Hi, can we send or set multiple Struc message in one set of code?
I can now get 2 data from my sender1 (esp32) and sender2 (esp32), but my problem is the struct values,
for sender1, i just want to received values of x & y only,
for sender2 is just y2.
So im thinking if I can put different struct in each?
#include <esp_now.h>
#include <WiFi.h>
#include <ESP32Servo.h>
#include <Wire.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2;
Servo myservo3;
int pox;
int poy;
//int poy2;
int poy23;
int servoPin1 = 17;
int servoPin2 = 5;
int servoPin3 = 13;
// Structure example to receive data
// Must match the sender structure
typedef struct struct_message {
int id;
int x;
int y;
int y2;
}struct_message;
typedef struct struct_message2 {
int id;
int y2;
}struct_message2;
// Create a struct_message called myData
struct_message myData;
struct_message2 myData2;
// Create a structure to hold the readings from each board
struct_message board1;
struct_message board2;
struct_message board3;
// Create an array with all the structures
struct_message boardsStruct[3] = {board1, board2, board3};
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac_addr, const uint8_t *incomingData, int len) {
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy(&myData, incomingData, sizeof(myData));
Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
// Update the structures with the new incoming data
boardsStruct[myData.id-1].x = myData.x;
boardsStruct[myData.id-1].y = myData.y;
Serial.printf("x value: %d \n", boardsStruct[myData.id-1].x);
Serial.printf("y value: %d \n", boardsStruct[myData.id-1].y);
boardsStruct[myData2.id-2].y2 = myData2.y2;
Serial.printf("y2 value: %d \n", boardsStruct[myData2.id-2].y2);
// attaches the servo
myservo1.attach(servoPin1, 500, 2400);
myservo2.attach(servoPin2, 500, 2400);
myservo3.attach(servoPin3, 500, 2400);
WiFi.mode(WIFI_STA);
//Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
int board1X = boardsStruct[0].x;
int board1Y = boardsStruct[0].y;
//int board2Y = boardsStruct[1].y2;
int poy22 = boardsStruct[myData2.id-2].y2;
pox = board1X;
poy = board1Y;
//poy2 = board2Y;
poy23 = poy22;
Posx();
Posy();
Poy2();
/*int board1X = boardsStruct[0].x;
int board2X = boardsStruct[1].x;
int board2Y = boardsStruct[1].y;
int board3X = boardsStruct[2].x;
int board3Y = boardsStruct[2].y;*/
delay(10);
void Posx(){
if (pox>=0 && pox<=45)
pox = (pox*2)+180;
pox = (pox-360)*2;
myservo1.write(pox);
//Serial.println(pox);
void Posy(){
if (poy>=0 && poy<=45)
poy = (poy*2)+180;
poy = (poy-360)*2;
myservo2.write(poy);
// Serial.println(poy);
void Poy2(){
if (poy23>=0 && poy23<=45)
poy23 = (poy23*2)+180;
poy23 = (poy23-360)*2;
myservo3.write(poy23);
