Hi, i didn´t upload the code before because i believe it is quite long and may mislead the conversation... i will put here the code utin the end of void setup, that is where the issue is happening.
// v00.1 substituidos todos analogwrite por ledcAttachPin ,ledcWrite
// PLACA V00 PRECISA CONECTAR O SCL NO LUGAR DO PUL-
#include <Arduino.h>
#include <stdio.h>
// #define USE_LittleFS
#include "esp_ota_ops.h"
//http://www.lucadentella.it/en/2018/10/27/esp32-37-ota-via-https/
// https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_https_ota.html
#include "FS.h"
#include <LittleFS.h>//https://www.dobitaobyte.com.br/como-escrever-arquivos-no-spiffs-com-esp32/
#define TWOPART
#define FORMAT_LITTLEFS_IF_FAILED true
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiManager.h>
// #include <WifiManager.h>
#include <Update.h>
#include <WiFiClient.h>
#include <HTTPClient.h>
#include <DNSServer.h>
//-------declaração de portas----------//
#define ledverdepin 27 // pino LEDVD
#define ledamarelopin 26 // pino LEDAM
#define ledvermelhopin 25 // pino LEDVM
#define ledbrancopin 33 // pino LEDBR
#define PULroletes 22 // pino SERVOPUL
#define DIRroletes 13 // pino SERVODIR
// #define pwmdescepin 32 // pino PONTEHDIR
// #define pwmsobepin 23 // pino PONTEHESQ
#define pwmdescepin 1 // canal PWM0
#define pwmsobepin 0 // canal PWM1
#define sverticaluppin 4 // pino PNP01
#define sverticaldownpin 16 // pino PNP02
#define Sinalparacanlockerpin 17 // pino PNP03
#define sgavetaabertapin 14 // pino PNP05
#define FDCroletespin 15 // pino PNP06
#define bautopin 39 // pino B01
#define bacionamentopin 34 // pino B02
#define bemergenciapin 35 // pino B03
#define Sinaldocanlockerpin 18 // pino R1
#define rmotoracpin 19 // pino R2
#define acsanalogpin 36 // pino AN01
//-------declaração de variaveis----------//
const long interval_Report = 18000;
unsigned long previousMillis_Report = 0;
unsigned long currentMillis_Report = 0;
boolean debug_mode = false;
boolean update_mode = false;
int Status_Debug;
// declarando variaveis de estado das IOs
unsigned int r1eststate = LOW;
unsigned int r2eststate = LOW;
unsigned int sverticalupstate = 1;
unsigned int sverticaldownstate = 1;
unsigned int bautostate = 1;
unsigned int sgavetaabertastate = 1;
unsigned int bacionamentostate = 1;
unsigned int bemergenciastate = 0;
unsigned int FDCroletesstate = 0;
unsigned int sroletestate = 1;
unsigned int Sinaldocanlockerstate = LOW;
unsigned int Sinalparacanlockerstate = HIGH;
unsigned int acsanalogstate;
// declarando variaveis genericas
unsigned int contador = 0;
unsigned int tipoemergencia = 0;
unsigned int FDCCORRENTESOBE = 600;
// função para ler valores da eeprom caso nao seja a primeira vez
unsigned int flag = 0;
// declarando variaveis para gravacao de numero de ciclos
unsigned int gravador = 0;
unsigned int ciclos = 0;
unsigned int enderecoCiclo = 0;
unsigned int enderecoCicloMULTIPLICADOR = 1;
unsigned int enderecoFDCsobe = 2;
// unsigned int enderecoACS = 4;
// unsigned int enderecoFDC2est = 4;
unsigned int ciclosInicial;
unsigned int ciclosMULTIPLICADORInicial;
unsigned int enderecovirgem = 5;
unsigned int enderecoCentralizar = 3;
unsigned int contadornaoacs = 0;
unsigned int state = HIGH;
unsigned int velocidadevertical = 120; // era 150
unsigned int velocidadedescida = 255;
// leituras dos valores caso nao seja o primeiro ciclo
unsigned int passos = 0;
unsigned int velocidade = 0;
boolean pulso;
unsigned int i = 0;
unsigned int passoscentralizar; // estimativa de passos para centralizar
unsigned int calib = 0;
int passos1estagio = 90; // v2.9 era 65, 24 dentes. agora 90 para 20 dentes//numero de passos realizados antes de ler o sensor fim de curso
