) == 0)
Serial.println("Pin_next");
if (file_index < file_num - 1)
file_index++;
file_index = 0;
drawStart();
print_song_time();
button_time = millis();
if (digitalRead(Pin_pause) == 0)
Serial.println("Pin_previous");
if (file_index > 0)
file_index--;
file_index = file_num - 1;
drawStart();
if (digitalRead(Pin_vol_up) == 0)
Serial.println("Pin_vol_up");
if (music_info.volume < 21)
music_info.volume++;
audio.setVolume(music_info.volume);
drawVolume();
if (digitalRead(Pin_vol_down) == 0)
Serial.println("Pin_vol_down");
if (music_info.volume > 0)
music_info.volume--;
drawVolume();
if (digitalRead(Pin_mute) == 0)
Serial.println("Pin_pause");
audio.pauseResume();
paused=!paused;
if (Serial.available())
String r = Serial.readString();
r.trim();
if (r.length() > 5)
audio.stopSong();
open_new_song(file_list[0]);
print_song_info();
audio.setVolume(r.toInt());
void open_new_song(String filename)
music_info.name = filename.substring(1, filename.indexOf("."));
audio.connecttoFS(SD, filename.c_str());
music_info.runtime = audio.getAudioCurrentTime();
music_info.length = audio.getAudioFileDuration();
music_info.volume = audio.getVolume();
music_info.status = 1;
music_info.m=music_info.length/60;
music_info.s=music_info.length%60;
void tft_music()
int line_step = 28;
int line = map(music_info.runtime,0,music_info.length,10,210);
char buff[20];
tempSeconds=music_info.runtime%60;
tempMinutes=music_info.runtime/60;
tft.fillRect(0,87,240,9,TFT_BLACK);
tft.drawLine(10,92,210,92,0xBDD7);
tft.drawLine(10,90,10,94,0xBDD7);
tft.drawLine(210,90,210,94,0xBDD7);
tft.fillRect(line,88,6,8,TFT_GREEN);
String ts,tm;
if(tempSeconds<10)
ts="0"+String(tempSeconds);
ts=String(tempSeconds);
if(tempMinutes<10)
tm="0"+String(tempMinutes);
tm=String(tempMinutes);
tft.setFreeFont(&FreeMono9pt7b);
tft.drawString(music_info.name,5,66);
tft.drawString(String(music_info.m)+":"+String(music_info.s),150,100);
tft.setFreeFont(&DSEG7_Classic_Regular_20);
tft.drawString(tm+":"+ts,5,20);
void drawVolume()
int v=map(music_info.volume,0,21,0,8);
tft.fillRect(180,18,54,24,TFT_BLACK);
for(int i=0;i<v;i++)
tft.drawLine(198+i*4, 40, 198+i*4, 37-(i*2),0xFFFF);
void drawStart(void)
tft.setTextColor(TFT_GREEN,TFT_BLACK);
tft.drawString("TIME",6,0,2);
tft.drawString("VOLUME",182,0,2);
tft.drawString("PLAYING",6,45,2);
tft.setTextColor(TFT_ORANGE,TFT_BLACK);
tft.drawString("RAFO PLAYLIST",6,100,2);
tft.fillRect(0,64,232,22,TFT_BLACK);
tft.fillRect(0,112,14,130,TFT_BLACK);
tft.fillCircle(7,125+(file_index*15),5,TFT_ORANGE);
void lcd_text(String text)
tft.fillScreen(TFT_BLACK);
tft.setTextColor(TFT_WHITE);
tft.setCursor(0, 0);
tft.println(text);
void print_song_info()
Serial.println("***********************************");
Serial.println(audio.getFileSize());
Serial.println(audio.getFilePos());
Serial.println(audio.getSampleRate());
Serial.println(audio.getBitsPerSample());
Serial.println(audio.getChannels());
Serial.println(audio.getAudioFileDuration());
void print_song_time()
int get_music_list(fs::FS &fs, const char *dirname, uint8_t levels, String wavlist[30])
Serial.printf("Listing directory: %s\n", dirname);
int i = 0;
File root = fs.open(dirname);
if (!root)
Serial.println("Failed to open directory");
return i;
if (!root.isDirectory())
Serial.println("Not a directory");
return i;
File file = root.openNextFile();
while (file)
if (file.isDirectory())
String temp = file.name();
if (temp.endsWith(".wav"))
wavlist[i] = temp;
i++;
else if (temp.endsWith(".mp3"))
wavlist[i] = temp;
i++;
return i;
void audio_info(const char *info)
Serial.print("info ");
Serial.println(info);
void audio_id3data(const char *info)
{ //id3 metadata
Serial.print("id3data ");
void audio_eof_mp3(const char *info)
{ //end of file
Serial.print("eof_mp3 ");
file_index++;
if (file_index >= file_num)
file_index = 0;
void audio_showstation(const char *info)
Serial.print("station ");
void audio_showstreaminfo(const char *info)
Serial.print("streaminfo ");
void audio_showstreamtitle(const char *info)
Serial.print("streamtitle ");
void audio_bitrate(const char *info)
Serial.print("bitrate ");
void audio_commercial(const char *info)
{ //duration in sec
Serial.print("commercial ");
void audio_icyurl(const char *info)
{ //homepage
Serial.print("icyurl ");
void audio_lasthost(const char *info)
{ //stream URL played
Serial.print("lasthost ");
void audio_eof_speech(const char *info)
Serial.print("eof_speech ");
Take the "free ram" # at the end of your upload and divide it by you STRUCT size and you'll get the best case count of directory entries you can read befor crashing. In reality, the actual number will be lower by whatever memory you're using for other stuff.
wavlist[]
is running you out of memory
thanks
i dont wanna sound dump but ,you mean upload with IDE and divide how by STRUCT?
sorry . thanks for yor patience.
When you load your sw into your device from the IDE, there is a memory usage summary at the bottom. This lists total memory and memory used/free. This is it, you run that out, you CRASH! -- every time.
You have a STRUCT defined. You can only create soo many copies of the STRUCT before you run out of memory.
Your wavlist[]
array holds all the directory entries, at a min of 12 bytes each. Again, the more files, the larger wavlist[]
gets, and then you crash.
undestood
thanks a lot
