ESP32 send the DHT11's data to android
I am writing the program on ESP32. I want the DHT11's data that sent to Android via Bluetooth. However, I have a error about the invalid conversion.
#include <SimpleDHT.h>
#include <BluetoothSerial.h>
#define DHT11_PIN 7
SimpleDHT11 chk(DHT11_PIN);
BluetoothSerial SerialBT;
    Serial.println("Enter AT commands:");
    // HC-06 default serial speed is 9600
    BTserial.begin("BLETEST");
    String output = "";
    String tokenizer = "@";
    byte temperature = 0;
    byte humidity = 0;
    int err = SimpleDHTErrSuccess;
    if ((err = chk.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
    Serial.print("Read DHT11 failed, err=");
    Serial.println(err);
    return;
    // Keep reading from HC-06 and send to Arduino Serial Monitor
        if (SerialBT.available())
          Serial.write(SerialBT.read());
   Serial.print((int)temperature); Serial.print(" *C, ");
   Serial.print((int)humidity); Serial.println(" H");
    // Keep reading from Arduino Serial Monitor and send to HC-06
         //dummy data
       SerialBT.write("@");
          output.concat(tokenizer);
          if ((int)temperature != -999.00 || (int)humidity != -999.00){
              if((int)temperature != -999.00){
                  output.concat((int)temperature);
                  output.concat(";");
              if((int)humidity != -999.00){
                output.concat((int)humidity);
                output.concat(";");
              output.concat("0.00@");
              Serial.println(output);
              SerialBT.write(output.c_str());
              SerialBT.write("@100.25;100.00;100.00@");
          delay(10);
The error message:
C:\Users\yiu_c\OneDrive\桌面\arduino\bt-weather-arduino\bt-weather-arduino.ino: In function 'void loop()':
bt-weather-arduino:57:26: error: invalid conversion from 'const char*' to 'uint8_t {aka unsigned char}' [-fpermissive]
In file included from C:\Users\yiu_c\OneDrive\桌面\arduino\bt-weather-arduino\bt-weather-arduino.ino:5:0:
C:\Users\yiu_c\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\BluetoothSerial\src/BluetoothSerial.h:38:16: note: initializing argument 1 of 'virtual size_t BluetoothSerial::write(uint8_t)'
size_t write(uint8_t c);
How can put the variable of string in SerialBT.write? In this situation, the variable of string cannot put in function of SerialBT.write.
Have anyone can solve this problem?
If you use double quotes the compiler sees a string (char array). The write method needs a characters and not an array of characters. So use single quotes:
SerialBT.write('@');
and it probably is happy.