int velocidade1estagio = 1700;
int passos2estagio = 90;
int velocidade2estagio = 1700;
int multmicropassos = 4; //(4 é para 800) passos multiplicador de passos, caso utilize a opção de micropassos do driver
int velocidadeconfig = 3000;
String SN = "0";
String num_ciclos;
int num_ciclos_int = 0;
String valortemp = "0";
void writeFile(fs::FS &fs, const char *path, String message)
// void writeFile(fs::FS &fs, String path, String message){
Serial.printf("Writing file: %s\r\n", path);
File file = fs.open(path, "w");
if (!file)
Serial.println("- failed to open file for writing");
return;
if (file.print(message))
Serial.print(message);
Serial.println(" - file written");
Serial.println("- write failed");
file.close();
/// String readFile(fs::FS &fs, String path){
String readFile(fs::FS &fs, const char *path)
String content;
Serial.printf("Reading file: %s\r\n", path);
File file = fs.open(path);
if (!file || file.isDirectory())
Serial.println("- failed to open file for reading");
while (file.available())
content = file.readString();
Serial.println("valor: " + content);
file.close();
return content;
void parametrosmemoria()
//função criada para gerar documentos iniciais na gravação do equipamento
if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED))
Serial.println("LittleFS Mount Failed");
return;
///////valor do contador//////////se nao havia arquivo criado, ele cria e atribui valor 0, se havia, pega valor
File file = LittleFS.open("/contador.txt", "r");
//Serial.println("nao encontrou, criando");
num_ciclos_int = 0;
num_ciclos = String(num_ciclos_int);
writeFile(LittleFS, "/contador.txt", num_ciclos);
num_ciclos = readFile(LittleFS, "/contador.txt");
num_ciclos_int = num_ciclos.toInt();
Serial.println("ciclos: " + num_ciclos_int);
///////valor do serial//////////se nao havia arquivo criado, ele cria e atribui valor 0, se havia, pega valor
file = LittleFS.open("/serial.txt", "r");
//Serial.println("nao encontrou serial, criando");
SN = "IL-003-0060";
writeFile(LittleFS, "/serial.txt", SN);
SN = readFile(LittleFS, "/serial.txt");
Serial.print("novo Serial Number: " + SN);
///////valor do FDC sobe//////////se nao havia arquivo criado, ele cria e atribui valor 600, se havia, pega valor
file = LittleFS.open("/FDCSOBE.txt", "r");
writeFile(LittleFS, "/FDCSOBE.txt", String(FDCCORRENTESOBE));
FDCCORRENTESOBE = readFile(LittleFS, "/FDCSOBE.txt").toInt();
Serial.print("FDC Sobe: " + FDCCORRENTESOBE);
///////valor do centralizacao//////////se nao havia arquivo criado, ele cria e atribui valor 60, se havia, pega valor
passoscentralizar = 60;
writeFile(LittleFS, "/passoscentralizar.txt", String(passoscentralizar));
passoscentralizar = readFile(LittleFS, "/FDCSOBE.txt").toInt();
Serial.print("passos centralizar: " + passoscentralizar);
LittleFS.begin();
WebServer server(80);
// GetInfo();
// connectRede();
Serial.println("V3.4 integ V00.2");
parametrosmemoria(); //grava e resgata variaveis da memoria
// configure LED PWM functionalitites
// ledcSetup(ledChannel, freq, resolution);
// attach the channel to the GPIO to be controlled
// ledcAttachPin(ledPin, ledChannel);
ledcSetup(0, 25000, 8);
ledcSetup(1, 25000, 8);
ledcAttachPin(23, 0);
ledcAttachPin(32, 1);
//if (debug_mode==true)
// mododebug();
//update_mode = digitalRead(bacionamentopin);
//if (update_mode == LOW)
// modoupdate();
Serial.print("FDC sobe: ");
Serial.println(FDCCORRENTESOBE);
// ciclos=ciclosInicial*10+(250*ciclosMULTIPLICADORInicial);
Serial.print("Ciclos: ");
Serial.println(ciclos);
pinMode(rmotoracpin, OUTPUT);
// pinMode(pwm1estpin, OUTPUT);
// pinMode(pwm2estpin, OUTPUT);
pinMode(PULroletes, OUTPUT);
pinMode(DIRroletes, OUTPUT);
pinMode(pwmsobepin, OUTPUT);
pinMode(pwmdescepin, OUTPUT);
pinMode(Sinaldocanlockerpin, OUTPUT);
pinMode(Sinalparacanlockerpin, INPUT);
pinMode(sverticaluppin, INPUT);
pinMode(sverticaldownpin, INPUT);
pinMode(bautopin, INPUT_PULLUP);
pinMode(sgavetaabertapin, INPUT_PULLUP);
pinMode(bacionamentopin, INPUT_PULLUP); //*****
pinMode(ledbrancopin, OUTPUT);
pinMode(ledamarelopin, OUTPUT);
pinMode(ledverdepin, OUTPUT);
pinMode(ledvermelhopin, OUTPUT);
pinMode(bemergenciapin, INPUT_PULLUP);
pinMode(FDCroletespin, INPUT_PULLUP);
pinMode(acsanalogpin, INPUT);
digitalWrite(Sinaldocanlockerpin, LOW);
int tempoled = 70;
digitalWrite(ledverdepin, HIGH); // liga leds
delay(tempoled);
digitalWrite(ledamarelopin, HIGH); // liga leds
delay(tempoled);
digitalWrite(ledvermelhopin, HIGH); // liga leds
delay(tempoled);
digitalWrite(ledverdepin, LOW); // liga leds
delay(tempoled);
digitalWrite(ledamarelopin, LOW); // liga leds
delay(tempoled);
digitalWrite(ledvermelhopin, LOW); // liga leds
delay(tempoled);
delay(tempoled);
delay(tempoled);
delay(tempoled);
delay(tempoled);
delay(tempoled);
ledcWrite(pwmsobepin, 0); // PWM vertical desligado
ledcWrite(pwmdescepin, 0); // PWM vertical desligado
digitalWrite(PULroletes, LOW);
digitalWrite(DIRroletes, LOW);
primeirocheck();
Serial.println("Pronto para operar!");
// codigo para enviar report a cada 3 minutos se ocioso//
int delay_entre_ciclos = 200; // quando entra no pelo modo auto, espera x tempo para iniciar o ciclo para nao cair a lata
while (1)
unsigned long currentMillis_Report = millis();
if (currentMillis_Report - previousMillis_Report >= interval_Report)
previousMillis_Report = currentMillis_Report;
SetData("CONTADOR", String() + contador);
// String IP=WiFi.localIP();
// SetData ("IP",WiFi.localIP());
checkentradas();
// Serial.println("No loop");
// se tiver com o emergencia em posição, sensor down em posição e a gaveta aberta, liga o led amarelo
// if ((bemergenciastate == 0)&& (sverticaldownstate ==0)) //retirado gaveta
// {//se tiver tudo certo menos a gaveta, liga o led amarelo
// digitalWrite(ledamarelopin, LOW);
// else
// digitalWrite(ledamarelopin, HIGH);
// check se devemos iniciar o ciclo
if ((bautostate == 0) && (bemergenciastate == 0) && (sverticaldownstate == 0))
digitalWrite(Sinaldocanlockerpin, HIGH);
// Serial.println("canlocker pronto, sinal para atuador enviado");
Sinalparacanlockerstate = digitalRead(Sinalparacanlockerpin);
if (Sinalparacanlockerstate == LOW)
Serial.println("sinal do atuador recebido para iniciar ciclo");
Serial.println("sinal do atuador nao recebido");
if ((((bautostate == 0) && (Sinalparacanlockerstate == LOW)) || (bacionamentostate == 0)) && (bemergenciastate == 0) && (sverticaldownstate == 0))
{ // se o sinal do atuador for LOW e estiver no auto, inicia o ciclo
Serial.println("entrou no laço do ciclo");
if (bautostate == 0)
contador = 0;
// Serial.println("entrou no auto");
while (contador <= delay_entre_ciclos)
checkemergencia();
delay(10); // se for o automatico, dá tempo entre ciclos
contador = contador + 10;
checkentradas();
ciclo();
// ciclo concluido
gravador = gravador + 1;
if (gravador == 10) // a cada 10 ciclos armazena o numero de ciclos realizados
gravador = 0;
ciclosInicial = ciclosInicial + 1;
if (ciclosInicial == 251) // a cada 50 sobe o multiplicador
ciclosInicial = 0;
ciclosMULTIPLICADORInicial = ciclosMULTIPLICADORInicial + 1;
// EEPROM.write(enderecoCicloMULTIPLICADOR, ciclosMULTIPLICADORInicial);
// EEPROM.write(enderecoCiclo, ciclosInicial);
ciclos = ciclosInicial * 10 + (50 * ciclosMULTIPLICADORInicial) + gravador;
// printbotoes();
checkemergencia();
delay(10);
